Question about Toshiba Satellite M35X-S311 Notebook
Toshiba mx35 s-111
Took it apart to fix the ac port. Reassembled and now I have no video display!!!
  • Dave King
    Dave King May 11, 2010
    I'll assume you had a display before you took it apart ?
    How far did you take it apart? By AC port you mean the power pin? If thats the cas eyou had it totally apart?
    When you try and start it now do you see the leds light up or change (POST test)?
Check to make sure the cable to the screen is in place. Often when you take these notebooks apart the cables become loose.
Posted on Mar 07, 2009
Took apart head of sharp steamer S3501; cannoat reassemble. Where can Iget a diagram of how to reassemble?
I just posted a video showing how I took apart and reassembled the S3501 to clear the heating core.
http://youtu.be/S4NglGXVv50
Nov 12, 2012 | Vacuums
When connected to ac adaptor it will turn on and toshiba leading innovation appear, but after that no program will displayed, but when i disconnected to the ac adaptor the programs runs normally. the
This is strange.
I think your ac adapter power cord is bad. Get another one from ebay at: http://www.ebay.com
Just put in your computer's make and model, not the model of the battery in the ebay search.
For example: Toshiba Satellite Pro L300 AC Adapter
It might be your lcd screen's inverter, but it's strange. Anyway test the inverter by plugging in the ac adapter and when the screen goes blank try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 20, 2012 | Toshiba Satellite Pro L300 Notebook
CAN WE USE TOSHIBA SATELLITE M35X-S161 AFTER REMOVAL OF ITS TFT ( DISPLAY ) IF YES HOW TO REMOVE TFT ( DISPLAY ) KINDLY ANSWER ?
You don't need to remove the LCD display even if it is not working, provided the video card is OK to use the Toshiba without its display.
Just connect a monitor to the video port on the Toshiba, then power up the monitot then boot up the Toshiba. The video data should automatically switch to the external monitor.
Nov 04, 2010 | Toshiba Computers & Internet
"No wireless network found"
you may have caused damage, or disconnected the wireless radio when you dissassembled / reassembled the case. Take it apart again and check if the wireless works while it is apart. then identify the location of the radio and see if the connection is damaged.
May 31, 2010 | Toshiba Satellite A105 Notebook
Water comes out the accessory hose but not the floor cleaner
I had the same problem and the heater ports were clogged. I took apart the top unit and cleaned the ports with miniature bottle brushes used to clean spray painting equipment (purchased at Harbor Freight for $4). Reassembled and the unit worked fine.
Feb 07, 2010 | Bissell 1699 ProHeat Clear View Upright...
Took it apart, reassembled, stopped working. Hitachi superscan elite 751
All fixed. Discovered 3 setting screws. 2 for focus, one for picture. Monitor must be running with plastic casing removed to access set screws and adjust till perfect.
Jan 28, 2010 | Computers & Internet
Toshiba Tecra S1 'Display freaks out' Iserni hello, your help with my display problems for a toshiba tecra s1 was helpyul with one exception... What/whenre is the 'Berg Strip' I took the thing apart...
if it is a single wire ,pls check it and connect to wireless card , id it has cover ,don't need to connect. also it has multi wire connector pls connect to display connect on the mother board.
Mar 07, 2017 | Toshiba Tecra S1 Laptop Notebook
Satellite ac connecting port damage how do i fix this problem
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
dissasembly instructions,you need to take out motherboard and take a look do you able to fix or need to exchange ac port
Jun 14, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba Satellite M35X-S161 - No Video
There are generic (well, platform-agnostic) and free utility programs e.g. indexed on VersionTracker, used for fan control (FanGUI, smartFan, etc.) and power management which should work without interfering terribly with that Toshiba utility. Even so, it's possible you'll need to take out a misbehaving power-saving daemon (using Task Manager or whatever.) That suggestion to fiddle with the sleep levels is reasonable; another component you might update or refresh to work in concert with those tools is the system BIOS, which sets the addresses for all those sensors where Toshiba's tools can get at 'em.
Feb 21, 2008 | Computers & Internet
Toshiba Satellite M35X-S311 Notebook Logo
88 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
