Question about Xerox WorkCentre Pro 555 Plain Paper Laser Fax
Cleaning the Xerox Workcentre Pro 575
The print quality from my workcentre has been getting worse. It looks all smudgy and faded. And it looks like there is a black haze over the entire page. I assume I have to clean something, but no where in the manual does it explain how to do this. Or could the toner cartride be of low quality?
Also, when I print photos, often they don't come out at all... and they used to print just fine.
  • 239 Answers
This sounds like the cartridges are not seating proplerly in their position. They have ground straps on the sides make sure they are in place correctly.<br /> <br /> It was mentioned when printing from memory the copies are not good quality. This indicates cartrige problems, or power supply problem.<br /> <br /> The power supplies on these machines are pretty reliable, but one can fail at any given point in time.<br /> Try changing the cartridge with a new one, even the toner cartrige.<br /> Look in the menu button for a maintance menu.<br /> There might be a clean test pattern check. Run this process with a white sheet of paper and then try making a copy and see if this helps any.<br /> Good luck.<!-- from fixya rte -->
Posted on Aug 12, 2010
    Genius:
  • 2,120 Answers
More than likely, you have a bad toner cartridge.
Posted on Nov 12, 2008
Xerox workcentre pro 55 pcl xl error
We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 bit edition is sending files to print (using the secure print function) - the system is reporting they have spooled fine to the printer - but when they go and release the document they are getting (more often than not) about 16 out of 21 pages (for example) and then a PCL XL Error (Subsystem: Text, InternalError 0x50, Operator: Text, Position: 8564). I have another document that 9 times out of ten will actually crash the WorkCentre completely and cause it to reboot mid way through printing.
The driver we are using is the latest: "Xerox WorkCentre 7655 rev 2.0 PCL6"
As mentioned the user is running Windows 7 - the printer is shared from a Windows 2003 Server which has the same version of the driver.
Jan 06, 2012 | Xerox WorkCentre Pro 575 - 550 Copier
How do you clear the memory when the machine says memory full 100%
You can find your answer at the link below. Just type "memory full" in the search dialog box and it will provide you with the many results and solutions for clearing the error. The message can be the result of many issues, so you may need to perform a few different steps:
http://www.support.xerox.com/support/workcentre-pro-575/support/enus.html
Jun 22, 2011 | Xerox WorkCentre Pro 575 Plain Paper Laser...
I have a workcentre pro 575 and am receiving the message, "memory full". Nothing will print, and I hope you can tell me how to get the stored memory to print out. Thanks.
You hopefully just need to clear memory, delete phone numbers or delete jobs.
If those don't work the Main Board might be bad 160K72560
Whit
Item, Inc
Aug 17, 2010 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Can not send or receive fax.
Is the phone line plugged into the "line" jack and not the " phone or Ext " Jack?
Jun 09, 2009 | Xerox WorkCentre Pro 575 Plain Paper Laser...
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Work center Pro 575 will not communicate with PC.
I changed the port address to 3BCh-3BF and set the port to SPP. Rebooted twice and all seems to be working. Noticed the WorkCentre wakes up from Power Save mode on reboot, if this happens then all is working OK.
Dec 06, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Xerox WorkCentre Pro 575 error message
Could be the tab that actuates the top cover switch is broken off.
The process unit is your drum,toner, and developer unit. It sits right under the top cover. Big black removeable cartridge.
Nov 03, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Xerox WorkCentre Pro 555 Plain Paper Laser Fax Logo
153 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
