Question about Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television
The Blue Color Convergence is highly distorted & will not adjust.
The set powered down by it's self and then came back on with all colors misalligned and double images. In the convergence mode I can adjust both the Red and Green but not Blue. When I try to adjust the Blue color lines it has no effect; the lines will not move in any direction. Also, the blue lines (in the convergence mode) are highly distorted as you progress from left to right on the screen. The lines dip down from the top and up from the bottom starting about half way accross screen. The HC-P4241W is approx four years old. Your help is appreciated as funds are very limited.
  • drmajor Nov 12, 2008
    I can' believe I was told to "turn the TV off for 5 minutes then turn it back on"? That has to be an automated response right?
    Your comment "the 2 output ic's stk392-110 which should be replaced" is understood. Should they be replaced with the same type IC's (392-110) or the newer STK392-180 chip which seems to handle heat a little better. I just don't know if they would be a good replacement IC for this set. Also, what circuit board are the STK IC's located on and can that board be removed completely from the TV set? Thanks...Danny
    Sergeant:
    Champion:
  • 200 Answers
Hi
Turn off for five minutes and then turn on..
Thank you
Posted on Nov 12, 2008
  • 1 more comment
  • Thafa Nov 12, 2008
    HI
    It just like a restart..
    First we want to check it like this
    while u turn on the tv, again u get the problem means..
    then only we want check the circuit board ok...
    u just do it and then tell me what is happening
    thank you
    hi
    After turn on the tv the problem continues means..
    do this if ur well in technical means do this other wise better go the service man..
    The trouble is the 2 output ic's stk392-110 which should be replaced..
    All three Color Amps are within these ic's for
    both horizontal and vertical convergence.
    Sometimes a resistor or two
    will burn out as well because of the short in these ic's.
    Be sure to be
    extrremely careful unsoldering and soldering and use good heat sink
    compound and fasten securely to the heatsink metal.
    Manual convergence
    calibration may be necessary after the ic's are replaced.
    First try
    Touch Focus after the ic's have been Properly replaced.
    Thank you
  • Thafa Nov 13, 2008
    Hi
    Better u replace with the same type IC's..
    Safety is important Danny...
    Check the resistors and other components with the multimeter..
    Thank you..
How can I fix a distorted picture?
it was convergence problem, tried first with adjustment at the set up menu. select color adjustment then adjust the red and blue to make have white balance. if can not resolved with adjustment it could be a bad convergence ic or an open change value resistor ( high resistance) near the ic.
Sep 16, 2012 | Televison & Video
I have some distored blue color across the screen
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 15, 2010 | Panasonic PT-53TW53 53" Rear Projection...
We have Phillips 55 in rear projection TV and just set our color convergence back to factory settings but we still have an awful picture. Any suggestions? All objects have multiple halo bars on them....
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Philips 55PW9363 55" Rear Projection...
Color convergence issue.
Yes,U know how to solders?Must replaced 2 convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairworld.com to buy a convergence to repair it ur self.The shop will cost U $300 for parts and labors.
Mar 27, 2010 | Toshiba 55H70 55" Rear Projection...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Mar 27, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Tv pic got distorted and has red color through it, could this mean I need the color guards cleaned?
  • Screen looks 3D
Mar 07, 2010 | Samsung HCM553W 55" Rear Projection...
COLOR CONVERGENCE PROBLEM COLOR SHAWDOWS WE HAVE
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Jan 23, 2010 | Philips 51PW9363 51" Rear Projection...
Color distortion in an Akai ( Cheaper model Rear Projection tv) I
Ur convergence is dead.Try Tv repair World.com.
Buy a whole convergence board replaced it.
Jan 01, 2010 | Akai PT4799HD Rear Projection Television
Color is distorted. Green, red, and blue ghosts
  • Screen looks 3D
Jul 15, 2009 | RCA P52950 52" Rear Projection Television
Distorted image and color
sounds like the convergence ICs have failed. Will the red and blue move in all 4 directions when you try to adjust the convergence? If not the convergence ICs are bad replace both of them also check the resistors that power the ICs as they may be open as well.
Mar 12, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Open Questions:
Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television Logo
53 people viewed this question
Henry  Thomas
Henry Thomas
