Always get a busy signel on fax and cannot get fax through
  • kfuller997 Mar 12, 2009
    I have the same problem. I have a brother fax 565 and I can send out faxes but cannot recieve any. There is always a busy signal and there is not an answering machine attached. This line is strictly for the fax machine.
    Thanks
  • 218 Answers
Check to see if there's an answering machine picking up before the fax machine gets a chance to answer. The person receiving the fax might need to temporarily disable their answering machine first.
Posted on Nov 12, 2008
My Brother MFC7340 Fax Machine will not send faxes it has a busy signal always and a busy signal when someone tries to fax me.
You need to reset the memory, since previously you have dialed some number, which is not able to connect. So restart the printer. Unplug the printer for 10 minutes and plug back the power to the printer.
Hope this helps.
Shane
Apr 04, 2011 | Brother MFC-7340 All-In-One Laser Printer
I have a bother FAX4100E . It is newly installed. I can receive faxes but when attempting to send, no dial tone is immediatley heard. The fax always gets a fast busy. It is on the same line as my old...
Hi.
Check and eventually replace the phone cable.
The fax machine must be connected using a two-conductor phone cable such as the cable pictured below at the left:
Dec 13, 2010 | Office Equipment & Supplies
The fax machine will not faxes, it prints out as busy.
make sure the cable is in the LINE socket not the TEL socket as this will stop connection..
Jul 20, 2010 | Brother IntelliFax-2820 Laser Fax
Fax is always busy when sending, have the line into the phone line port and into the telephone jack, fax scans and dials and even redials but it never go through, prints out receipt that says busy/no...
Has it always done this, or did Fax once work? Sadly, Windows XP Fax has many shortcomings, not the least of which is that it won't work with many modems still in common use. Modem incompatibility is not apparent during installation or the initial setup. It only becomes apparent when you try to send or receive a fax. The Fax Service will dial or will answer an incoming fax but then fail with any of a number of unhelpful error messages such as "Line is busy," "There is no answer," or "Reception error." There will be nothing in Event Viewer to give a clue as to where the problem might lie.
These errors have been nearly impossible to track down. To do so requires enabling both PSS and debug logging of fax transmissions, both of which require fairly extensive registry changes. For the time being, the best advice is to attempt to use XP Fax only if you have a modem that is listed on the Windows XP Hardware Compatibility List and using the latest drivers.
Hope helps.
May 09, 2010 | Brother MFC-5840CN All-In-One InkJet...
Fax is not going out and no signel in the receiver
Plug a compatable phone into the wall socket to see if you can get a dial tone.If not contact your phone company.If you get dial tone then check that you have the phone lead plugged into the line socket on the fax machine and not the extention or Tel sockets.
Oct 21, 2009 | Samsung Office Equipment & Supplies
Trouble faxing
Check the fax line with a regular phone and dial a fax number to listen for fax tones.
May 31, 2009 | Samsung SCX-5115 Fax Machines
No gps signel on my evesham navcam 7000
Evesham is no longer in business but the following url is for a company that supports their products..
http://www.tewktech.com/
As a matter of fact, I understand this company has ex-Evesham employees. Good Luck and please rate this solution ....
Jan 10, 2009 | Evesham Nav-Cam 7700 GPS Receiver
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
Brother Advantage
You mean you can't fax out or you can't get a fax because the line is always busy. I assume you already know it doesn't receive it only sends so we'll go from there. This model seems to have quite a few problems with the fax and it is usually in either the selector the processor or a switch. Make sure all your covers are closed tight if they are it's not the switch but some other problem. Your probably better off getting a new one because the repairs can be fairly expensive from $50 to $90.00 and I have found this model on the net for around $79.99. Hope this helps.
Jan 14, 2008 | Brother Multi-Function Center MFC-240C...
98 people viewed this question
jasbo
jasbo
