Question about McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK
Chainsaw shuts down when chain engaged
The chainsaw starts easily but as soon as the chain is engaged, the saw immediately stops.
  • 211 Answers
Hi gregory
I think it has a carburation problem.Check the fuel line and the fuel filter:
cheers savumihai71
Posted on Dec 03, 2008
Cant get enought gas
repair - What should I check if my chainsaw fails to start ...
diy.stackexchange.com/.../what-should-i-check-if-my-chainsaw-fails-to-s...
Feb 26, 2013 - Does anybody have any idea what I can do to get my chainsaw started?... Clean carburetor and fuel lines, especially if it may contain old fuel. ... that prevents it from generating enough current to sustain repeated firing of the spark plug as the engine turns. ... Your muffler is pluged up your saw can't exhaust.
Stihl Chainsaw - starts but won't run - GardenWeb
forums2.gardenweb.com > Garden Forums > Tool Shed
Aug 9, 2006 - Re-chocking (once until it kicks) gets it running again for another 20-30 seconds ... carb body was not letting enough gas through to contunue running the saw at full speed ..... MY STIHL 029 CHAIN SAW BLOWS GAS BACK OUT OF THE .....Can't imagine why shaking the saw around would keep it running. Chain saw won't start
Feb 8, 2012
homelite xl chainsaw
Sep 4, 2009
Husqvarna chainsaw wont start?? HELP
Oct 15, 2006
chainsaw starts then after few cuts shuts down
Mar 30, 2006
More results from forums2.gardenweb.com
chainsaw won't start - any ideas? [Archive] - Straight Dxxe ...
boards.straightdope.com > ... > Main > General Questions
21 posts - ‎11 authors
Jan 31, 2016 | Garden
How to change a chain
First of all, make sure the saw is off. Also, before removing bolts, make sure the chain brake is not engaged (the chain should move freely).
Remove the guide bar side panel. Using a scwrench or wrench, unscrew the nuts and remove the plate to access the chain.
The side plate on most chainsaws will be held on by two nuts. Loosen the blade adjustment screw (a pin that is usually driven by a screw and pushes the blade out from the chainsaw to keep the chain tension tight).
The old chain is ready to be removed now that the sprocket plate is off of the saw. Pull the nose of the chainsaw's bar away from the chainsaw to release it from the tensioner.
Remove the old chainsaw chain.
The chain will easily remove from the guide bar with all that slack in it. Note the orientation of the cutting edges of the chain so you put the new one on the same way.
Pull the drive links out of the guide bar and slip the other end of the chain around the clutch drum.
Steps to Install a New Chainsaw Chain
Thread the new chain onto the saw.
Carefully thread your new or recently sharpened chainsaw chain around the chainsaw's clutch drum, making sure that the drive links engage in the sprocket.
Thread the rest of the drive links into the guide bar and around its nose, making sure all links are in the guide bar slot.
Align the guide bar.
With the chain properly threaded along the clutch drum and guide bar, put some tension into it by pulling on the nose of the guide bar away from the chainsaw.
While pulling the guide bar, make sure to seat it onto the saw's adjustment pin.
Replace the side plate.
The side plate is ready to go back on as long as the guide bar is properly positioned beneath.
Replace the plate and the nuts that hold it into position, but do not tighten the nuts down all the way yet. The guide bar must be allowed to move a little while the chain is tightened to the correct tension.
Tighten the chain to the correct tension. Use the tensioning screw to the side of the guide bar to adjust the tension on the chainsaw chain.
Finish tightening the side plate nuts.
The chainsaw chain replacement is now complete.
And here is a great overall reference guide to keeping a chainsaw sharp and running. Sharpening a chainsaw chain is a great way to extend the life and is less expensive and easier than replacing a chain. There are small grinding tools (like a dremel) that can be run off a small 12v battery or your vehicle battery that allow for quick 'tune-ups' on your chain if you are out cutting and need to sharpen your chain.
http://www.pcta.org/pdf/STUCHAP2_web.pdf
Aug 28, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do you remove the sprocket and clutch assembly
Article: Fixing a Broken Chainsaw
Having a broken chainsaw is an inconvenience. Having one that works when you need it is important! Chainsaws are useful tools for tree pruning, cutting firewood, and carpentry projects, but are not so useful if not properly maintained. It can also cost a great deal of money to get a broken chainsaw repaired. You can save a lot of time and money by repairing it yourself. For chainsaw repair you will need a blanket or large cloth, a chainsaw tightening tool, files to sharpen the blades, and any necessary replacement parts.
My Chainsaw's Engine Does Not Start
If the engine will start at all, you might have a bad starter switch. Check to see that all connections to the starter switch are secure. Is the power cord cut or broken? Check to make sure that you have a proper power line connection. If all checks out except for the switch, go ahead and replace it. You may want to consider whether you are using the appropriate fuel mixture.
My Chainsaw Smokes
If there is smoke coming from the chain, it could be an indication that there is not enough lubrication. Without the proper lubrication, the chain and chain bar can become seriously damaged. Make sure there is oil in the reservoir. When you start the saw, the automatic oil pump should lubricate the chain and bar. To see if this is a problem, hold the saw tip over a light-colored surface, hit the throttle and look for oil spatters on the chain bar. If you see no oil splatters, turn the saw off. Remove the chain guide bar and see if the oil discharge slots are clogged with sawdust. Clean out the sawdust and restart the saw to check lubrication again.
The Chain Skips or Jumps
If the chain skips or jumps during operation, check the engine drive sprocket to make sure it is not worn. If you have a worn sprocket it will not allow the chain to sit properly. Also, check to make sure the chain tension is set correctly. Setting the chain tension is a part of continuous operation. However, a dull or damaged chain may also cause the skipping and jumping.
My Chainsaw Isn't Cutting Properly
If the saw cuts at the wrong angle or shoots out a lot of sawdust, you probably need to sharpen the chain. A dull chain can be very dangerous. It can cause a kickback or chain jump that might break the chain and release pieces that could harm to the operator. If your chain is very shiny, you need to examine each cutter for damage. Use a file to sharpen the cutters.
The Chain Continues to Move or Stops
If the chain continues to move while the engine idles then you should check to make sure the idle is not set too high. If it stops while cutting, see if the brake is engaged.
My Chainsaw Loses Power
If the saw loses power while operating, check to make sure all electrical connections are secure. Any break in current may cause the saw to decrease in power, stall or shut down altogether.
When maintained, chainsaws are a great asset to any tool collection. Consult your user's manual for questions specific to certain manufacturer types.
About the Author:
Oct 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan 2 cycle gas chainsaw 18 inch. Was real
no bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
Feb 02, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
While cutting the chainsaw bogs down and stops
Check the air filter and the muffler if either are plugged up it will not run smooth. Carb hi and low screws are very sensitive so if you change them, only move them a little at a time.
Jan 02, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Chain not engaged when the chainsaw is running and brake is off
If the brake is not engaged the only thing it could be is the clutch, or the bar. If the bar is burnt or bent from the chain failing off then you will have this problem. But this sounds more like a clutch problem
Apr 29, 2009 | Garden
Stihl chain saw
shut off the engine
pull out the hinged clip and loosen the wingnut
turn the adjusting wheel clockwise as far as stop. (on top of the adjustment wingnut).
tighten down the wingnut firmly by hand
fold down the hinger clip.
go to the following link, if you need the users manual.
http://www.stihlusa.com/stihl_ownersmanuals/MS210230250_Manual.pdf
Apr 09, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Idle is off??
hi leobowdy
disassembly the carb and carefully clean it.Check the air filter,the fuel line and fuel filter,check the needle,lever,small spring and the screen filter from the carb.Check the sparkplug.
high speed H=2 turns,low speed L=2 1/2 turns,adjust T
When chain saw starts adjust H,L and T accordingly.
cheers savumihai71.
Nov 22, 2008 | Ryobi Factory Reconditioned 18" 40cc...
McCulloch 16 In 4.5 Hp Electric Chainsaw With Carrying Case MCC4516FK Logo
227 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
