Also when i try to copy a file off my school account it wont let me ????
Right click on the file select properties you will se an array of options in the security tab make sure you have full control you can change permisions by clicking on the edit tab and also in the advanced tab you can change permissions
this may differ depending on the file and operating system
hope it helps
So when i click on edit and i says permission for everyone should i then click allow for full control ??
yes you will need full control
if you select the advanced tab you can add or change permissions
Thank you for all of your help :)
you are most welcome
The error code 80070005 usually means that you do not have enough permission to install updates.
First please confirm you have logged on an account with administrative privileges.
If the issue still occurs, lets' try the following method to reset the permissions:
1. Please download the subinacl.msi file from the following link and save the installation patch onto the Desktop:
2. Please go to the Desktop and double click the downloaded file.
3. Please select the C:\Windows\System32 folder as the Destination Folder during the installation. Later we will use this tool to reset the permission settings on the current machine.
Note: If the UAC (User Account Control) window is prompted for permission to continue, please click Continue.
4. Click Start, in the Start Search bar, type: "notepad" (without quotes) and press Enter.
5. Copy the following commands and then paste them into the open Notepad window:
@echo off
subinacl /subkeyreg HKEY_LOCAL_MACHINE /grant=administrators=f
subinacl /subkeyreg HKEY_CURRENT_USER /grant=administrators=f
subinacl /subkeyreg HKEY_CLASSES_ROOT /grant=administrators=f
subinacl /subdirectories %SystemDrive% /grant=administrators=f
subinacl /subkeyreg HKEY_LOCAL_MACHINE /grant=system=f
subinacl /subkeyreg HKEY_CURRENT_USER /grant=system=f
subinacl /subkeyreg HKEY_CLASSES_ROOT /grant=system=f
subinacl /subdirectories %SystemDrive% /grant=system=f
@Echo =========================
@Echo Finished.
@pause
6. After pasting the above commands, please close the Notepad window. Choose Save when you are prompted to save the file. Type "reset.bat" as the file name and choose Desktop from the left panel as the save location.
7. Refer to the Desktop and right click the reset.bat file, and then choose "Run as administrator."
8. You will see a DOS-like window processing.
Note: It may take several minutes. Please be patient. When it is completed, you will be prompted with the message: "Finished, press any key to continue".
Try to install the updates again.
This issue can be also caused by third-party security programs such as firewalls and anti-virus software. You can disable or remove them to check the issue.
