Question about Dishwashers
My dishwasher is filling up with water but the water want get hot
  • 218 Answers
The water needs to be hot before it goes into the dishwasher. Just before you start the machine, run the hot water faucet until the water gets hot.
Some dishwashers have a heat boost feature to sanitize the dishes, but it's not intended to take cold input water and make it hot.
Posted on Nov 12, 2008
  • 213 Answers
SOURCE: dishwasher will fill but not cycle
the motor on these dishwashers have been causing alott of problems. you might want to check your owners manual for warranty info. some of these models have 5 year warr. on the motor
Posted on Nov 21, 2007
Master_Tech
  • 770 Answers
SOURCE: Hot water fill
No you need to plumb into COLD only the unit has a built in heater if you plub it into hot you will ruin the sealve and the inlet valve will fail
Posted on May 11, 2008
  • 333 Answers
SOURCE: water fills up dishwasher after complete maybe a day or two later
Sound like the hot water sonenoid is stuck in the open position. Locate this solenoid and tap it lightly with a small hammer while the hot water is open. If it does not stop it will beneficial to have this part replaced. I hope this will help.
Posted on Jan 17, 2009
jumptrout51
  • 3361 Answers
SOURCE: water won't drain from my hot point dishwasher
Your drain/waste line under the sink is clogged with grease and soap scum.
Remove the P-trap and connecting drain lines, route out the drain and lines.
If you have a air gap mounted on the sink, clean that too.
Posted on Apr 02, 2009
  • 715 Answers
SOURCE: No water comes in my kitchenAid dishwasher
you only need prime to pump water out if you are not getting water to D/W it is most likely the water control valve
Posted on Oct 23, 2009
It' no longer cleaning my dishes
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
thanks.
Oct 23, 2010 | Dishwashers
Dishes are still dirty at the end of the cycle
hello,
hope this help?
thanks.
Oct 23, 2010 | Kenmore Dishwashers
Can I use cold water fill when installing this machine
No,
There are only a few dishwashers that have good enough heating elements to be able to use cold water.... most all of them need to fill with hot water and then the element just keeps the water hot...
heatman101
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Oct 10, 2010 | Dishwashers
Dishwasher fills with water, then empties, fills then empties, and repeats this cycle a few times - then decides to work. then part way through cycle - it repeats this frustrating cycle, making the whole...
Hi, Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Apr 18, 2010 | Fisher and Paykel DS605I Built-in...
My dishwasher is not heating the water up just running cold
Try turning on the faucet by the dishwasher and let the water run until it gets hot. Once this is done turn on the dishwasher and see if the water is warm or hot. Most dishwashers do not heat the water (residential dishwasher) they take the hot water from the hot water side of the sink. If the water heater is located a distance from the dishwasher then the cold water fills the dishwasher before the hot water can make it to the unit. This should cure your problem.
Hope this helped
Dave
Jan 15, 2010 | Dishwashers
Oct 23, 2009 | Dishwashers
Water not hot nor warm
When you run the hot water at the kitchen sink until it is hot and start a cycle on your dishwasher, is water hot when you open the door after it stops filling?
If no, the diswasher is connected to the cold water line, not the hot water line. The water temerature entering should be a minimum of 120 degrees but no hotter than 140 degrees.
If the water going in is hot, but it cools down after each filling then the heating element has failed and needs to be replaced. When the heating element fails, the dishes, especially the glassware will be foggy and still dirty.
Please reply with what you find. Good Luck!
Mar 30, 2009 | Dishwashers
Water fills up dishwasher after complete maybe a day or two later
Jan 17, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Diswasher wont fill
Faulty fill valve?
Timeing out with insufficient flow of water?
Hot water to hot and locking up valve?
Apr 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
140 people viewed this question
Top Dishwashers Experts
