Question about Lexmark X75 All-In-One InkJet Printer
Printer will not print
After restarting. checking all connections as advised, and disconeecting power source(all reccommended) the printer is still not being comunicated with
  • nancy1223 Mar 01, 2009
    printer won't print..light flashes..when i open the cover the arrow points to the color cartridge, but when i check my ink level it is not low at all.
  • 1,913 Answers
Check your usb cable.may be it is fauly.
go to control panel then printer and faxes.
then right clik on your printer then ports.
then select your usb port and clik on configure port .
if u receve error.
your connection is not proper.
if good .then try to install driver from here. - 16k -
Posted on Nov 12, 2008
My printer is a HP- 6210, Message: "remove and
Hello Cliff, welcome to FixYa.
Hard Reset the printer by doing the following:
  • Remove all the ink cartridges.
  • While the printer in ON, unplugged the power cable from the power source.
  • Disconnect the USB cable at the back of the printer (if your printer is connected through a USB cable)
  • Restart your computer.
  • Connect back the USB cable.
  • Plug the power cable to its power source.
  • Turn ON the printer if it does not turn ON automatically.
  • Install the ink cartridges.
  • If the printer prompts for an print head alignment, please do so.
If the problem persists, replace the ink cartridge. The cartridge might be defective since you already have tried to clean the contacts.
Keep me posted.
Sep 28, 2011 | HP Photosmart 2610 All-In-One InkJet...
I have upgraded to Windows 7 and my Lexmark X6170 will print but not scan. I need the scanner badly. Please advise on solution.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
Aug 29, 2011 | Lexmark X6170 All-In-One InkJet Printer
My printer model is Canon Mp250 all in one printer my problem with the printer is that everytime i print a document it always says printer is not responding, I check all the connections its all connected,...
Try to restart the print spooler service. Here is the link
Please try this solution.
Remove the USB cable into the printer and leave the printer on.
Remove all the cartridges.
Close the cartridge door and wait for the INSERT INK MESSAGE to appear.
Disconnect the power cable and from the power source supply.
Move the carriage using your hand from the original position to the other side of the printer and then move it back to original position. Wait for couple of minutes
Reconnect power cord and turn on the printer.
Return all the ink cartridges and close the door. Wait for the calibration process.
Print the test page to check if it working.
Reconnect the USB cable and try to print again.
Post comment if you need more help. Regards
Apr 09, 2011 | Office Equipment & Supplies
"The printer is offline. Check that
Issues or errors within the operating system might also cause printer offline issue. Users having offline printer issue are advised to clean the registry of the system, check integrity of the system files and also remove any malware infections using an updated antivirus program. Users must also stop the printer service active on the system and restart it as the issue might be because of errors. Removing the errors from the system would get the printer working without issues.
Jan 18, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
My printer can not read the cartages
First remove the power source.
Try cleaning the contacts on both the cartridge and the printer. I'd use a soft dry lint free cloth first.
I know your's isn't a HP printer but, HP reccommend you use distilled water and cotton buds to clean. They don't reccommend using alcohol based cleaning agents.
If you use water, you must wait for it to evapourate before inserting the cartridges and switching on.
May 11, 2010 | Canon SmartBase MP390 All-In-One InkJet...
Both the orange and the green lights are blinking and printer will not print.
The printer is waiting to receive a document to print. Choose the print command from the software program that you are using.
Wait for the printer to complete the current task.
If the printer continues to blink after several seconds, follow these steps:
    1. Turn the printer off, and then turn it back on.
    2. If it does not turn off, unplug the power cord from the back of the printer.
    3. Unplug the power cord from the power source. Wait 30 seconds.
    4. Plug the power cord into the back of the printer.
    5. Plug the power cord into the power source.
  • Restart the computer and the printer. Try printing again.
  • Make sure there is a direct connection from the printer to the computer. Remove scanners, switchboxes, and so on.
  • Try another cable.
  • Try connecting the printer to another computer. If the printer prints, then the problem was with the main computer, possibly a software or device conflict
Aug 11, 2009 | HP DeskJet 5550 InkJet Printer
My printer is not working properly. The light on the left (Amber Light, I guess this is what it is called) is blinking, but there is no paper stuck in the printer. How do I get it to stop and keep...
You will see 3 led lights on the printer. They will blink continously if:
if the print cartridge status light is flashing
-- check if the top cover is open, Close the top cover.
-- there may be a problem with a print cartridge
1. Verify that the correct print cartridges are installed.
2. Check if a print cartridge is low on ink or improperly installed.
if the resume light is flashing
-- the printer may be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of
-- the printer may be ready to print the second side of a two-sided document
1. Follow the onscreen instructions for printing the second side.
2. Press the Resume button.
if the power light is flashing
-- the printer is preparing to print
-- The light stops flashing when the printer has received all data.
if all lights are flashing
-- the printer may need to be restarted
1. Press the Power button to turn off the printer, then press the Power button
to restart the printer.Proceed to step 2 if the lights continue to flash.
2. Press the Power button to turn off the printer.
3. Disconnect the printer from the power source.
4. Reconnect the printer to the power source.Press the Power button to turn on the printer.
May 06, 2008 | HP DeskJet 940c InkJet Printer
try to install it at another computer
if not relevant - this is the fuser i think
icq 475653626
Dec 30, 2007 | Samsung ML-2510 Laser Printer
HP Officejet 5610 series printer problem in printing
Can you please restart your computer with your printer connected. Check for cartridge whether it has adequate ink.
try printing again and if it refuses to print just come back and advise me.
Dec 10, 2007 | HP Compaq Presario V2000 Notebook
Lexmark X75 All-In-One InkJet Printer Logo
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
