Question about Delta & Victorian 5 Spray Showerhead
Flow restrictor i want to remove flow restrictor in a DELTA 4" CHROME &BRASS SHOWER HEAD..looks like it can be removed with an ALLAN WRENCH but im not sure..can you help.thanks tom
  • 37 Answers
Hi, all the shower heads that I replaced, the flow restrictor was always in the nut that you screw onto the pipe that comes out of the wall.it's a plastic disc, with a little hole in middle.you can use a coat hanger to pull it out.
Posted on Nov 12, 2008
  • AL Turcotte Nov 23, 2008
    Hi, has your problem been solve yet? please respond
    Thanks
This was a great help, I was able to have a real shower again!
Thanks!
Posted on Sep 06, 2009
How can I remove the flow restrictor in the shower? I have terrible water pressure.
You need to tell us what shower head it is. Usually the flow restrictor is in the section that screws onto the pipe that goes into the wall. Be careful when you take it off so that you don't mar the chrome finish,
Aug 23, 2014 | Moen 7175CSL Level Single-Handle Kitchen...
How do I build up pressure on both sides of shower valve
why? you dont want pressure you want volume take the flow restrictor out from back of shower head and watch the difference
Feb 24, 2013 | Delta T13420 Chrome Classic Single Handle...
The shower is coming up with low pressure soon as you turn on checked filters all ok
Remove the shower head and check the water flow. If it is good, look inside the head for a restrictor that is designed to reduce the flow rte. It can be either rubber or plastic, with a smaller hole than the inside diameter of the pipe. Remove the restrictor and re-install, making sure that you still have a rubber washer to prevent leakage.
Best regards, --W/D--
May 16, 2011 | Home
Removing flow restrictor from Moen Brantford posi-temp shower he
How I remove them is take a drywall screw and screw in to the flow restrictor. Then grab it with a pair of pliers and pull out.
May 16, 2010 | Moen T2153BN Brushed Nickel Brantford...
I believe I have a delta monitor shower faucet. I am wondering why the hot water pressure is less than the cold water pressure. Also, I am wondering what size hex head I need to remove the lever so I can...
It takes a 1/8" allen wrench to remove handle. To increase hot water flow remove plastic dial that sets temperature. It is right behind handle and slides off stem for easy adjustment.
Remove indicator and replace about 1/8 to 1/4 turn counter clock wise to increase to hotter temperature.
Apr 26, 2010 | Delta & Single Handle Shower Faucet
My delta shower diverter is leaking. How do I find a model/ part number to get a repair kit ?
You may only need to soak the old one in vinegar overnight to remove hard water crust.
Take the old one out and take it to the plumbing store and get an identical one. There aren't very many part numbers for this part; all I've seen is for color choice, chrome or bronze. See if they have a special wrench for reinstalling it, as the diverter valve hex head is very thin and if you aren't fairly delicate you can mangle the brass casting of the faucet body (been there) or distort it using channel locks, vice grips and the like when removing the old one (done that).
Nov 28, 2009 | Delta Home
I have a Delta shower faucet model number 1324 and my shower head is leaking How do I get the faucet part apart I have a diagram, but actually looking at the insides it all looks like one piece I don't...
Hi Shannon:
The problem is most likely the seats and springs. You should purchase Delta Part # RP4993. I found some for mine at Lowe's for around $4.00. O-rings are available there too for about $2.00, and you probably should go ahead and replace them as well, especially if they feel dry and brittle.
You have to remove the handle, then unscrew the brass ring (or bonnet) with a pipe wrench, then just pull the cartridge straight out. Separate the lower cartridge from the upper by twisting a quarter turn to the left. Once separated, remove the black rubber seats and springs and install the new.
Sep 29, 2009 | Delta 2402 Classic Single Handle Kitchen...
American Standard Cadet 2-handle tub & shower
All you should need to do is remove the shower head and make sure that their isnt any dirt obstructing the opening ,also if their is a restrictor like you said you need to remove it.This should make a big difference.
Feb 07, 2009 | Delta & Victorian 5 Spray Showerhead
Delta & Victorian 5 Spray Showerhead  Logo
1,798 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
