Question about Roper REX3614KW Electric Dryer
My dryer belt broke
I need a diagrame of how the belt goes back on the drum and pulleys at the bottom there is just a tentioner pulley and a motor pulley (ADMERIAL_)dryer is a front loader 2 yrs old
  • hlowman20 Nov 12, 2008
    thank you so much jsrock516 belt diagram is just what I wanted .this was top notch help.ty hlowman
I need a diagrame of how the belt goes on the drum . dryer is a roper 386567 3 cycle 2-384
Posted on Apr 29, 2009
  • 5,911 Answers
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the next page, click on the "Dryer Belt Diagrams" link under the "Special Features" section. There are numerous dryer belt diagram illustrations listed that you can print out. Admiral is listed. I hope this helps you.
Posted on Nov 12, 2008
What is the belt diagram from the deck to the motor for a mower?
1st, Unplug the Dryer from the Power Supply.
You will need the Exact recommended Replacement "Idler Pulley".
With the Belt Ribs Facing Toward the Dryer Drum, position the belt on the tell tale Ring Mark on the Drum letting the Belt Hang Down below the Drum.
Place The New Idler Pulley into the Slots on the Inside Dryer Bottom located near the Motor Mounted Pulley.
(Face The Idler Pulley Toward The Motor Mounted Pulley)
(Hold the Idler Pulley in place in the slots)
Take the "Hanging Belt" & run the Whole Loop "UNDER" the Idler Pulley & then
Attach the "Belt Loop" "AROUND" The Motor Mounted Pulley.
That should do it.
Put the rest of the Dryer Back Together...Done!
Good Luck,
Vinnie
Sep 20, 2014 | Dryers
My dryer belt broke. (a) Does the belt go over the top of the tensioner wheel? (b) Or, does the belt go under the wheel (tensioned fork/wheel needs to be removed to allow the belt inside the fork). In (a)...
The belt goes on the drum, and on the motor pulley. The tensioner pulley is pulled past the belt, pulling against the spring, and pulls the belt taunt.
Best regards, --W/D--
Jan 22, 2011 | Dryers
I have an older kenmore 70 series dryer. the belt broke and im trying to figure out where the pulley is supposed to go and how the belt is supposed to go
If you are referring to the tension pulley that keeps the belt tight on the drum, it is common for it to come loose when the belt breaks because there is no longer any tension holding it in place. Just follow these steps to reinstall:
1. Make sure the drive belt is looped around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place with your left hand, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
If you have any questions, please post back with your MODEL NUMBER (located on a nameplate around the dryer door opening) so that I may be able to confirm your dryer configuration. I hope this helps you.
Feb 24, 2010 | Kenmore Dryers
I need to replace the belt in my GLER341AS2 model Frigidaire dryer. How do i open up the dryer to do so?
Unplug the dryer and using a 1/2 inch pait scraper locate the spring loded clips holding the top down to the front of the cabnet. They are located about one to two inches from the front corners of the dryer.
Lift the top and rest it on the wall behind the dryer.
Looking inside the dryer locate the screws holding the front panel to the cabnet and remove the screws.
Mark the wires to the door switch and remove.
Remove the front panel.
Go behind the dryer and remove the small rear panel near the bottom of the dryer.Observe how the belt is attached to the pulleys.Release the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go to the front of the dryer and grab the belt on the top of the dryer drum. Holding the belt lift the drum straight out holding the drum with the belt.
Check to see if all the rollers are in good shape and rotate freeley. Oil if needed.
Check to see if the teflon gliders located on the front panel that hold the drum are in good shape. Replace if needed.
Vaccum the inside of the dryer.
Put the new belt over the drum and line the drum up and install back into the dryer.
Put the front panel back on and reinstall the two screws.
Replace the door switch wires.
Make sure the grooves on the belt are flat to the dryer drum
Put the top down and go behind the dryer'
Locate the belt.
Pinch the belt and insert it under the tention pulley and slide it over the motor pulley. Make sure the belt is positioned straight and located where the old belt was positioned on the drum.
Jan 03, 2010 | Frigidaire GLER341A Electric Dryer
Belt broke and there is a small plastic part melted lying in bottom of dryer housing that looks like maybe some kind of a guide for the belt+a shoe type device lying in the bottom, looks like the belt goes...
sounds like the plastic take-up pulley on the motor which is spring loaded to keep the drum belt tight. You will have to replace the tensioner which should, depending on the model, include a new plastic pulley.
Oct 16, 2009 | Whirlpool LGR3624JQ Gas Dryer
Placrment of belt
THIS ONE IS TOUGH PUT THE BELT AROUND THE DRUM FIRST THRU THE REAR OF THE UNIT PUT THE BELT AROUND THE MOTOR PULLEY LOOK CAREFULLY AND THERE SHOULD BE WHAT THEY CALL A TENTIONER PULLEY THIS TENTIONER SHOULD GO ON THE BACK SIDE OF THE BELT THIS IS GOING TO BE TOUGH, THEY DON'T GIVE A WHOLE LOT OF ROOM FOR THIS
Aug 09, 2009 | Dryers
Installing the belt around the dryer drum and pulleys. I have a broken belt and a loose pulley at the bottom of the dryer. How to I get the pulley on? Where does the pulley attach to create the proper...
you will have to take the drum out to see where the tentioner was inserted , it is in line with the motor pulley, should be a couple holes it fits into.
putting the belt on is easy , with the lined side of the belt down on the drum take the slack at the bottom with a finger holding the belt , move the belt toward the tentioner until it touches the tentioner pulley
then with your other hand help bend the tentioner pulley with the belt on it until you can touch the motor pulley with that finger , slide it off your finger onto the motor pulley and the belt is on.
let me know if you have any questions.
Phil
Apr 14, 2009 | Dryers
Belt broke on Amana dryer
belt goes around drum and motor pulley and under tentioner
Feb 18, 2009 | Amana NDE5800AY Electric Dryer
DIAGRAM OR INSTRUCTIONS BELT INSTALLING MATAG DRYER DE412
belt goes around drum and around pulley on motor and under tentioner
Feb 18, 2009 | Maytag Dryers
Replacing maytag dryer belt
looking at the back of the motor where the belt pulley is you would grasp belt coming down from the left side of drum then come across the top of belt pulley that is on motor shaft going clockwise around that pulley then continue back to your left and over the top of belt tension pulley going counterclockwise around that pulley this is when you will have to raise pulley against spring pressure to get belt on then release belt tension pulley make sure that belt is still in belt groove on the drum hope this helps ed
Feb 28, 2008 | Dryers
Roper REX3614KW Electric Dryer Logo
550 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
