Was using my laptop working fine then message came up battery is low yet i had my laptop plugged into mains help my laptop went off checked fuse on plug still dose not work made sure all the points were connected do you have any idea my laptop is just over a year old thankyou angela
  • 153 Answers
Your laptop's power adapter must be the problem, try borrow a power adapter power cord similar voltage rating and connector to your laptop's and test to see if it is the calprit.
Posted on Nov 12, 2008
My acer aspire 7736G was working fine, it's about 2.5 years old, and is used mainly with the power cord plugged in. When using it the other day the computer just went dead on me. I took the batter
You have reached the end life of the battery pack. The battery must have some minimum charge to have computer function even with the AC power pack connected. So I suggest you replace the battery pack as a solution. Any local Radio Shack store can test this battery I am told free of charge.
Jun 20, 2012 | Computers & Internet
Dell inspiron said battery low plug into charger, when plugged in charger light goes out and laptop will not power on, why?
Remove the main battery from the laptop and try power, if it works the battery is bad, if no change the charger needs to be checked for proper voltage. Since your laptop is less than a year old you should have warranty for up to the year, check this asp and find your paperwork should verify.
Mar 24, 2012 | Dell Inspiron N5030 Notebook PC
My car has no power battery good cables tight no power. it was working fine now its not had a very low speed rear collision right before but car ran fine no damage visible rolled up windows parked and...
Your main fuse in the engine fuse box went open these are the big on some can be 80 amp or 60 amp you will see it it has a clear to case look carefully at it one will be openif you dont find the fuse look at the fuse cover you will need to replace the ignition fuse (main fuse)
Jul 31, 2011 | 1991 Saturn SC
My acer aspire one mini laptop won't turn on when i charge it. the orange light does'nt come on and i last used it about a week ago,and it hibernated because of low battery. iv'e had my laptop for about...
Remove the main battery and power supply charger adapter from the laptop, wait a few minute to get rid of any residual charge, now install the battery, power up! if no change remove battery, next plug the power supply back in, power on, if yes! the main battery is bad and needs replacement. If no change reply to this message so I can help you further. If you having low memory issues, the ram needs to be upgraded.
Jan 12, 2011 | Acer Aspire One Netbook 8.9" Notebook
Targus COMPACT laptop charger isn't working
Your battery sounds like its buggered. I would suggest buying a new battery
May 20, 2010 | Lenovo 3000 G530 Notebook
Nothing at all happening when i turn it on even when plugged into mains
Check your power adptor if it is working fine. If it is working, then check out the battery if it has drained out all power. If you can find any battery same as your laptop then try to check out with that. If it still remains dead, then you have tp open the system cover and check the internal fuse. You will fine this fuse near the input plug of your power adptor. It will be white and some visible amps will be rated, use your multimeter. There can be more problems but im just giving you basic hints if you can overcome this problem. Still can't get it done, consult with qualified IT technican. Thanks
May 15, 2010 | ASUS Eee PC 701 Notebook
My headlamp and speedometer bulb both suddenly went out. neither hi or low beam works. i pulled the headlamp bulb and it looks fine. what else might be wrong? Is there a fuse somewhere?
the fuses are near the battery housing - suzuki usually have a clear plastic case on the left side of the battery - check these fuses - the dash/clock gets its power from a relay (also near the battery) which in turn gets its power from a main fuse near the battery.
Jan 23, 2010 | 2000 Suzuki VS 1400 Intruder
Check guages light came on , 9 volts on guage,\radio died. charged batt. ran yesterday, today it wont start. battery has 12 v. turns over but no start.no guages work,when key is on. checked fuses,ok. no...
The main problem is the alternator has went out,and the battery voltage dropped to low for it to run.Most likely the computer has lost memory sense the battery was dead,or close to it.I don`t know the year,but this is most likely what happened.The computer would have to be reflashed at the dealership.But be sure to look for a main fuse to be blown,check all fuses,this might have happened,and not the computer.
Nov 03, 2009 | Dodge Pickup Cars & Trucks
Toshiba satellite M55 not turning on
Either the battery is faulty, or the charger is faulty.
Check the fuse in the mains plug, or even the power point you are using could have a bad connection.
Test using a lamp that you know works or a radio or something and try the charger in another outlet to find the fault.
May 24, 2009 | Toshiba Satellite M55-S135 Notebook
Dell D600 Battery Causes Screen to go Black
Laptop batteries normally just last for a few years, depending on usage. If your battery is almost done, it may report a 'full' status, but just have the capacity to feed your laptop for a few minutes.
You may check this by disconnecting current while your laptop is started up. If low battery capacity is the cause, the same will happen within a few minutes.
Laptops normally go in standby on low battery, to avoid data loss.
May 05, 2009 | Dell Latitude D600 Notebook
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
