Schaub lorenz lcd tv controls frozen
The remote control and the controls on the television are not working at all. We cannot change channel or volume or turn the tv on or off. We have to switch it on and of at the power point on the wall. I was hopping it was just a setting problem. Please Help.
Kind Regards
Charlotte
  • Anonymous Mar 17, 2009
    I have the same problem
  • crazy kayzy Mar 25, 2009
    Can't turn tv off at set or by remote. Can only turn off at wall. To get it working again, you have to hit the reset button at the back. Now there are green and purple vertical lines.
SOURCE: Acer AT3201W LCD TV
I repaired my Acer by replacing the power supply from
http://www.power-on.com/lcd323-4m.html - $85
Acer would not sell me a replacement power supply.
Note: I needed to solder wires the new power supply to the old one,
the pinouts on the connectors on the new one would not fit the original.
Posted on Dec 13, 2008
SOURCE: only vizio light on
RJW34 I have a 37" Viizio LCD that has a similar problem. I power it up and I get a lit screen but it's blank. No controls work except power on and off.
Posted on Feb 20, 2009
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
SOURCE: TV doesn't respond to the remote control.
surface mount capacitors on ir receiver board are shorting
Posted on Mar 15, 2010
Testimonial: "Thanks I'll be checking them."
SOURCE: Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Posted on May 30, 2010
Why my Schaub Lorenz tv the last six months keeps starting up at maximum volume every time i turn it on no matter what the volume level was the last time the tv was turned off ?
Hi, Dimitris,
The memory chip in the main board of your TV seems to have gone bad. Please see if someone can replace it, or the main board has to be changed.
Good Luck.
May 04, 2016 | Televison & Video
Tune automatically
Refer its user manual for details.
Oct 07, 2014 | Televison & Video
I have lost the manual for dax ne -190e universal tv remote
i have the same problem & the same DAX remote control. and i can't find anything. It's like this DAX xompany does not exist!!!
Dec 30, 2012 | Televison & Video
I have a 32 in insignia and a universal remote was used to try and turn channel..it turned the channel once and now its frozen on that channel even the tv remote wont work and the manual buttons on the tv...
Turn your TV off and unplug it for several minutes. Remove the batteries from any remote controls that you use for the TV, press all of their buttons, and install fresh batteries. Reset the TV to factory defaults. The universal remote control should not have caused any damage to the TV. If the problem persists, we recommend that you seek service by calling 1-888-237-8289 in the U.S or 1-866-237-8289 in Canada.
Mar 24, 2010 | Insignia NS-LTDVD19-09 LCD TV
My remote control for my polaroid tv wont change channels up and down.the channel button isnt working for the tv.everything else is working.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
Apr 19, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Yamaha RX-V663 - HDMI doesn't work.
Hi and welcome to FixYa,
Initially, a workaround:
  • as you posted, audio out of the DVD goes to the receiver;
  • HDMI out of the DVD goes to the Schaub Lorenz LCD.
Even if it were a compatibility issue or HDMI processor issue on the receiver, the above should get you going.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 19, 2008 | Yamaha RX-V663 Receiver
When I turn on my Schaub Lorenz LCD TV there are lines through the picture (digital TV) which then dissappear after 10-20secs or so. This is only a problem that has been occuring in the last couple of...
Sounds like an internal component needs to warm up before it works properly. Could be a condenser, resistor or a transistor.
If the set is under warranty, get it serviced. Chances are it will only get worse with time.
Mar 24, 2008 | Televison & Video
Televison & Video Logo
1,041 people viewed this question
Top Televison & Video Experts
