Question about ViewSonic MU203 Optical Travel Mouse
MU203 mouse not working
I have been using my Viewmate Optical Travel Mouse (MU203) mouse for at least 2 years now and all of sudden it stopped working. I tried to uninstall the driver and then restart my computer and it recognized it for about 5 minutes but then it stopped working again. My device manager says it is working properly but it is not. When I turn it over the red light isn't on but if I stick a swab in the the little opening where the sensor is the red light goes on. What do you suggest I do?
Thank you for your help.
NO RESET BUTTON AND STILL DOES NOT WORK
Posted on May 25, 2009
    President:
  • 8,637 Answers
Replace the batteries and try this.
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Posted on Jan 19, 2009
My Genius Traveler 6000x wireless mouse suddenly stopped working
Double check the batteries, although the lights work and the computer sees it, the voltage could drop low enough to stop the sensors.
next, try another USB device in that plug. USB port can go bad.
If the port works, it could be the wireless USB connector starting to fail, if they are bumped to hard sideways it can cause loose connections internally.
then, you might just need to update drivers. Computer update s can conflict with drivers cause devices toss top working.
May 20, 2014 | Genius "Wireless Mouse - Traveler 6000X,...
I have microsoft bluetooth optical mouse 4000 it suddenly stopped connecting to the receiver, as I cannot move mouse anymore
Just to clarify, this is a wireless optical mouse, right? Please try the steps below:
1. Use fresh batteries.
2. Make sure that the mouse is turned on.
3. Check if there's a connect button on the wireless receiver and underneath the mouse. If there is, try holding down the two connect buttons at the same time for five seconds and then release them both.
4. Try moving the mouse.
5. Make sure that there are no possible wireless interference between the wireless receiver and mouse like the base of a cordless phone, cell phone etc.
If same problem occur after doing the steps below, then you may want to contact the manufacturer for RMA. This Microsoft 4000 has a three year limited warranty.
Thank you!
Nov 11, 2009 | Microsoft Wireless Optical Notebook Mouse...
Right'click option has stopped working
Try another mouse If it works then it is your mouse. They are really cheap so you can pick one up a Wal-Mart really cheap..
Oct 10, 2009 | Microsoft Wireless Optical Mouse
Mouse Stops Responding
You need to reset the mouse and keyboard to the sensor. On the sensor(base) you should have a button and under the mouse you should have also a button. Press the sensor(base) button first and quickly the one under the keyboard and mouse. If the doesn't work shut down the system, unplug the mouse and keyboard sensor(base) and re-plug it back in . Start the system and try the process again.
Oct 03, 2009 | ViewSonic ViewMate CW2206 DHCW2206...
Logitech Mouse V320 Corless Optical Mouse not working
The warrenty period is usually a year. Is there a connection button on the receiver as well? Normally you need to press the connect button on the mouse, and then on the receiver shortly there after. If you want to replace it, you might have an easier time just getting a new mouse.
Jan 25, 2009 | Logitech Cordless Mouse
Microsoft Wireless Notebook Optical Mouse 3000 not working
Most devices last a long time. Have you tried re-installing the software for the keyboard & Mouse> Also go to microsoft download center and get the latest drivers for you setup. Make sure when you do, choose the right Operating System driver for your Keyboard & Mouse. Hope this helps. Bud
Dec 30, 2008 | Microsoft Wireless Optical Mouse
My wireless mouse suddenly stopped working, its on, the lights are blinking but the computer doesn't respond to it, its a microsoft wireless optical mouse.
To Troubleshoot:
1.) try to change the battery of the mouse
2.) try to connect the USB of the receiver of wireless mouse to the other open usb slot
3.) try to use your wireless mouse to other computer to troubleshoot
Sep 30, 2008 | Computers & Internet
Can't insert battery to the mouse
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Aug 02, 2008 | Micro Innovations Micro Optical 3 Button...
Help mouse problem
Click Here to download the User's Manual. It may just be going into sleep mode.
The Targus Wireless Optical Notebook Mouse features an ergonomic design with built-in power management allowing for travel or everyday desktop use. The physical on/off switch, combined with a touch sensor for sleep mode, enable optimized power management capabilities. The thumb-size USB receiver with 90-degree swivel provides flexibility in limited workspace. The mouse features sensitive optical technology for increased accuracy and ease of use.
Jul 27, 2008 | Targus Wireless Optical Notebook Mouse...
ViewSonic MU203 Optical Travel Mouse Logo
109 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
