Sears water cooler
Compressor works but no cold water
  • 31 Answers
Make sure your coils are clean,check freon
Posted on Nov 16, 2008
Why won't the red blinking light go off on my primo water cooler?
If the cooler or the water are not getting cold I would check for a high pressure reset if they are getting cold the compressor would working fine, you could also try flushing it, is there a pattern to the flash that may indicate a code................good luck! mine has developed a leak and does not heat less that 6 mo old pretty disapointing.
Jul 20, 2014 | Unknown Primo Deluxe Stainless Steel...
Water cooler stopped working
Compressor seized, may just need a new start relay or capacitor
Aug 07, 2012 | Haier WDNS32BW Hot Cold Water Cooler With...
Our Hamilton beach water cooler makes a constant noise as it cools the water. The cooler does not shut off once the water is cold. Series #A0370CT.
When empty of water remove the back panel and the cooling fins are most likely covered with an inch of dirt! Find an air compressor and blow out the dirt. It worked on mine!
Feb 15, 2011 | Hamilton Beach Water Cooler with Storage...
Cooler not running
Check power to relay. If yes, check compressor is working. If yes, keep your hand on discharge pipe. If it's not warm, cooler is under gas leak. Rectify leak and recharge gas.Thanks.
Jan 24, 2011 | Whynter FX-6SB Free Standing Hot & Cold...
Cold water spiget handle broke off . can i get a replacment ?
Yes. Call Sears parts direct at 1-800-252-1698 or go to repairclinic.com
Dec 19, 2010 | Avanti Hot and Cold Water Cooler
Cooling does not work either
Get in there with a vacuum and clean up the condenser coils then check the compressor relay. If all those are fine bypass the cold control just long enough to see if the water cooler works. Do not leave it bypassed or damage to the reservoir could occur.
Aug 31, 2009 | Hamilton Beach Water Cooler with Storage...
Water doesn't get cold anymore.
Hi, check receptacle for power, plug something, fan, radio etc, if there're power (voltage) it's possible your compressor has hard start, you can buy compressor hard start kit and try to start compressor, if compressor are working, maybe you got, freon leak, or you could have low voltage problem, or faulty overload relay on compressor, unplug water cooler, for about an hour, then replug it, let me know what happened, then i can tell you exactly what's problem. good luck.
Aug 11, 2009 | Hamilton Beach Water Cooler with Storage...
Water is hot on both cold and hot side of my water cooler. water bottle on cooler is extreamly hot.
are you talking about a water cooler dispenser with hot and cold valve?
if you do, the cooling side is not functioning well.
is the compressor running? if not, check the thermostat.
if the compressor tries to start but can not. check the relay of the compressor, it may be bad.
if the relay is ok then the compressor is bad.
another thing to look at is the hot water thermostat. it may no longer functioning as to the cause of the bottle to be extremely hot.
tnx 4 using fixya,
drcool
Oct 06, 2008 | Whirlpool Refrigerators
Water not getting cold
see if the compressor is working or move the thermostat to a highter level
Dec 29, 2007 | Whynter FX-6SW Free Standing Hot & Cold...
Heating & Cooling Logo
182 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
