Question about JVC KT-SR2000 SIRIUS Radio Receiver
Backlight inop sometimes
Lately the backlight on my wifes unit has been inop. Sometimes it works and sometimes it doesn't. The unit is less than a year old. Any ideas on how to remedy this problem would be greatly appreciated.
  • Anonymous Aug 15, 2008
    same
JVC KT-SR2000 backlight repair
Posted on Apr 10, 2009
How do I repair backlight?
Repair: LCD Monitor Backlight - YouTube
? 6:06
https://www.youtube.com/watch?v=BTjH-jkuo9Y
Jan 30, 2014 - Uploaded by Heilman Hackatronics
This videos shows how to repair an LCD monitor Backlight. ... I've Samsung SA300 21.5 inch led monitor ...
How To Replace a LCD Backlight - Instructables
www.instructables.com/id/How-To-Replace-a-LCD-Backlight/
InstructablesHere are some simple instructions on how to replace a burnt out LCD backlight with a new working one to bring your LCD back to life. ... To get the the LCD screen and thebacklight inside, you must first disassemble the LCD housing; this is different depending on whether it is an ...
A (very) Simple LCD Backlight Fix - Instructables
www.instructables.com/id/A-very-Simple-LCD-Backlight-Fix/
InstructablesFix any broken LCD backlight with an ordinary light bulb and a dead CRT monitor.Broken LCD monitors basically come in three categories:1) Cracked LCD ...
Dec 30, 2015 | Samsung Televison & Video
My 6270 backlight when it suppose to turn on sometmes it doesn't or sometimes comes on dim. If I tap the side it comes up bright. I am familiar with trouble shooting circuit boards to a component...
Sound like u have loose Fiber Optic cables connections cables somewhere,if u tap the side of it comes back brightter.Take the unit aparts and tries reconnected all the Fiber Optic cables tightly if it work.Tries it out the unit turn it on/off 5 or 6 the backlight go up good and bright.Take hot glue gun glue all the Fiber Optic cables connections together for good.
Aug 11, 2011 | Ademco 6270 Graphic Touchscreen Touch...
Dell XPS M1330 Backlight Problems
Really does sound like a backlight problem. They usually don't cost much and are easy to replace if you are good with a screwdriver.
Apr 25, 2010 | Dell XPS M1330 Notebook
My screen light went off. Internet is working I can see the background.
1. First make sure the backlight was not turned off by inadvertently cycling the "CRT/LCD" function- the key combination "Fn" + "F8" is used by Dell but EVO may be different. Hold down the "Fn" (function) key and press the "F8" (or EVO equivalent) a few times and see if the backlight comes back on. (The purpose is to turn off the notebook backlight if a standalone monitor is used.)
2. You might find that the switch that shuts the backlight off is stuck. Sometimes there is a little piece of plastic sticking above the surface of the of computer base (often near the hinge). Sometimes it is pretty well hidden, and sometimes it is completely internal.
(NOTE: The above solutions assume the backlight never comes on. If it goes off after a period time there could be a hardware problem - with the backlight itself or its inverter board).
3. By the way, you can connect a standalone monitor into the appropriate laptop connector and use it until you figure out what is wrong with the backlight. I'm doing that myself right now. You must get the CRT/LCD correct to do this.
Oct 15, 2009 | Compaq Evo N610C Notebook
Sidekick III 3 LCD Backlight stopped working sometimes
yes you need to replaced the LCD to make it work again.
Jun 03, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Acer travelmate 2410
This doesn't necessarily rule out the inverter. I've had inverters with intermittent problems that had the same effect, so having the inverter tested is the only way to rule it out. Other possibilities are a bad connection, a corroded/dirty pin or socket in a connector, a bad ribbon/cable, and a failing backlight. If it is a failing backlight, the entire screen will need replaced, as the screen is considered a sealed unit and the backlight isn't available and not considered a replaceable item. Also, it's rare, but it could have a faulty motherboard component or video card. I'm leaning towards a faulty backlight, but keep in mind the inverter and cable possibility. Start by checking and cleaning all connections.
Sep 17, 2008 | Acer TravelMate 2300 Notebook
Backlight
your problem is the backlight, changeit and solved the problem....
http://articulo.mercadolibre.com.mx/MLM-28562362-lampara-backlight-para-lcd-de-laptop-acer-compaqdell-_JM
i buy this and i kick this problem....
Jun 09, 2008 | Computers & Internet
Cloudy patches from backlight leakage in LCD TV
You have to send it back to company to fix this problem>
Dec 04, 2007 | Televison & Video
Garmin GPSMAP 60Cx Powerup Problem
I suddenly had the same problem. Here a page with the explanations : http://forums.motionbased.com/smf/index.php?topic=3814.0 I removed the cache back to clean power connectors, tighten the cache back to properly adjust the power connectors on the map. Now everything is working properly.
Oct 31, 2007 | Garmin GPSMAP 60Cx GPS Receiver
JVC KT-SR2000 SIRIUS Radio Receiver Logo
459 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
