Question about Car Audio & Video
RADIO NOT WORKING AND I DON'T KNOW NUMBER FUSE TO CHECK
I HAD A NEW SOUND SYSTEM INSTALLED, AND NOW IT'S NOT WORKING AND I DON'T KNOW WHAT NUMBER FUSE TO CHECK
  • 3 Answers
Some stereos have a fuse on the back of them usually a 15 amp. Some have an inline fuse round inside a small holder on the power in wire, they are red or clear. If you are refering to as which fuse to change in yours cars fuse box it is usually the one that goes to the Accesories, the lid to the fuse box usually has this information, or your owners manual, or you can pick up a motor manual for you cars make, model, and year at your local auto supply store.
Posted on Nov 12, 2008
Radio not working
intermitent on and off sounds like a loose connection ,this could have blown fuse at rear of radio , check and replace if blown and make sure all wiring connectors are pushed home fully
Mar 28, 2014 | Mercedes-Benz Cars & Trucks
Hello , I have a new Tiguan trend and fun 2.0 and my dash light and radio won't work.
Check the manual and find the fuse box or boxes. find the dash lite fuse, it may say " interior illumination" If it is good check also the radio fuse.
If the fuses are good, you have to visit a wv dealer for detailed fault finding.
If the car still have warranty, don`t mess with the electrical system.
The car also have can bus electrical system, and it can go wrong when you try to fault find your self.
The fault could be the light switch, fuses, the radio.
Here is a fuse list for a golf:
http://mit.edu/dennis/www/vw/fuses.html
Check the Fog light relay, instrument panel light dimmer switch fuse.
Good luck
Jan 08, 2013 | RupseTM For VW: New BORA / PASSAT CC /...
Radio does not work/fuse is good/ no light, clock, sound, power etc
Question: Did you use a wiring harness to install the radio? If not, I recommend you get one and use it. You run the risk of frying you entire electrical system if you don't. Of course, you may get lucky, but not usually. The wires on the wiring harness will match the wiring of the radio you are installing. All radio wires are standardized in color. If you did use a harness, check the crimps on the wires. Hope this helps
Aug 22, 2011 | Car Audio & Video
Pontiac grand am 2004 3.4 6cylinder installed brand new battery altenator & starter all good car started took it for test drive everything shut off car wont start. lights radio still come on
Sounds like the security system activated or the ignition is bad. If you have an alarm installed remove it. If you don't then replace the ignition switch after checking all fuses in the fuse panel. There is one that can blow and will give you this symptom.
Jul 22, 2011 | 2004 Pontiac Grand Am
The display lights in my stereo sound system have failed. There is no channel number display or control adjustment display lights. All the other dash lights in and around the radio system are working just...
It is a common issue. there is no easy fix. The radio will have to be repaired or replaced. The least costly option is an aftermarket unit. You can have new unit installed for less than $150usd
Feb 20, 2011 | 2005 Suzuki Forenza
Sound stopped working except system sounds
reinstall the drivers for your sound card, you don't have to have the install cd just go to support.dell.com and choose your model pc, and dl the audio driver
Nov 01, 2009 | Dell Microsoft Windows XP Home Edition
1993 240 volvo, radio, door locks, clock do not work. not fuse.
check all your fuses,,,sometime the radio display is on a separate fuse.....
Feb 02, 2009 | 1993 Volvo 240
My Altec Lansing ADA745 speakers have stopped working. I probably downloaded some other software that overrode the Dell speaker installation. How do I reinstall the Altec Lansing ADA745 speakers?
The speakers are probably fine. What you probably need to do is to reinstall the sound drivers on your dell.
You need the model of your dell pc and go to the dell website and find download and install the sound drivers for your system.
The model of your pc will be needed if any more assistance is needed.
Sep 16, 2008 | Computers & Internet
Car Audio & Video Logo
63 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
