Question about Kenmore 22422 Top Load Washer
Washer stopped in the middle of the cycle
I have a Kenmore top load washer, model 110.4750292. It was in the middle of the wash cylce when it suddenly stopped. Tried to reset (push then pull the knob again), it wont work but after about half-an-hour, I rest again and it worked. Then after a few minutes, it stopped again. Tried filling-up water or the spin cycle but it wont start. Please help. Thanks!
  • jo_calalang Nov 12, 2008
    after cleaning the contacts on the timer, it worked...just dont know how long...
  • 63 Answers
Sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Posted on Nov 12, 2008
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
Kenmore oasis HE Top load Washer stopped in the middle of a cycle. No power and will not unlock
error code? totally unresponsive? try reseting power then if unresp. replace main control. verify 120v into board. 3 screws on rear of console and lift.
Sep 16, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Washer stops in middle of cycle. Comes up with code d5. My wife pushed something on and off 3 times and came up with a code of f71
some machines come with a reset program but not all. Suggest you pull the plug out and wait 20 min untill washer has totally discharged. In the mean time, try and drain the water from the tub. Take note if the drain pump motor is working as well. Retry a wash program..
Sep 06, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Cylce stops after 1st drain before spin out
I have kenmore washer front load H2 after 1st circle of wash it stop and start beeping with code F11. My email address is anarfi1212@ live.com
Jan 21, 2010 | Kenmore HE2 Plus Front Load Washer
I had the problem with the washer not agitating once it filled.
The control panel has a clip at each front corner. Push a putty knife between the case top and the control panel, at the corner and you will feel a spring clip. Push toward the rear of the machine to conpress the clip and it will release. Repeat at other corner. The panel has two connectors on the back at the top corners. The newer machines will allow the panel to roll over the back, carefully. Otherwise there will be two screws that will need to be removed.
Aug 16, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore TL Washer Just Hums
try to wash by 1/2 load the same cycle maybe the problem come from overload laundary
Jun 06, 2009 | Washing Machines
Washer stops during rinse cycle and isn't easily restartable....
Sounds like the contacts in the timer has a problem. Unplug washer. Remove the back of the washer and spray WD40 in the timer. Put towels around and under to to collect excess runoff.
Rrotate washer dial 25 times and spray some more wd40. Rotate 25 times again. Do a wash load. If it works put everting back together.
May 04, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Goes through all cycles by will not drain or spin.
If the timer hangs at points in the wash cycle, and you can manually advance, then the timer continues to run or runs shortly before hanging again, then the timer is bad and needs to be replaced.
Jan 24, 2009 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore Elite Washer that does not complete the wash
The timer should be checked/replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 12, 2009 | Kenmore 22422 Top Load Washer
Kenmore 25852 Top Load Washer dead
Check the lid switch again. There are two wires going to this switch, jump these two together, if it works replace the switch.
Dec 16, 2008 | Kenmore 25852 Top Load Washer
Kenmore 22422 Top Load Washer Logo
343 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
