Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jenn Air Fridge Temperature Way Too Cold!!!
Jenn Air side by side.  The refridge temperature is 20 degrees colder than what it is set at and continues to freeze liquids and food in fridge...
  • Anonymous Nov 13, 2008
    I have had the problem in the past, and it required thawing the defrost drain 6 years ago, and replacing the defrost control last year. I was hoping to find access to the defrost drain and try to thaw it before I pay a service call
SOURCE: Increasing ice AND temperature paradox
After reading this forum and other places I was pretty sure that luck of defrosting is a symptom and the defrosting timer relay is the most likely problem in my case. I must say that my Jenn-Air JCD2289AT refrigerator was occasionally creating rattling sounds in the upper right corner under the panel. I suspected some relay malfunction. This sound lasted for almost a year and then stopped. Refrigerator lost the temperature while working continuously without turning off. I went to a local parts shop and they had this defrost timer in stock. They said that the item is very popular and they always keep it in their stock. Calling technician would cost me $80 and the part was also $80 (not returnable). I’ve made my best bet and bought the part. I removed the panel and found the timer small board (2x3 in) in the upper right side. Make sure unplug refrigerator from power before changing it. The new part is coming in a plastic case, while the old part was without a case. I removed the cover to take picture and compare. My old part had a relay with a bulge on a side apparently due to burned contacts inside (see photo),
cbf6fab.jpg while the relay on the new one was perfectly square.
c49b9ad.jpg This is a picture without a cover.
I turned on the refrigerator and didn’t see any difference. Obviously, it needs defrosting. I was afraid that automated defrosting at a random time would flood my kitchen, so I opened up the panel in the freezer part to expose coils. Here I took an opportunity to check heating element with a relay. The relay was in “on” position, as supposed to while immersed into ice. The heater showed a resistance of 22.6 ω, and I thought it was OK.
e207d3c.jpg This is partially thawed situation (I used a hair drier).
On the bottom left of the compartment I discovered a 2x3 inch opening connecting the freezer and refrigerator compartments. It was initially completely clogged with ice. That’s why the temperature in refrigerator part was so high, while the freezer stayed cold.
05b8f22.jpg This is a veiw from refrigerator compartment. The hole is ~ 6 inches above the bottom on the left side. It provides cold air from the freezer compartment. If I checked it first, it would give me a clear idea what was going on.
7aee4b8.jpg I tried to collect water as much as possible not to overfill the tray under refrigerator.
Still the water spilled onto the floor. I pushed down on the front side of the tray and made a controlled spill. Now the tray had extra room for any residual water.
Refrigerator is working normally now.
This was the second strike. I am planning to move it to the garage and buy another brand. I think Jenn-Air/Maytag engineers are not smart enough to use old fashion electromagnetic relays. Technology offer more reliable electronic switches now for at leas several decades.
Happy end
Posted on Aug 19, 2008
  • 306 Answers
SOURCE: Fridge not keeping food cold.
When you open door to freezer do you hear a fan inside that compartment blowing? If you don't the fan motor is shot and will need to be replaced.
Posted on Nov 26, 2008
  • 115 Answers
SOURCE: fridge freezes food even though its set at warmest temp
what it sounds like is either your damper is stuck or your damper motor is bad it will probably be in the top left of your refrigerator side
Posted on Dec 30, 2008
tborn6
  • 700 Answers
SOURCE: Freezer appears to be working properly - fridge is not cold
if this has only one evaporattor coil then you wil have to turn down the freezer too. first check to see if the if the manual damper motor is working properly. turn the tempertur to 0 on the frig and the damoer should close down. look to see if it did. then turn to 9 and you should hear the damper motor opening and feel air from the outlet.
Posted on Mar 29, 2009
  • 11 Answers
SOURCE: My jenn-air refrigerator and freezer temp controls
you need to unplug it and put oil in to it so that is will sorf and easy to turn .... or change the temp.adjuster key
Posted on Jan 25, 2010
Fridge keeps freezing
Cold air falls so unless your fridge has a fan the bottom is always going to be colder than the top. Raise the temperature by a couple of degrees, as your thermostat is reading the temperature at the top.
May 29, 2015 | Refrigerators
Jenn air refrigerator model jbr2088hes is not cooling fan is blowing and cool air is coming into refrigerator
A compressor can naturally get hot the tech leaving parts on the floor is wrong the real way to tell if the compressor is bad is to unplug the fridge find the thermostat and unplug the two wires that plug into it then make a small jumper wire with two male spades and a two inch peice of wire and plug it in to both of the wires that you unhooked from the thermostat then plug in the fridge and wait 20 min if the fridge gets to normal cold which is 37 degrees or less it's not the compressor it's the thermostat but if it don't get any colder than before it may be the compressor but a new fridge is less that 500 dollars
Mar 12, 2014 | Jenn-Air JBR2088HES Stainless Steel Bottom...
I have a Jenn-Air JCD2295KES side-by-side - freezer fine but the fridge too cold
The thermostat is not registering temperature correctly. If you have thermistors they should be replaced
Feb 27, 2014 | Jenn-Air JCD2295KES Stainless Steel
GE monogram refrigerator too cold
There is a balance between the freezer and fridge. Reduce the freezer temp and see what the fridge temp does. By reduce I
mean make the freezer warmer. If it is set too cold the fridge gets colder.
Nov 25, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Freezer turns of in cold weather
Many residential refrigerator / freezers are designed to work at temperature considerably above above freezing. Most modern refrigerator / freezer have a single electric thermostat - located in the fresh food compartment. This lone thermostat will control the compressor to keep the fridge (fresh food) section at the desired temperature (usually between 34 - 38 degrees F). The freezer will get colder regardless of how cold it is already whenever the fridge thermostat turns the compressor on.
Now that you see how the thermostat works, let's look at what happens when the fridge is placed in an unheated space - like a garage. In winter time, the temperature can drop considerably below 38 degrees. If the outdoor temperature remains cold enough, for long enough - it will affect the thermostat in the fridge. The temperature inside the fridge could drop below 38 degrees, preventing the thermostat from telling the compressor to turn on. Meanwhile, the temperature in the freezer compartment slowly rises from the normal -10 to 0 F degrees. It will continue to rise until it is the same temperature as the fresh food compartment or until the thermostat in the fresh food compartment tells the compressor to turn on again. This means the freezer contents will thaw.
If the temperature in the garage is even in the 40 to 50 degree range, the loss of cold in the fridge may not happen often enough to keep the compressor coming on often enough to keep some freezer items frozen solid - such as ice cream. Remember, water freezes at 32 degrees F, other products may require lower temperatures to remain frozen, and could thaw at 28 or other temperature.
Feb 13, 2012 | Refrigerators
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
Refrigerator top rack is warm. Temperature shows 65 degrees
if your freezer can make ice and the ice is dry, the problem is simply air flow into the refig section. A very common cause for a service call that wasnt needed for reefers is the settings. One setting OFF 1-10 usually, operates the compressor. The remaining setting will say , for colder freezer or similar, It opens a little flapper door between the freezer and the fridge section. If you set that one to max or coldest freezer it will actually starve out the fridge section for air ,and you get a cold freezer and warmer box! It happens everytime someone has the problem , its too warm! they peg both controls to coldest! The compressor will coll the freezer sufficiently even if set to 1 and the fridge should be cool too if the setting isnt pegged to coldest setting thus closing down fridge air and making the freezer colder which isnt ever required!
Aug 25, 2009 | Jenn-Air JSD2695KES Side by Side...
Upper freezer is working but the temperature in the fridge part is approx. 65 degrees -- not cold.
This is a malfunction of the control board. The control board is telling the refridge side that it is plenty cold - so it doesn't divert the cold air needed to keep the refridge side cool enough. Check to see the the coils in the freezer are frozen - if they are, unplug the unit and defrost with a hair dryer. Dry up the water and turn it back on - that should solve your problem.
Aug 22, 2009 | Refrigerators
Mar 29, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
118 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
