Question about HTC PPC-6800 Smartphone
Sanyo 8125 battery issues
When i charge it, the red light comes on. but when i try to turn it on, it does nothing.. plz help
  • 4 Answers
Red means no juice obviously, try letting the phone charge for a while to at least the yellow light. If the problem persists, understand that wear and tear on these phones will often times wear out the buttons on the side of it, or there could be another underlying issue I'm not understanding, but when my phone started acting up with the power button, I took it to the dealership that sold me the phone and had them replace it under factory warranty. If you're not feeling ambitious enough to do that, just press the button harder next time.
Posted on Nov 14, 2008
I have a Sanyo T700 camera. Just got a new battery off Ebay. I inserted it inside the camera and a red light came on. Does that mean the battery is charging or does a green light mean that its...
The manual says that a red light is a charging error. Green means it is charging and the light goes out when charging is complete.
The camera must be turned off when charging the battery. They recommend a full 8 hour charge for a new battery, then allow it to discharge completely (leave the camera on I guess) and charge it again "before use".
You can download the manual from this page. Select the "Resources" tab.
Nov 05, 2010 | Sanyo Xacti VPC-T700 Digital Camera
Gps not turning on/starting
I have the same problem. It may have something to do with battery. Try to charge it via your car. Or get a Garmin and never buy a Sanyo GPS again.
Jul 11, 2010 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Hi i have a 50 inch sanyo plasma tv...all of a sudden the tv turned off and never turned back on no power nothing plz help
Usually a power issus are a power suppy issue or main board issue. If unit or pilot lights do not light happens.
Nov 08, 2009 | Sanyo DP42746 42 in. Plasma Television
Cingular 8125, dead as a doornail.
u can take a usb cable that not being used by any thing . save the end that plugs in to your computer . the end you would plug in to the device you can cut off and you need to use the red and black wires to jump start the battery so it will charge . on your battery you will see the - and + the black goes to the - and red to + can use electric tape to hold the exposed wire to it and plug the other end in to your computer for about a 5 to 10 mins and then put it in your phone and turn it on and charge it .if didnt work you might have to leave it hocked up to the usb cord on the battery longer what i did to mine and it turns on and works fine now had the same problem battery got to low and dead . so phone was froze and wouldnt start
Jun 12, 2009 | Cingular Wireless 8125 Smartphone
HTC touch will not turn on
Hello friend. i am having the same mobile and had a same problem while i let it charge the whole nit and in the morning it never boot. its the battery problem. change the battery or get one of ur friend same kind of battery and boot with it. it will boot. cheer up the battery has gone. the problem is the new battery wont avail for this model. i tried a cheep one that little bit solved the problem but the talk time comes to very low. original battery must be replaced. best of luck.
May 28, 2009 | HTC Touch P3450 Smartphone
Will not power up on AC or usb adapter
If you have an extra charger for the phone remove the end take the exposed copper wires hold them to the positive and negative post's on the battery for about 3 minutes and then plug into the normal charger.
I know this works I did it to my phone last night.
Jan 07, 2009 | Cingular Wireless 8125 Smartphone
8125 will not reboot
You need to jump start the battery.. The phone's charging capability is controlled by software (pretty dumb) so without enough juice from the battery it won't charge.
Grab an old USB cable (or other 5 volt source) and cut off one end.. take the red wire and put it on the battery contact on the end with the red plus sign. Put the black wire on the other end. Hold the wires there for about 3 minutes. Be careful not to switch the positive and negative.
Now reinsert the battery into the device, and without turning it on, plug in your charger. the charging light should come on shortly, and just leave it off charging for about an hour before turning it on..
Thats all Folks
Dec 04, 2007 | Cingular Wireless 8125 Smartphone
I HAVE A SANYO 8125 PHONE THAT....
most likely you should get a new battery or a new phone all together. after you have most sanyo phones for a while the battery stops working
Nov 13, 2007 | HTC PPC-6800 Smartphone
HTC PPC-6800 Smartphone Logo
51 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
