Question about Coleman Powermate Premium Plus 6250W Portable Generator
Powermate 6250 loaps.
Filled new generator with oil and fresh gas then started engine. The engine loaps with the carb linkage moving back and forth on it's own.
I also do not see where engine speed is adjusted eventhough the Tecumseh manual says it should be. Any suggestions?
Thanks,
Bill
  • 1 more comment
  • Anonymous Dec 01, 2008
    severe surging
    , no load
  • Anonymous Dec 14, 2008
    I have the same issue with the 6250. But it is only when under no load or light load. I grabbed an old bare wire radiant heater (you know the kind that turns bright red and causes fires) and have that sitting out in the middle of my back yard on a can and as long as that is plugged in when no house load is on the generator runs perfect. If the house load comes online I can unplug the heater and it is still OK until the load ceases, Brand new gas and oil, the generator has only run about an huor before this,
  • beebob308 Dec 24, 2008
    I have the same problem with my coleman powermate 6250 ..Bought it 2 years ago and tried A couple of times to get it going but won't stop loaping for me ...Got discouraged and put it away ...The power is going out now and I still don't have power ...Kinda defeats the purpose of buy A generator ...lol Brought it to A small engine repair shop but he has no clue how to set the governor on it ...Would like A bit of help ...
I took a new generator out of the box, filled it with oil and gas then started it. The govenor /carb linkage was moving violenting back and forth and the engine was backfiring.
I was able to get it to settle down by holding the linkage and closing the throttle plate a little but it would resume surging and backfiring when I let go of the linkage.
I tried again several weeks later. This time, after babying the linkage to get it to settle down, I moved the linkage about a 1/4 inch (which closed the throttle plate slightly) and lightly secured it in place with a ty-wrap. After running 10 minutes it finally settled down to where the backfiring stopped and the linkage stopped moving.
It was still okay after powering a heater motor and light.
I'm thinking that the problem with this engine is just that it needs a long warm-up time. I know very little about engines, so I could be wrong.
Bill
Posted on Dec 14, 2008
  • 169 Answers
I've never been a big fan of the 180 OH family of engines in these things, but here goes.
1 - If the engine will stay running while it surges, close the choke a little at a time and see if it settles down. If it does, there is something amiss in the carb. The carbs on these engines are very picky about tiny bits of dirt. The good news is that they are fairly simple to take apart and clean, the bad news is that lots of the parts are plastic and break easily. At least they aren't too expensive.
2 - I've seen 2 ways to adjust the governed speed on these engines; a spring that connects to the governor arm at one end and a tab bent up from the sheet metal that mounts on top of the engine at the other - bend the tab so the spring is tighter to speed the engine up, and (b) a jam nut and screw mechanism that presses against a lever that pulls on a spring that connects to the governor arm - screw the screw in tighter to raise the engine speed.
Note that in either case the mechanism adjusts the tension in a spring that pulls against the governor arm, this is helpful in finding out where to make the adjustment.
Here in the US we want our 2 pole generators like this to run at 3750 rpm at no load so that we get very close to 3600 rpm at load. If you're using a DMM to measure the output of the generator in Hz, you want 61.5 at no load.
If nothing you can do with the choke makes the surge go away, you might have a misadjusted governor. The Tecumseh service manual has a great procedure for making this adjustment, essentially what you do is loosen the retaining nut on the governor arm, twist the governor shaft to its minimum speed position, then hold the throttle assembly at the idle stop and tighten the governor arm jam nut. Always keep a finger near the kill switch when running the engine the first time after this procedure, it's easy to mess up and have a runaway engine.
Please rank me if this was helpful,
Carl
Posted on Dec 02, 2008
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Start up instructions for PM05450-07.02
check the oil level fill fuel tank with fresh fuel open the shut off valve on the bottom of the tank put choke on and turn the kill switch to the on position and pull the rope release choke after i second pull alway shut the fuel off and run the carb out of gas when done using it
Sep 03, 2012 | Coleman Powermate 6250
I have a coleman powermate premium plus 6250 generator,put in new plug ,new filter ,changed oil,cleaned the carb,put in new gas. runs ok at half choke but when go full choke it starts backfiring and runs...
if you are running the engine at full CHOKE, then it is flooding the engine, but if you meant off full choke, then the carb is still stopped up. Try soaking in carb cleaner overnight after removing jet & all rubber goods. HOPE THIS HELPS.
Dec 17, 2010 | Coleman Powermate Premium Plus 6250W...
I have a Coleman Powermate PRO-GEN 5000 (6250). It has been sitting for a year and the gas value was not shut off (oversite). When checking the oil, it smells like there is gas in the oil-is this possible?
when the engine sets for a long time the gas can seep bast in to the cylinder and their will be some gas you will need to change the oil and take the spark plug out and air i suggest you squirt a small amount of oil in the cylinder gas in the cylinder can wash out the lube to the rings and cause undo wear and start smoking turn the engine by hand slowly to allow lubing of the rings the gas seepage is most likely caused by a float that's not set correctly you may need to rebuild the carb with a kit around 20 bucks ans easy to do at least the clean it well to remove schlack that gas leaves behind when it dissipates and can cause issues.
replace with fresh gas and run the engine and it will smoke for a couple mins do to the oil in the cylinder remove the spark pug after running a couple mins and clean or replace the engine should be fine following the steps above. hope this helps
Aug 03, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman 6250 PoweLeaking gas at bottom of motor housing. Can not
The gas is leaking from carb but in the motor not out.
You should check and repair the carb flow valve. The floating unit may be full and bent down.
Jun 20, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate 6250 generator - shut off generator at 11pm after v4 hours normal use. At 5am, wouldn't start, pull rope wouldn't move to start. A few hours later while draining oil found mostly gas...
the usual reason is a stuck float in your carburator , can be caused by dirt/rust etc , remove carb bowl and clean , there is also a very small needle valve which is attached to this float ( metering needle ) these can leak.
if all else fails always turn off the fuel supply to the generator whilst not in use
Oct 21, 2009 | Coleman Powermate Powermate 5000W...
9hp briggs and stratton engine has gasoline in the engine oil
Old gas, gone bad from sitting. Drain all gas out and use carb cleaner in unit to clean. Add fresh gas.
Oct 01, 2009 | Coleman Powermate Powermate 5000W...
Coleman 6250 Generator won't turn over
try removing the air filter and try starting if it dirty or to oily , no vacuum is created to pull the fuel into the carb
Jul 30, 2009 | Electrical Supplies
Oil for Coleman Powermate 5000 PM0545305.03
My answer:
First of all - Almost every 4-stroke Genset engine out there should use a minimum 10-30 or else a 10-40 oil blend tops. Best NEVER to use just a straight weight, as in a 30 or 40 weight, as that would be way too "high viscous" at colder temps and could destroy the engine due to overheating at MAX Genset LOADS!
Next - If the Genset is indeed brand new then you need to use the proper fuel in it, as certain mfr's require different fuel blends (such as with certain B&S - Briggs & Stratton - engines), and those engines are set up that way to run on that blend alone. Using the wrong gas blend could damage the engine.
You really need to get a factory Users Manual for your Genset there and read it through thoroughly!
If it has gas in it now (and hasn't run in 3 years?) chances are the whole gas tank, and fuel lines, and Carb as well will need to be cleaned out from contaminated fuel - as there definitely is gum and varnish built up everywhere in those fuel delivery areas esp the most important component - the Carb! Been there - seen that - cleaned that! So I KNOW for FACT.
As for the OIL LEVEL - that is fairly simple - as all you do is unscrew (or in some cases pull out) the dipstick, and check the oil for proper level on the stick as well as cleanness (2 finger test like with car oil), and if it's even black or a silvery color then it definitely needs to be changed out NOW! Refill with fresh oil and your done there.
Check the Air Cleaner for cleanness as well, and service the filter if a foam element, or replace it if a paper element.
If the fuel tank has an in-line fuel line filter and it looks dirty change it out as well. Esp if the gas tank is made out of metal.
Check the spark plug for proper gap, and heat range, and burn color if the Genset has been run already. Should be a nice "light tan" color. If dark and wet - then you have Carb flooding problems.
That about covers it...
Anything else problem wise feel free to ask me here in post follow-up and I'll be glad to answer it for you.
Please post me a reply as to the found problem there, and the resolve to it by following my recommendations above. Also please rate my troubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
Aug 20, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
1,050 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
