Question about George Foreman GRP99 Indoor Grill
FOMREMAN GRILL DOES NOT COME ON
When I plug in my grill and push the power button, no lights come on and the grill does not heat up. This is the second grill of the same model I have owned with the same problem. The first one I returned to AAFES within a week for a replacement. I live in Japan where I work for the U.S. military, and the appliance repair shop here told me they could not fix the grill without parts, but did not tell me what parts. Have you seen this problem in other grills, is there a recall, and can I buy the part(s) needed to repair? Thanks for any assistance you can offer.
  • Anonymous May 07, 2008
    I do have this same problem but the links to salton don't work. Is there a better web site to go to?
  • 944 Answers
These are the guys you need to talk to; http://www.esalton.com/control/contactus it sounds like the control board is fried. easy to fix if you can get one - just swap. Hope this helps :)
Posted on Mar 27, 2007
SOURCE:
Our grill will not light. When the knob is pressed in and turned to 'light' I can see a light inside, but it's like it's not catching and it won't light up. Each burner is doing this....
It sounds like your grill may have a glo plug type of ignition system if there is a light inside the grill instead of a spark to light each burner. If your grill is hard wired to the house elelctrical, it may be that a breaker is tripped and the power is not getting to the glo plug and the grill us using a battery back up to try and light the grill. The batterys do not last long, and when they get weak, the plug will glow, but not hot enough to light the grill. The other possibility is that you have a short, or some other problem, that is preventing enough voltage to reach the glo plug, the plug will glow, but not hot enough to light the grill.
Jul 03, 2011 | KitchenAid KBNU487TSS Gas All-in-One Grill...
The heating element will not heat up.
From Traeger:
Why won't my Grill Ignite?
  1. If your grill is plugged into an electrical outlet with a GFI (ground fault interrupter) plug, chances are the hot rod has absorbed or been exposed to too much moisture and is leaking to ground causing the plug to trip.
  2. Open your cooking chamber lid, remove cooking grill, angled drip pan and U-shaped firepot cover. Is there ash build up in the firepot and/or around the firepot? If so, this needs to be cleaned out. The ash is choking out the fire.
  3. Check the fuse on the back of the control board. To do this, first UNPLUG the grill from the electrical outlet. Then, unscrew the control board and look at the fuse-is it blown or not?
  4. If the fuse is good, check for power by switching the colored plugs first. Unplug the purple plug and the orange plug. Plug the purple plug into the orange plug. Now plug the power cord back into the electrical outlet and turn the grill on. Does the induction fan operate? If so, you will need a new hot rod and fuse. If not, you will need a new control board. Unplug the purple from the orange and reconnect the plugs together to their correct color plug.
  5. Always start your grill on the SMOKE setting.
Jun 26, 2011 | Traeger Industries BBQ070 All-in-One Grill...
I plugged in my new grill and it does not power up. The only thing that works on the grill is the rotisserie. Can you help?
Presumably you have the grill connected to your 120v house power via an extension cord to the electrical box attached on the outside rear of the grill.
And that is where your rotisserie is plugged in, into one of the two available outlets at that same electrical box.
The other outlet is meant for the hood light, which connects via a pigtail from the little transformer inside rear of the grille. (If that connection is made and the light still does not work, check the bulb for burnout.)
Does the ignitor work? You probably already know this from reading the manual, but there is an AA battery which powers the ignitor--not the 120v system. Unscrew the cap on the ignitor button and ensure a new alkaline AA battery is installed correctly, put - (negative) side of battery in first.
Hope this helps!
Apr 04, 2010 | Fiesta Blue Ember Gas Grill
Where does the battery for the igniter go?
In some grills with electronic ignitions, the battery is behind the button that you push in to light the grill. You can unscrew the button and check to see if the battery is behind it. On some grills, the button is nothing more than a button and you have to look for a sepearte battery box on the grill. Some grills have the battery in a box behind the front panel, the button to light the grill is in front of the grill and you have to unscrew the cap to the button to release the battery box from behind the panel.
Dec 20, 2009 | Brinkmann 810-2300-B Grill
Grill ignition is sparking when the oven is on
if the grill is constant sparking when the oven was on and turns off when the oven is not in use then u either have a defective pcb/ht lead or electrode if it is self lighting or if you have to push in a button then this button or control will have a problem
Aug 21, 2009 | New World G70m Gas Double Oven
EOU6330 grill doesn't heat-up all the time.
hi Step 1: Check the power cord, the plug, and the outlet. Then look for blown fuses or tripped circuit breakers at the main entrance panel or at a separate panel.
Step 2: If the range is receiving power, set the timer on the range to the MANUAL position.
Step 3: If the element still doesn't heat, turn off the power to the range and test it with a VOM set to the RX1 scale thank u................
Sep 11, 2008 | Electrolux EOU6330 Electric Double Oven
GRP99
Everything you described is normal, except not heating up.
When you first plug it in, you will see 'dashes' that tell you it is getting power.
When you press the Power Button, the grill will start at the Default Temp of 300F and the Timer starts at 5 minutes. You now change the temp to what you want.
It takes 5 minutes to get your grill to your tempreature, so the timer should 'count-down' as the grill heats up.
As for not heating up, I think you will need to get that 'looked at' for repairs.
Mar 18, 2008 | George Foreman GRP99 Indoor Grill
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
George Foreman GRP99 Indoor Grill Logo
208 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Thomas F. Schneider
Mike
Gerry Harvey
Gerry Harvey
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
