Question about Philips Cell Phones
I have a Philips 60PW9383 rear projection HDTV monitor...the picture won't go on, just happened...no storms or surges etc...is there a fuse that could have blown?
  • davidkch Nov 12, 2008
    this is for a rear projection tv, NOT A CELLPHONE
    how likely is it that a fuse blew out????
    have never had trouble with the set, no surges or storms etc...it just happened!
    I did hear a "pop" moments after I turned on the power, not loud, sounded like a speaker connection noise...would a fuse blowing have a popping sound?
    Genius:
  • 1,550 Answers
Chance of fuse to be blown .
Fuse blows up when there is low voltage or high voltage as input power supply .
Bad solder joints and faulty capacitor can also cause this problem .
Posted on Nov 12, 2008
  • SAM ANDERSON Nov 12, 2008
    Yes at times you get sound when fuse blows up .
    Genius:
  • 1,913 Answers
Check your power supply is good.
also check earthing.
try in other place out side your home.
    Sergeant:
    Novelist:
  • 196 Answers
There could be many problems causing this error. 1) try to unplug the device and replug after 5 minutes.do this 3- 4 times some times this resets the device. 2)may be u r right the fuse could be blwn.as if there is power short circuit the first thing to blow on the power supply board is fuse that blows.as to avoid further damage to the main board. 3)if there is a major short circuit the capacitors or the ics on the board also can be blown. this can be repaired manually but if u have proper technical knowledge .but very risky if done without proper knowledge. call in a tech is much advisable for safety purpose. and this problem is mostly  repairable. thanks.
  • mmechanics Nov 12, 2008
    if the capacitor blows it does that noise.
    get your board checked to locate the exact problem.
    thanks.
    President:
  • 2,712 Answers
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and re-plug to AC power and redo the cabling. Switch on the TV and see if it works..
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key.
4. A circuit board may crack about some of the larger components mounted on it. Try the slap test – Hit the TV firmly on the side. If there is any change in the picture, it could indicate a possible solder problem / connections. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
If all fails, then best get a repairman to come and fix your TV.
  • Swilin Sampson
    Swilin Sampson Nov 12, 2008
    Yes..it could produce the sound. But only a manual inspection can confirm this. You should find the fuse at the bottom right on the back of your TV behind a small panel.
    Genius:
  • 1,847 Answers
Is this a Cellular Phones or projection tv?
  • 1 more comment
  • Legin Varghese
    Legin Varghese Nov 12, 2008
    Yes there is a fuse on the motherboard of the Projection TV.
    This should help you in locating the fuse.
    http://i.ehow.com/images/GlobalPhoto/Art...
    Hope this help
    let me know if you want further assistance...Thanks Kevin
  • Legin Varghese
    check and let me know if the fuse is blown or the issue is internal.
    there could be also problem with the power supply.
    could be also an ic blown off.
    Kindly check the fuse first and let me know the status...thanks ...kevin.
  • Legin Varghese
    no that could be crackling sound from the speakers.
Philips HDtv model 51pw9303/17f: It won't turn on... We think its the fuse too but not sure. Can anyone help?
no not the fuse, the lamp is gone replace it if not check the color wheel u need a tech to do this
Jul 18, 2013 | Philips 51PW9303 51" Rear Projection...
Philips 60PW9383 picture faded. Try to adjust, sharpness, contrast & brightness are all almost all of the way up, but the picture just looks weak & washed out.
Thats the classis sign that the CRT coolant needs replacement to restore the picture quality. You can get the Phillips CRT coolant kit from www.tvrepairworld.com which contains the coolant for the three CRTs plus the CD with instructions.
Jun 19, 2010 | Philips 60PW9383 60" Rear Projection...
I had a power surge last night do to a storm and now my Projection TV won't turn on. Is there a surge protector inside the TV that I can reset or is the TV fried?
there are several fusses in a hitachi located in the power board if your lucky one of them took the hit you can , or have atech look for you the gma type fuse are avail at Radio Shack or your local tv shop
Dec 03, 2009 | Hitachi 57F500 57" Rear Projection...
I have a phillips model # 60pw9383-17f tv.sounds
Sound with no picture on this model is typically the HVG/Flyback.
Sep 04, 2009 | Philips 60PW9383 60" Rear Projection...
My television quit working after a storm, it wasn't even turned on during the storm. the power on the set and remote does nothing. but it makes a sound when plugged in like it is turning on then nothing...
Ok, this was a direct hit in this case and you will defiantly need to replace the power supply board in this unit. the first thing that will happen during a direct hit is, the surge will run threw the power cord and travel threw the entire power supply circuitry, frying all circuits. this includes the main mother board as well. I recommend replacing the mother board and power supply board as well. this will restore your set to its original operational value. The mother board is commonly called the main control board.
please rate and god bless:)
Apr 02, 2009 | JVC HD-52G886 52" Rear Projection HDTV
No Power
Check the fuse on the small board on the far right inside the TV.
Oct 25, 2008 | Philips 60PP9202 60" Rear Projection...
55 philips hd tc projection
The tv no doubt experienced a surge which has caused a problem in the power/deflection circuits. this is better left to an experienced TV tech, unless your skilled with diagnosing electronics with high voltages that are normally present in the deflection circuits. let me know if you need further assistance.
Apr 28, 2008 | Philips 55PW9363 55" Rear Projection...
Philips 46PP9302 46 in. Rear projection -
The power supply section is not working.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- CRT tube has failed overloading the supply
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Jan 22, 2008 | Philips 46PP9302 46" Rear Projection...
VOLUME
Check first to see if n menu speaker are off or then you may have to change audio amp IC. in 7700 location before changing look for blown round black fuse 2A 250V, 1700's
Aug 07, 2007 | Philips 60PP9202 60" Rear Projection...
Cell Phones Logo
116 people viewed this question
Top Philips Cell Phones Experts
Jack Frost
Vladimir Frolov
Tom Chichester
Are you a Philips Cell Phone Expert? Answer questions, earn points and help others
