Question about Kenwood KDC-716S CD Player
KDC.716S Mech error issue
The other night my car completly shut off due to the battery cables losing connection. I got the connection back and when I started my car back up the stero will not eject a cd, the fm radio works but when I try to get the face to move at all with the open button or by turning it off it doesnt even turn. After pushing the eject button 3 times I got a mech error message. What do I do?
  • scion12 Jun 07, 2008
    i tried to eject the cds a few times. I tryed loading another cd in another slot
Try the tiny reset button on the front just below the volume down button.
Posted on May 22, 2007
SOURCE:
My radio/ 6 disc CD player.
Both. Check the power line that is supposed to power the clock and memory circuits when you turn off the ignition.
And your player has lost the ability of the laser to focus on the disc - hence the error message.
Sep 09, 2016 | 2009 Hyundai Sonata Limited
My saturn sc1 lights and radio would flicker when pressing the brakes, sometimes it would shut off when pressing the brakes in reverse, now it will not turn completely over or hold a charge in the bat
corrosion on you battery terminal will create high resistance.inspect the battery connectors and wire. if you find white/blue crystals on you terminal disconnect and clean. the battery cable must be gold/light brown.If the wire are black/blue that mean is burn from bad(lose) connection to the terminal and need replacement.Inspect all ground connection betvin battery and body for corrosion or lose
Mar 23, 2014 | 1998 Saturn SC
My 1998 delta 88 died again today. While driving it just shut down completely. No battery power no nothing. After having it towed it started like nothing was wrong an hour or so later. Have had the pr
Battery connections good , battery ground cable connection on the frame an engine clean an tight ? No corrosion . I wouldn't look for any ground issues under your seat . No power , main cable problem , to starter etc...
Feb 23, 2018 | 1998 Oldsmobile 88
Kenwood Kdc-mp425 will not switch to Aux. Aux cable is connected to the back of the headunit, but no aux option is available on menu for either my ipod touch or my sirius unit. I've accessed the menu from...
Apparently, this auxiliary input only works for a Kenwood CD changer or a sirius radio connection. At least that is my conclusion after finding the same problem. Let me know if you figured anything out on this.
Jun 02, 2010 | Kenwood Sirius KDC-MP425 CD Player
Kenwood KDC-716S
FLEX CABLE has been worn out, its thirty bucks and easy to install.
Oct 02, 2008 | Kenwood KDC-716S CD Player
Kenwood kdc-716s
firstly you should remove the power from the unit for a few seconds to reset it. if this doesn't fix it you can remove the top lid and you will see the motor that rotates the fascia, if you unplug the flexible cable that powers the motor and put 6volts on the motor contacts till the fascia rotates and then plug the flexible cable back put the fascia back on and plug the power lead back on to the radio
Nov 24, 2007 | Kenwood KDC-716S CD Player
Will power up,will hide, will open on igntion start
yup.. needs a new face plate ribbon cable.. just like mine :-(
Sep 24, 2007 | Kenwood KDC-716S CD Player
Kenwood KDC-716S CD Player Logo
208 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
