Question about Westinghouse LCM-19v1 Monitor
Westinghouse LCM-19V7 powers on, but picture only stays for a sec
When I plug in the DVI cable the picture stays for a second or two then goes away, and the power light eventually turns to red and I get a "No signal Input" message.
When I plug in the regular VGA cable, I get the same second or two picture, but the power light stays green.
I just bought this monitor "as-is" on ebay and of course it is not truely "as-is". I have 2 others just like it and was hoping for a 3rd match.
Any suggestions?
  • 8 more comments
  • Anonymous Nov 24, 2008
    I have the same problem. I turn on the monitor and see a weak image for about a second and then it goes black.
  • gwinter9 Nov 24, 2008
    I have the exact same problem.
  • maintenance2 Dec 12, 2008
    same thing happens to me
  • hdb3 Dec 22, 2008
    I have the same monitor and it displays the same symptoms, have not found a fix yet but have emailed Westinghouse tonight.
  • manningba Dec 30, 2008
    Same problem here. Bought mine at Best Buy a year and a half ago. It started this last night, but corrected itself for a day. Now it won't stop..
  • Ross Anderson
    Ross Anderson Jan 22, 2009
    Same problem.No way can it be the video card/motherboard/cables.I have had this for 2 yrs. also from Bestbuy.Have new PC.Now I have to rely on my 17" Philips crt which I have had for about 8 yrs now.Really ticked.
  • jtom617 Feb 05, 2009
    Thanks i have this same problem and ordered the 5 capacitors that are required, i opened this thing up, and its clearly the caps. As far as unsoldering them, EASY! Put some more solder on the two points, then heat one side up at a time and dance the capacitor so it slowly wiggles out, just go back and forth the on the leads. as far as the excess solder left over, it helps to have desoldering braid, etc also found at radioshack! :)
  • Anonymous Feb 12, 2009
    I had the same problem with my LCM-19V7.I did what paseante said and got new capacitors and my monitor came back to life.
    Thanks ALOT paseante your advice was right on the money
  • Anonymous May 02, 2009
    I had the same problem, replaced the 5 caps and good as new. Thank you to person that originally gave advice, it was great advice and prevented me from purchasing new monitor
  • Ellen Wuest Aug 30, 2013
    i have no image, just black and flahes or blinks . is it the transformer?
Most likely the capacitors on the power board have failed. I had the same problem and replaced (2) 1000 mfd/25 volt and (3) 220 mfd/25volt capacitors. Problem fixed! I used Radio Shack #272-1032 and #272-1029 capacitors.
Posted on Jan 24, 2009
WHAT ABOUT R100 DO ANYONE KNOWS THE VALUE
Posted on Mar 30, 2010
There might be a problem with the main board, which you can buy a replacement on EBay for ~$85 "Buy it now" from an EBay store. It would probably be a little tough to do if you aren't good at these sort of things. But, it's worth spending $85 and using a little more time, then $200 + for a new one. I would try and set up the TV from the menu first however, or check your computer's graphics settings depending on what is plugged in. Your computer might be displaying at too high of a frequency or too high of a resolution (max supported res. is 1440 x 900 for this model). Good luck
Posted on Nov 15, 2008
Buy a sony
Posted on Jun 15, 2010
2 Suggested Answers
SOURCE: Westinghouse LCM-19V7 powers on, but picture only stays for a sec
It's probably bad capacitors on the power supply board. These monitors are notorious for having the electrolytic capacitors blow out; cheap components! I would suggest replacing the two 1000 mfd capacitors and the three 220 mfd capacitors with 35 volt components from Radio Shack. That fixed one of my LCM-19V7s but not a second one which seems to have some other power supply problem.
Posted on Apr 11, 2009
I have a Westinghouse LCM 19v7 monitor that stays on for a few seconds and picture goes off. I know about the capasitor replacement but there is another conponent that I need to replace. It is the pow
That is the correct value. That resistor just gets very hot and discolors the PC board around where it is soldered. You should be able to remove all of the old solder and scrape the resistor leg to get it bright, resolder the leg to the copper pad and you should be good to go.
Oct 09, 2012 | Westinghouse LCM-19v1 Monitor
My monitor Westinghouse Mod# LCM-19v5
The most common thing that causes no power or a blinking power light and no picture is a failure of the power supply board. The board can be repaired and the monitor will be as good as new. To repair the board you just need to replace a few parts called capacitors. Here is a link to repair information on the Westinghouse LCM-19V5
http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-19v5/
I hope this helps, if so please rate my solution.
Oct 21, 2011 | Westinghouse LCM-19v5 Monitor
I have Westinghouse LCM19v7 monitor that goes blank after a second or two. I have read it might be a capacitor. Where would I find a web page, link, that could show me what and where it is? Many...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=182f4dc3ec4e86ae58424f1254f6cc10&modelid=278990&q=Westinghouse+LCM-19v7
also you can buy the repair kits on Ebay
Repair Kit, Westinghouse LCM-19v7, LCD Monitor, Caps
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230554161161&ssPageName=STRK:MEWAX:IT
$13.95 +$7.59 postage worldwide
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
Jun 11, 2011 | Computers & Internet
At power up, screen flashes DVI, then screen displays "check source and connection" green light is lit for about 10 seconds and then monitor powers off.
Check the DVI cable and all the pins, try it with another PC to make sure you are not having the video card problem, also try using VGA port to see if it has the same problem. Post back what you find.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 14, 2010 | Westinghouse Electric LCM-22W2 Monitor
No image on monitor model LCM- 19v7
Look for bad capacitors (bulging top/seal) in the power supply first, post back what you see inside so we can guide you further, see example of failed Westinghouse monitors due to bad caps; http://s807.photobucket.com/home/budm/allalbums
Mar 13, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
Need power cable for a westinghouse LCM-19v1 SL monitor
We carry the power cords for this model at our web site at:
www.ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Oct 17, 2009 | Westinghouse LCM-19v1 Monitor
Lcm-19v7 westinghouse lcd monitor
Yes, The problem is bad caps on the power supply board. We are working on the repair guide and it should be up on our web site by tomorrow night ( 08/19/09 ) check it out at:
www.ccl-la.com/badcaps.htm We will have parts list and pictures showing what needs to be done.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Aug 18, 2009 | Computers & Internet
Mar 24, 2009 | Westinghouse Computers & Internet
Westinghouse LCM22w2 monitor need cord to pc
You need either a standard VGA cable or a DVI cable, depending on the type of video card you have.
http://www.ctcco.com for professional hosting solutions
Jan 19, 2009 | Westinghouse LCM-22w2 Television
Screen works for awhile but then goes blank.
if u have a problem wih your Westinghouse Monitor LCM-17V8 email me for solution or if you want to dispose of it; email me at
ekwhoward@yahoo.com.
Thanks
Ekow
Nov 04, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
Westinghouse LCM-19v1 Monitor Logo
2,695 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
