Question about IBM ThinkPad A21m 2628 Notebook
Network card got ibm tinkpad worke except i cant get the cat5 port to work, looking in device maneger ther are no net work card showing
  • esassu Dec 02, 2008
    I have the same problem. I tried to download several network drives for the A21m and none works. It seem network card is Intel's brand acordding IBM information web page. Cuold anybody help me? Thank you so much!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
Look in the mini-pci slot on the back of your computer (1 screw opens the compartment) and make sure you have the 10/100 ethernet & 56k combo modem & that both plugs are firmly seated in their ports on the mini-pci card.
sometimes there is just a 56k modem card installed, in which case you will not have ethernet high speed internet capability.
Easy to tell which mini-pci card you have.
1. The ethernet/modem combo has two ports on the card (wide for ethernet & skinny for modem) to connect to the corresponding two wires coming from the motherboard.
2.The modem alone one only has one skinny port available on the card .
Posted on Mar 03, 2009
  • IBM Master
  • 32,281 Answers
Yuo need to install a driver for your network card. Go to the IBM WEB site to download a network driver for your particular model ThinkPad.
Posted on Nov 12, 2008
Problems connecting my dell computer to the internet dell inspiron 1720
plug in the ethernet cable or cat5 into laptop. then go to the keyboard and click on the windows key. go to computer then with the right mouse botton click it. select manage. in the new menu. select manege devices. look for the wifi. remove it. refresh. it will remove it. reboot pc. it will reinstall new driver for the wifi. if it does not work. wifi card is busted. on my own experience it was the wifi card no good. good luck
Jul 09, 2014 | Acer Aspire 4520-5582 Notebook
Amber light is flashing on network card
Switch off the printer, re connect the net work cable, switch on the machine & wait till ready mode comes.. Go to administration on control panel, select configure device,select configuration page, print,, total three print out will come, in that see the IP address.. If any IP address showing, ping that IP from system, if its pings, reload the drivers once again.. check for the print. If no IP adress showing in configuration page, try with another net work cable & try above said exercise.. Even no luck, remove formatter from the slot & re-fix once again & try... Even no luck.. it might be network port faulty. If its warranty contact HP support for free replacement.. If no warranty purchase HP620n or higher version of zetdirect card(net work card) install it... But take service engineers suggestion before replacing the network card..
Aug 01, 2012 | HP LaserJet M4345 MultiFunction Printer
I bought 1 box of belden cat5e for LAN. when i test it with LAN tester the cables are good but when i connect it to the modem/hub it is not connecting.. please help me.. thanks..
If you've tested the cable and your not getting a link light, there is a posibility that either the port in the switch or the network card is bad.You can try moving the cable to an existing working port on the switch to see if it links up. If not then try another device like a laptop or printer with a NIC card on the cable
Sep 07, 2010 | Belden CAT5e Plenum 4Pair...
I FORMATTED MY MACHIN BUT NOW I DIDN'T GET THE NETWORK DRIVER
if it's a genuine IBM computer, give their support line a ring and ask.
You can also visit their website and in the Support section, have a look for the network driver for your particular computer model.
What model is your IBM computer?
In system properties, can you click update driver for the network card?
To get here click on Windows Start (bottom left of your screen), then select Run, then type in the box this: sysdm.cpl then hit OK. Then select Hardware tab, then Device Manager. Scroll down to your Network Card which will probably have a Yellow exclamation mark next to it. Double click on the network card, then Select Driver and then Update Driver.
If you are on the net at the time Windows should search the web for the right network driver.
Cheers,
Steve
Jun 10, 2010 | Intel Motherboard
Not recognizing networks after water damage
Sorry old chap.  Looks like your wireless ic chip is fried.  Open this thing up and replace with a new one.
Cheers
Nov 21, 2009 | Acer Aspire 5500 5570-2609 Laptop
Lan port not working , tried all normal options
try to re-install you network driver.
go to control panel, system maintenance, device manager. uninstall the previous driver downloaded on your machine then boot up machine. once done, install your network driver.
Jul 01, 2009 | IBM ThinkPad T30 2366 Notebook
Vga driver
i can find my vga dirvers
Oct 17, 2008 | Vga (CAT5-1000S/R) (EXTCAT51000)
IBM ThinkPad T20
Wow, a lot of information but I'm unclear as to what you are trying to do.
Are you connecting the T20 directly to the T40 using a cat5 cable and then trying to access the internet on the T20 via the modem?
Connecting the two computer together using a normal cat5 will not work, you need to use a crossover cable otherwise you are connecting the send to the send and the receive to the receive.
You can also use a hub, a switch or a router if you have any of those on hand.
As for the modem, I suggest you unplug the telephone line from the modem and plug it into a phone and see if you can hear a dial tone. If you cannot hear a tone either the extension is bad (replace) or you outlet is defective. If you can hear a tone, the modem card may be defective.
Oct 08, 2008 | IBM Thinkpad T20 Notebook
T22-2647-M2U Internal Network Card not showing
Is this the wireless card or the ethernet controller when you say internal network card? I want to be sure before I give you the wrong info.
Aug 29, 2008 | IBM ThinkPad T22 2647 Notebook
The ethernet port is not working, and the network card is not being detected in device manager
If the device manager is not detecting the network device it is not going to work. turn off the laptop and remove the network/modem device located on the bottom of the laptop, then restart the laptop, now shutdown the laptop again and reinstall the device restart the laptop if device manager still does not detect the device then it is defective and will need to be replaced.
BPCS
Nov 30, 2007 | IBM ThinkPad T21 Notebook
IBM ThinkPad A21m 2628 Notebook Logo
285 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
