Question about Frigidaire ATF6000ES Front Load Washer
Door latch replacement
How do I change the locking assembly ie: taking the front off,do I do it from the back etc?
    Genius:
  • 1,028 Answers
Remove spring from around front of door seal roll seal away from door frame remove the 2 screws holding lock assembly to frame pull latch toward opening unplug the wires reinstall in reverse..reinstalling spring on door seal will be hardest part but not too bad
Posted on Nov 12, 2008
Oven door on gas range won't open. Apparently the "clean" cycle was initiated and locked the door and now won't open. Also didn't clean. The range is 4 burner about 25yrs old. I do...
Hello & Welcome to FixYa
This is a common problem that occurs when self-clean cycle is used after a long time or when the oven gets old. Recommended repair is replacing the door latch-lock assembly as the latch mechanism cannot be repaired. Please get back to me if you have any other questions.
Kevin
Jul 18, 2011 | Magic Chef CGR3742 Gas Kitchen Range
Washer door latch
Unplug your machine, remove the top panel, doublecheck all of the wiring is securley connected. Sometimes the wiring becomes loose due to the machine's vibration.
Jun 24, 2008 | LG WM-1832C Front Load Washer
HE3 no error codes, will not start when button is pushed. All mode lights are on push any wash cycle and no go. Checked water lines, drain line, no obstructions. When you push the wash cycle button it...
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel. Pull the door lock/latch assembly out of the washer and disconnect the wiring harnesses.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel. the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Feb 26, 2011 | Kenmore HE3T Washer
WE have Kenmore elite He3t Model Nol. 42926 203. We get an error code dL F. How do we correct this?
It is a door lock failure and it flashes after the door locking routine fails to lock the door after 6 attempts. Replace the door lock/latch assembly (part number 8182634) to solve the problem.
Jan 07, 2011 | Kenmore Elite 45986 Front Load Washer
My door lock has locked with the door open , how do i get it to unlock ?
There is a manual unlocking tab located at the bottom of the door lock and switch assembly. Disconnect power to the washer before accessing it.
Remove the three screws attaching the toe panel to the cabinet then pull the panel down and off the cabinet. Prop up the bottom front edge of the washer or cushion and lean it against the wall for an easy access of the screws.
Reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side.
Locate the tear-drop shaped tab then gently pull it down until a click is heard, and then open the door.
The door lock and switch assembly may need to be replaced if the problem persists. Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening.
Pull the door lock/latch assembly out of the washer and disconnect the wiring harness.
Secure the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Jul 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet washer will not start. I keep getting a "dl" and an "f" signal. I assume it means door lock failure. I've tried unplugging and opening and shutting the door before restarting but it won't...
It is indeed a door lock failure. Replace the door lock/latch assembly (part number 8181700) to solve the problem.
Mar 01, 2010 | Washing Machines
Trying to remove door latch on 1995 thunderbird. Car has power locks.
inside or outside latch? please rate
Section 01-14A: Handles, Locks, Latches and Mechanisms 1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION Latch, Door Removal and Installation
  1. Remove front door trim panel (23942) and watershield from front door (20124). Refer to Section 01-05 .
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812) . The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) , if so equipped. Remove the front door latch from the front door .
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch .
  1. Remove front door latch remote control link , front door latch control cylinder rods , and door open warning lamp switches from front door latch , where applicable.
  1. To install, reverse Removal procedure. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Part Number Description 1 21852 Front Door Latch Push Button Rod 2 21940 Front Door Latch Remote Control Link 3 386656-S Bushing 4 21978 Door Latch Shield 5 218A42 Power Door Lock Actuator 6 22134 Front Door Latch Control Cylinder Rod 7 21812 Front Door Latch
Remote Control Assembly Door Latch
  1. Remove front door trim panel (23942) and watershield. Refer to Section 01-05 .
  1. Remove screw and washer assembly retaining front door latch remote control and link (21818) to front door (20124) .
  1. Rotate front door latch remote control and link to remove from front door latch remote control link (21940) .
Sep 27, 2009 | 1995 Ford Thunderbird
Front door buzzing Frigidaire front loading washer
replace entire door lock assembly ..remove spring holding the door boot in place and roll boot back ..unless you have the one where the seal is glued then carefully slide knife under edge to cut through glue take the screws from lock and pull through opening remove wires and install new lock ..if noise is only issue use till it blows then replace
Jul 30, 2008 | Frigidaire FWT449
Door lock
The MAH5500B Neptune does not have the door latch wax motor so you won't have the R11 resistor burnt...
With that said.. Maytag made the door latch assemby one complete assembly meaning that you cannot replace the micro switches, solenoid, etc. On the older door latch assemblies Maytag broke it down to all of the little parts, ie. 12002535 wax motor, etc. I imagine that this was to reduce the part numbers folks would have to store in inventory...
You stated that the door is not locking? Did you pull on it to verify this? or could the door lock indication be not working?
There are 2 microswitches in the door latch assembly, one lights the door locked light and the second actually tells the control board that the door is locked. It is possible that the door is locked but the door locked light does not come on...
It more than likely could be three things.. The door latch assembly, wiring or control board. I would take Neptune apart so you can have access to the door latch asembly See www.neptunewaxmotor.com for step by step photos. Put a volt meter on the solenoid wires and see if you get 120VAC when the door should be locked. If so, then the solenoid coil is probably opened up and you will have the replace the door latch assembly. If 120 VAC is absent then I would check the wiring from the door latch assembly to the control board with an ohmmeter (unplug Neptune to be safe while using ohmmeter) If wire continuity is good then I would suspect the machine control board.
Jul 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
How to replace door lock
FACE DOOR DOWN ON A TABLE GLASS UP, REMOVE ANY SCREWS. IE. TWO].USE FLAT SCREW DRIVERS TO PRISE APART THE TWO PLASTIC SECTIONS, LIKE TAKING TIRE OFF BICYCLE, IT SHOULD BE EASEY TO FIT CATCH THEN. GET BACK IF YOU HAVE PROBLEM. CLOSE IRE GOOD LUCK, TOP OF THE MORNING TO YOU
Nov 08, 2007 | Zanussi WJS1397W Front Load Washer / Dryer
Frigidaire ATF6000ES Front Load Washer Logo
197 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
