Black screen- cannot view pictures, can hear sound
By mistake I clicked on progressive scan from menu > video. The screen is all black since then and I can only hear sound, cannot view any picture except for VIDEO on left top corner of my screen. Please advise. I have the Philips DVDR600RV and have the same problem. I go tinto progressive scan mode by accident and cannot hear or see picture
  • 7 more comments
  • stuart483 Nov 13, 2008
    I have tried unplugging the unit, plus the TV. I have unhooked all the componets and then plugged it all back in. I have tried hitting the 1 key and it still gives me a black screen and no sound. I hit the menu and it will not come up. this is a DVD/VCR combo and it will not allow me to go to the VCR. Any other ideas
    Tried a new cable and still no screen
    Tried pushing the power button same result. Might need to figure out how to do a factory reset
    Tried hitting the stop for ten seconds still did not work
  • stuart483 Nov 15, 2008
    model Phillips DVDR600VR combo DVD/VHS Player/ recorder Checked to see if there was a switch on front or back no luck. Left unit unplugged for two days no change
    I would love to go to the menu screen but I have a black screen and cannot see it
    I will take it to the repair shop
    Thanks
  • stuart483 Nov 16, 2008
    Thought this might be of help to others, here is the solution direct from Phillips and it worked
    1. Disconnect the power cord from the power
    supply.
    2 While holding down the D.DUBBING button
    on the front panel, connect the power cord to
    the power supply.The current time will appear
    on the display panel. Continue to hold the
    D.DUBBING button for 15 seconds and press
    STANDBY ON y button on the front panel.
    The display screen will show PHILIPS and
    READING CO2.
    President:
  • 2,712 Answers
Ok, looks like there is a component level issue here. the best bet would be to seek the services of a repairman..
Posted on Nov 15, 2008
    Sergeant:
    Champion:
  • 283 Answers
Your problem is just a settings of your TV and DVRs. Dont replace it part of it.
- Go to menu then click again the progressive scan if doesnt work try to fing restore factory settiing then switch off then turn on again.
Thank you. plz dont rate me if you are not satisfied. tnx......
Posted on Nov 13, 2008
    Brigadier General:
  • 6,966 Answers
Initially, try the unplug for an extended period of time, say an hour or even more. Additionally, postback the brand/model number, visually inspect the front panel controls and/or the rear of the DVD/VCR combo for a possible hard switch or button for the PScan, PS or Progressive Scan Mode.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • 19,396 Answers
Turn the unit on, until you see the "progressive scan" screen. Hold down the "stop" button for 10 seconds and the unit should reset to standard DVD play.
Let me know how it goes.
  • 1 more comment
  • Ginko
    Ginko Nov 13, 2008
    You do not push power button, you do the following:
    Click here and follow istructions: Removing parental lock on RCA and GE TV...
    Can you read my comments?
    answer please.
  • Ginko
    Ginko Nov 13, 2008
    Sorry, missing link, here you get the instructions from techman,
    I quote:
    "Most RCA and GE TV sets use a four digit code to control the v-chip.
    The code reset procedure is different depending on the model. Try each
    method until you find one that works:
    Hold down MENU on the
    remote and VOLUME DOWN on the TV it?s self at the same time for at
    least 4 seconds. The set won't say so, but the lock will be unlocked
    Hold
    down the 0 on the remote and the VOLUME DOWN buttons on the TV its self
    at the same time for at least 4 seconds. The set won't say so, but the
    Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
    Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
    Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
    Depending
    on the model, one of the methods should unlock the V-chip. Now, if
    desired, you can change the settings on the V-chip by going to the MENU
    and going to PARENTAL CONTROLS, or on some sets, going to MENU and then
    going to TV SETUP, then to V-CHIP SET."
  • Ginko
    Ginko Nov 15, 2008
    You just do not push the power button, follow instructions below thoroughtly:
    Hold
    Depending
    Genius:
  • 1,913 Answers
Press powr button for 1o seconds to reset it.
    Master:
    Sergeant:
  • 449 Answers
Hi!!
did you try to replaced the AV cable
    Scholar:
  • 112 Answers
The tv just needs reset. Unplugg it for a while if it comes back on with the same problem, try longer.
Posted on Nov 12, 2008
    Genius:
  • 1,847 Answers
Unplug the tv and and pluge back and check if that works.
  • Legin Varghese
    Legin Varghese Nov 12, 2008
    You need to reset the unit to factory settings. Try pushing each button on the unit for about 10 seconds. Specially check the stop button for a while.
    hope this will help
    Thanks
    Kevin
  • Legin Varghese
    HOWEVER, I believe on this unit, the progressive scan comes only when
    you connect to the outputs for component video and it gives you
    progressive scan automatically. If you don't want progressive scan,
    move the cables over to the video composite output.
    Sergeant:
    Novelist:
  • 196 Answers
Remove all the connections and hold for five minutes then replug it again and check.
  • 1 more comment
  • mmechanics Nov 12, 2008
    Accidentally switching to PAL and getting a rolling black & white picture happens all the time to baffle users, especially on models with a System or P/N key on the remote. To get back your color and sound just switch to the proper system in the menu or put in a movie of the correct type and it can switch automatically or try the procedure below for resetting to the defaults.
    Sometimes owners will accidentally switch to Progressive Scan in the menu then get no picture at all. You can fix the no picture condition on the CH-300 by resetting the defaults to interlaced as mentioned in the users manual:
    "To reset the VIDEO OUTPUT, turn Off the player, turn back On,  open the disc tray and press and hold the Stop button on the player for 10 seconds to reset the scan mode."
    The Reset procedure doesn't seem to work on all versions but you can sometimes get a usable B&W picture allowing you to get to the menu and change the settings by connecting the composite video input of your display to the Red Pr/Cr or Green Y component output jacks on the rear of the cabinet.
    You can also go into the Menu and set it blind with the following key presses on the Remote:
    1. With the unit Stopped, press Setup.
    2. Press Enter.
    3. Press the Down Arrow 3 times.
    4. Press the Right Arrow Once.
    5. Press Enter.
    On 300Z & 300ZS models if the video is set to Progressive Scan and you can't get a viewable picture on the Red or Green jacks try going into the Menu blind and changing it back with the following key presses on the Remote:
    1. With the unit stopped, press Setup on the remote.
    2. Press the Right Arrow Once.
    3. Press Enter.
    4. Press the Down Arrow 2 times.
    5. Press Enter.
    6. Press the Up Arrow 2 Times.
    7. Press Enter. This should switch it back to Interlaced scan with S-Video and Composite output.
    To change the Parental Control setting on the CH-300 use the factory password of 3351.  For the CH-400 use 1379.
HI i put my DVD on progressive scan by mistake ... i try to press on STOP for 5 seconds ...but nothing change ...i have sound but no picture ??
Try getting the Green component output and put it on the Yellow composite input. Your picture should be black and white. Then you can see the video to change the resolution back to where you need it. Hope this helps.
May 29, 2011 | Zenith Televison & Video
PROGRESSIVE LIGHT WAS SET BY MISTAKE, AND IT HAS BEEN SET ON AUTO HOW CAN I SOLVE THIS PROBLEM BECAUSE THERE'S ONLY A BLACK SCREEN AND SOUNDS THAT COMES ON.
According to the operating instructions (page 97), Progressive Scan can be cancelled (or turned off) by pressing and holding PAUSE (on the main unit) continuously for 5 - 10 seconds, until the progressive indicator goes out, or turning it off in the setup menu. Your recorder should now be back to normal interlace video output. I recommend that you check your setup menu after this procedure to make sure nothing 'AUTO' is set, that shouldn't be set, and subsequently turning off any function that isn't required.
Apr 30, 2011 | Sony RDR-VX515 DVD Recorder/VCR
Screen has black line down the middle.
it sounds like a setting in the progressive scan or screen ratio menu.
May 04, 2009 | Video Game Consoles & Games
Cant turn off progressive scan
Press OPEN/CLOSE on the DVD player
to open the disc tray.
Press numeric keypad ‘1’ on the
remote control for few seconds.
➜ The DVD blue background screen
will appear on the TV.
Aug 24, 2008 | Philips DVD 622 DVD Player
Cant see ps3 main menu
when in standby hold down the power button for over 4 seconds, it runs the optimal screen settings menu, hope this helps.
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
DVD player wont show picture
to turn it off select connection method 3 above and progressive scanning mode, to set the mode, set progressive to off in the display menu so that the p scan indicator light on the front panel goes out. do all of this in interface mode. you can also do this by pressing and holding PLAY > on the front of the unit for more than 5 seconds, still watch for the p scan indicator to go off. this works best when the unit is connected directly to the television.
Dec 04, 2007 | GoVideo Go Video DVD/VCR Combo
How do you take progressive scan off
eject the tray and press the stop button for 5 - 10 seconds...if not stop then try pause button
Nov 17, 2007 | TruTech TT320
ok do one thing,connoet rca video pin in component socket.. so that you can see bblack n white picture.
Aug 06, 2007 | Philips DVD 622 DVD Player
Televison & Video Logo
90 people viewed this question
Top Televison & Video Experts
