Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
My MacBook will not boot up
The white screen will appear, but the apple logo never shows up. It just sits there with the white screen, and my main screen never loads. after waiting a while, a folder logo where the usual apple logo is, appears with a question mark on it.
  • 1,913 Answers
Go to bios setup load optimal defaults.
then save.
Posted on Nov 12, 2008
Video issue macbookpro 2006
startup and regular sound White screen appears but no apple logo appear ,
1) smc have been reset multiple times. possible motherboard video hardware issue cause over heating.
2) hold option key switch on laptop it will be see hard disk or DVD drive (apple disk inside) icon, the motherboard good if icon appeared. and the motherboard video dead if not appear. hope to help a little
Jan 02, 2014 | Apple MacBook Pro with 17" Display
My macbook white fell on the floor and now I only get the apple logo with spinning wheel and time bar. I have waited more then 15 minutes but no changes. I do not have the disk. I have tired safe boot,...
The time bar may be telling you that there's damage to the hard drive, or perhaps just your hard drive's main partition.
If your Mac is running OS X Lion or Mountain Lion, you should have a recovery partition with Disk Utility on it. Restart your Mac while holding down Command-R to boot into this instead of your regular partition. Follow Apple's instructions on how to use Disk Utility to see whether the hard drive is damaged or just corrupted (and potentially corrupted).
Sep 06, 2013 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple macbook air won't turn on
Does the Apple logo or the Pinwheel show on the screen?
There is a problem with you OSX installation. Please boot from the Recovery partition (hold Cmd+R during the startup chime), and use Startup Disk to choose the correct hard drive to boot from.
You can also restore from a backup, and not lose your data here as well.
Oct 28, 2012 | Apple MacBook Air
Macbook pro problem
Put the installation cd in your drive, and boot while holding down the C key
then open up "Disk Utility", and choose repair permissions
Oct 17, 2012 | Apple MacBook Pro MB991LL/A 13.3-Inch...
I have a macbook air, and i turned it on today and the white screen appeared on the screen with the apple logo, then the wheel started spinning for hours and it doesnt turn on, i wonder how can i fix it?...
Find you apple install CD's and choose the one that says application install. as you turn in on try and put the CD in and hold down the D key this should run the disk before start up and allow you to run a hardware check.
Aug 14, 2011 | Apple MacBook Air
The white screen will appear, but the apple logo never shows up. It just sits there with the white screen, and my main screen never loads. after waiting a while, a folder logo where the usual apple logo...
You will need to put in the Mac install DVD, once that loads up on your computer on the main bar go to utilities and then disk utility. from there click repair disk. If this fails you will have to reformat your disk and install a clean version of Mac.
Feb 05, 2011 | Apple MacBook Pro Laptop Computer with...
Boots up but shuts down before opening ?
The software on the hard drive is not loading correctly and is giving the command to shut down. Reinstalling the OS should clear that up.
May 26, 2010 | Apple MacBook Mac Notebook
I do not have a startup disc ,how can i start my macbook.i tried all the key combinations for intel-base mac. only the apple logo and rotating don,t know what appear on screen.please help.
does it have ram inside. safe boot is a must. it took me 5hours to hack g4ibook 4 my 1rst time fscky aka command line. or on your other mac do superduper app.
Apr 20, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Bios setup for MacBook?
Command Button(the one with the apple logo) + Option + F + 0 when it boots
Nov 12, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
If you get the Apple logo with spinning lines underneath it but not getting past this stage then the hard disc is being seen but something is failing in the boot process, causing it to stall.
Most likely this is a case of incorrect file permissions which is easily solved.
There are 2 ways of doing it, depending on whether you have an OS X install disc to hand or not.
Insert the disc into the DVD drive, power on the Mac on after hearing the chime hold down the C key. This forces the Mac to boot from the DVD. After a few minutes you'll get a screen asking which language you wish to use as the main language; select English or whichever is appropriate for you.
On the next screen the Installer box will appear. Ignore this and instead on the menu at the top of the screen select Utilities -> Disc Utility. Once this has loaded select your hard drive on the left hand pane and then first click "Repair Disc" and once that has finished click "Repair Permissions".
Once these have completed successfully reboot and OS X should load up fine.
This is a bit more tricky. You have to boot into single user mode. To do this power on the machine, and after the chime hold down Cmd (Apple key) and S together. The screen will turn black and an a load of white text will start appearing and scrolling upward as the system loads. Basically this is what happens behind the Apple startup logo, only in single user mode rather than multiple user mode.
After a few moments the text should stop scrolling and you should see a prompt which looks similar to:
localhost: / root#:
Note that localhost is the name of your computer so will possibly be different to "localhost". At this point type the following EXACTLY including spaces, capitalisation and dashes etc:
/sbin/fsck -fy
now press enter, then type:
/sbin/mount -uw /
now press enter then type:
diskutil repairPermissions /
and press enter. It may take a few minutes to repair the disc's permissions, but once complete you should have the
localhost: / root#:
prompt again. Now type:
and hit enter. The system will then reboot and should boot into OS X without issue.
Sep 12, 2008 | Apple MacBook Mac Notebook
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
970 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
