Question about Goodman GMS90703BXA Heater
Electronic ignition is not working on my goodman heater
On the control panel, the red light is flashing 4 times. "Open high limit" what does this mean?
  • Anonymous Dec 15, 2008
    my goodman furnace does not ignite no mater the lectric sistem looks working well
  • icedextreme Dec 21, 2008
    My furnace diagnostics light is also blinking four times. I realize it is high limit switch. Is this something I can tackle myself? I have tried contacting my heat and air guy, but it seems as if he is not wanting to answer his phone.
  • 96 Answers
It means the high limit switch is staying open , it is there to keep the unit from over heating. it have went bad , it is the small square peice with two wires going to it on the heat exchanger could be black or brown
Posted on Nov 13, 2008
My Goodman furnance blowing cold air.I have 4 LED flashing lights
Reset the power to see if the furnace tries to light. If it tries & fails, it is an ignition issue ie hot surface igniter, dirty flame sensor. If the LED's still are lit up, it is most likely a limit that is open.
Mar 20, 2015 | Goodman Heating & Cooling
1993 goodman status light 4 times blinking
Witch blower is running, the inducer or the systems blower?
System blower could mean the the high limit is opening and shutting down the systems gas train, I would check this out first.
The other problem could be with the pressure switch for the gas train, it is supplied from the inducer motor, check to see if it is operating fully.
HSI boards do go from time to time, this sounds more like a system control problem.
Jan 24, 2008 | Goodman GMS90703BXA Heater
Goodman # GMS81155CNA light blinks 4 times - furnance won't light and blower runs all the time - it's cold - please help
The 4 blinks means that the high limit switch or the regular limit switch are tripped... try to find the high limit switch... it is usually near the blower...there will be a red reset button in the center of it... push it in and the unit should work again...
if the regular limit switch is kicked you may have to replace it for the unit to work again...
This often happens after a power failure if the unit was running at the time of the failure. If you did not have a power failure, then find out why the limit switch kick out...
Here is a tip that will help you try to figure out why yourfurnace is not working.
BasicFurnace or Heating System Troubleshooting
heatman101
Apr 23, 2011 | Goodman GDS81155CNA Open Flame Mid-Size...
Service indicator light flashes 4 times. High limit switch?
There should be a diagnostic chart on the reverse side of the front panel. If in fact it is a high limit issue, check your air, condensate hoses and blockage of return air from the ductwork.
Jan 08, 2011 | Goodman Heating & Cooling
I installed a new goodman unit this past spring. It seems to work ok to good in the day time but the tempature is warmer so we do not need as much heat. At night I know the thermostat is coming on. I...
Heating Mode (Goodman Service Manual)
· The furnace control checks for an open main limit (this
limit is normally closed). If the limit is open, the furnace
will remain inoperable until the limit is closed. During
an open limit the circulating air blower will be
energized. The status light will blink four (4) times.
· The room thermostat reacts to a demand for heat.
· The control will then check to insure that the vent
pressure switch is open. If, at this point, the vent
pressure switch is closed the control will blink two (2)
times and will remain inoperable until this situation is
corrected.
· The venter blower is energized.· The vent pressure switch will close when it detects a
pressure in excess of its setting. If the pressure switch
fails to close the status light will flash three (3) times.
The sequence cannot continue until the pressure switch
closes.
· After a pre-purge of about ten (10) seconds the electronic
ignition device will be energized.
· After a slight delay the gas valve will open.
· The burners will ignite and the flame sensor will detect
the presence of flame. The ignition device will
deenergize. If the sensor does not detect the burner
flame, the gas valve will close and the ignition cycle
will be repeated for a total of three attempts. If, after
the third attempt, the presence of flame is not detected,
the furnace will go into a lockout condition for one (1)
hour. It will then repeat the ignition cycle. This one (1)
hour lockout and retry will occur indefinitely.
· Thirty (30) seconds after the main valve is energized
the circulating air blower will be activated.
· The furnace will remain in operation until the demand
for heat is satisfied.
· Once the demand is satisfied the venter will shut off,
and the circulating air blower will shut off after the field
selectable time off is attained.
· The furnace will remain dormant until the next demand
for heat.
Dec 03, 2010 | Goodman GMS80903BNA Heater
My furnace blows cold air constantly even in heat mode. It's led light flashes 4 times in a set, what could it be?
On Goodman furnaces, 4 flashes usually means open high limit. Look for any burnt or loose wires or any resettable limits, they should have a red button that clicks when you push on it and wire going in and out of it with spade clips. If the open limit is not resettable, jump it out to verify its open and if that fixes the problem, replace the defective limit. Best of luck.
Mar 18, 2010 | Goodman GDS80703ANA Open Flame Mid-Size...
2 yrs old, getting a 4 flash alarm , "Open High Circuit" any help?
check for a reset able round limit switch in the burner area if fires up make sure filters are clean and no signs of flame roll-out in the burner area when fan comes on this furnace should still have mfg parts warranty left
May 16, 2009 | Goodman GDS80904BNA Open Flame Heater
I have a goodman gmp075-3 and it is flashing # 4 code
There is a Primary High Limit Switch towards the middle of the furnace, it more than likely needs to be replaced, very common to go out only after a few seasons. Also, you could have a flame rollout switch tripped that will signal the same code, these switches are re-settable and are located on the outer, top and sides of the burner assembly, they’re about ½ inch in diameter with a red push button in the center and two wires “ usually purple” coming off of them.
Hope this helps
Nov 20, 2008 | Goodman GDS80904BNA Open Flame Heater
Code continous flashing
If your igniter comes on but no ignition, that eliminates the possibility of a bad or clogged pressure switch, high limit or flame rollout switch. Sounds to me like you have a control board, or a gas valve going bad. Could even be some loose, corroded, or faulty wiring. Before the igniter comes on the furnace does a self diagnostics to ensure everything is working, or the furnace will not make it to the igniter sequence. Inducer motor, pressure switch/s, limit controls are closed…then comes on the ignitier, gas valve opens, pilot runners and burners ignite, flame sensor detects the flame, blower comes on and all operations are working.
Hope this helps
Oct 27, 2008 | Goodman GDS80904BNA Open Flame Heater
Goodman GMS90703BXA Heater Logo
187 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
