Question about Motorola Mobility RAZR V3
How do I unlock my samsung blast cell phone?
Its a t mobile phone but i want it to work with my att sim card
SGH A817 to t-mobile
Yes, on an unlocked phone you can easily switch SIM cards. All you can do is put the T-Mobile SIM card in the phone and it should show signal bars on the top of the phone. If not you can call up T-Mobile and ask them for correct network settings and they should be able to help you out with this.
If the phone is not unlocked it wont work with any other sim card except the original carrier SIM card. In this case you first need to unlock it.
I am posting the link below incase you need unlock code for your device:
Unlock Samsung Solstice 2 SGH-A817
Apr 15, 2013 | Samsung SGH-A817 Solstice II for ATT...
I NEED TO UNLOCK AN ATT SAMSUNG SGH-A137 PHONE
Its possible by codes.Get the unlocking code for your mobile from http://www.simpleunlocking.com/ .It helps to unlock your mobile easily.
May 18, 2012 | Samsung SGH-A137 Cell Phone
I am with tmobile and my friend gave me a att samsung phone when I put my sim card in it shows up att
Hi,did you inserted your t-mobile sim into your samsung mobile and then too does it displays at&t? if so it means that its locked to at&t network...you have to unlock your mobile to use your t-mobile sim..for unlock codes you can try at&t or can get it from online providers..once i got unlock code for my mobile from classicunlocking and unlocked my mobile..you can too try getting codes for your mobile and get it unlocked..but before that check whether unlock codes for you country and provider.
Aug 08, 2011 | Samsung A177 Cell Phone
I was given a Samsung phone. Model: SGH-A437 an ATT carrier. with ATT Sim card in it. Phone is shut off. I tried to put a T-moble Sim card in it, but doesn't work. the screen say's wrong card. how...
Hi you can contact your provider to get unlock code for your mobile or can try from online provider..you can try superunlockcodes to get unlock code for your mobile and get it unlocked..
Jun 12, 2011 | Cell Phones
How to unlock my samsung saga i770 for at&t
There are several ways for unlock mobile phones, but codes are best one, because it is easy and safe also,
you can get the unlock code for your Samsung model mobile, through this site http://www.mobileunlocksolutions.com/samsung-saga/rs1wp9/
It has the step by step instructions and easy methods for unlocking your mobile phones............
Jul 11, 2010 | Samsung Saga Cell Phone
I purchased a sim card from tmobile to replace my att simcard on my samsung SGH-A707.The new sim card won't work,it sy's incorrect sim and networt lock.
Hello
The sim wont work because it is locked to the att network which means it will only work with att sim cards.
You will have to unlock the phone from the att network before it can work with the T mobile sim card
You should contact your network provider so as to get steps to unlocking your phone from the att network or you should contact a repairer to help you unlock it
Thank you for visiting fixya
Mar 10, 2010 | Samsung SYNC SGH-A707 Cellular Phone
Won't accept ATT SIM card
Here is two possibility either you used sim in wrong slot like you have nano sim and you used into micro sim slot or other different slot. or your mobile is sim locked and that is why it not accepting at&t sim. here is how to unlock at&t simcard.
As your att sim working fine with blackberry so sim is fine no issue with sim card. on which mobile you have tried this sim as you have not mentioned your other mobile it is same as blackberry or apple or samsung mobile.
Sep 14, 2017 | AT&T Cell Phones
Unlocked att tilt with a tmobile sim card will not work
you have to call and get the new sim card activated with that phone even if it already is activated thier network has to update the information i believe
Jan 23, 2009 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
Samsung sgh-x426
I also have a x426 from 2003 and it wont work with the new ATT sim cards either, This is because of the Cingular/ATT merger which created a new network. The older original ATT phone must be unlocked to use a sim card from the new merged network. Try calling ATT Mobility customer service and request the subsidy unlock code. They are required to give it to you upon request, but it takes several days usually to get the code. I know because I used to work at a ATT call center.
Dec 23, 2007 | Samsung SGH-x426
Motorola Mobility RAZR V3 Logo
20 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
