Question about Honeywell Heating & Cooling
Purchased VisionPRO 8000 series model TH810U1003 digital programmable thermostat from Amazon on line to replace my old analog. My furnace company maintenance person was unable to get into the installation menu. It was not installed. Later, I managed to get into the installation menu and set the date and time but not all of the installation menu was available to me. I called Honeywell Support and they would not tell me how to get to the hidden installation menu items. They told me I would have to hire a contractor to install it. My furnace is a simple two wire system and I can install the thermostat since I already know which terminals to hook it up to. The furnace guy said to beware of some of the installation menu items that I can't get to. How do I see and adjust the hidden installation menu items for this thermostat?
    Novelist:
  • 124 Answers
The stats come with installer set up instructions inside the box. always do! i have used them always to program stat. go to a home store and as to look at a stat and see the instructions. find the installer setup info and make a copy. there are up to 100 options on many of these, and the default setting should be used if in doubt on many. i always leave the installer set up and the homeowner directions with the homeowner and for my future use. you may try to call honeywell and ask them to fax you the installer setup directions. many of thier guys can't even tell you how to remove the cover on a stat. some are quit good.
Posted on Nov 12, 2008
Why is screen showing EE and will not respond to touch?
The replacement batteries could be defective or installed incorrectly. Also, the thermostat could have been reinstalled incorrectly after battery replacement.
Dec 22, 2015 | Honeywell VisionPRO 8000 Programmable...
My gas furnace and heat pump runs at the same time???
its likely the outside control unit board its supposed to only kick on gas only when the temp is at freezing..
or
the inside thermostat is not selected for heat pump, open it an look at the jumper / switch.
or just replace the thermostat , then return it saying you couldnt figure it out. :P
there are a lot more variables here after that you cant know how to check.
Nov 05, 2014 | Honeywell VisionPRO 8000 Programmable...
Our visionpro 8000 thermostat has adjusted its day. It is currently one day ahead. We have misplaced our manual and we cannot seem to get the day to change. Suggestions?
This site has owners manuals for different types of thermostats. http://yourhome.honeywell.com/home/Products/Thermostats/7-Day-Programmable/VisionPRO+8000.htm
This site is the manual for the "VisionPro 8000". You can look up what you need, copy or download. http://customer.honeywell.com/techlit/pdf/PackedLit/69-1894EFS.pdf Roger
Apr 07, 2011 | Honeywell Heating & Cooling
Wiring heat only thermostat to inter therm central electric furnace had to replace fuze block, limiter, and sequencer thermostat only has one red wire and one white wire
I am trying to install a Honeywell VisionPro 8000 thermostat for my Intertherm Central Electric Furnace but I am having trouble getting to work any suggestions?
Oct 06, 2010 | Heating & Cooling
I have a Rheem Gas Furnace with an old analog thermostat (Wires conneected to terminals R and 4 for the thermostat). I went to install a Rheem digital and programmable thermostat and it indicated that it...
if you have 2 wire at thermostat Terminals at furnace that the thermostat wire attach to should be R & W if your new thermostat has R & W terminals is should work, an easy thing to remember is the red wire on R the white wire on W. If 4 wire at thermostat at furnace green on G, Blue on Y, red on R,and white on W same at thermostat If these do not match find a thermostat with these terminals
Dec 06, 2009 | Heating & Cooling
My Model TH8320U1008 touchscreen not working. I have replaced the batteries, still doesn't work. Is there a way to reset it?
I dont think its your thermostat. The 8000 pro series is relatively new. I think is you furnace you lost 24 Volt power. Check the furnace out first. www.fastacservice.com
Oct 18, 2009 | Honeywell Electronic Programmable...
Replacing analog thermostat with digital
alot of those gas fireplaces work on what is called powerpyle or 750 mv if your old thermastat has a ts in model then you would need tstat that works with millivolt systems
May 04, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
251 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
