Question about RCA E13309 13-Inch Diagonal XL-100 Color Television Television
Can't shut off wake up timer
RCA E13309
Somehow the wake up timer is set to "on" and I can't turn it off. Is there a way without the factory remote?
Thanks
  • jlevine_17 Nov 13, 2008
    I tried the buttons in the front before. I can change the time the set goes off, but I can't set it to "off". I have several universal remotes and I can't access any "off" setting.
    Atn: coolguy008
    That solved the problem - thanks.
    1. If the problem occurs again, is there an easier fix, or do I need to pull out the plug again?
    2. Any idea what causes the problem?
    Thanks again
  • 1,879 Answers
Some functions are accessible/configurable via the provided factory remote control. Since you are using universal remote control, the hard reset is the only way.
Posted on Nov 13, 2008
  • 2,326 Answers
If you do not have the original remote control, you can still get to disable the wake up timer using the front buttons.
Press menu and use channel down to get to TIME and Use the VOL+/buttons to set the wake-up timer. To clear the wake-up timer, display the wake-up screen and press RESET.
Click here to download the user guide for your TV.
    Sergeant:
    Champion:
  • 283 Answers
1. unplugged your tv
2. plug it back then switch on.it will automatically restore factory settings
if doenst work
1.in front of your tv or front pannel you'll see a menu
2.click the menu
3.press down look for timer then click it
4.selct timer of.
thank you. plz dont rate me if you are not satiesfied.....
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try in front of the tv panel if there is anything that can be
reset in defult setting or unplug for few days
or locate the battery inside of the tv that holds the memory
remove it and placed it back
  • ronald suboc
    ronald suboc Nov 13, 2008
    or use a universal remote
    Genius:
  • 1,239 Answers
HI try the settings on the front panel of your tv BY GOING TO 1.MENU
2.IN THAT LAST OPTION ,SELECT IT 3.SELECT TIME 4.THERE YOU CAN SEE THE TIMER YOU CAN SWITCH IT OFF. PLEASE RATE IT
Posted on Nov 12, 2008
  • RCA Master
  • 13,433 Answers
The memory of the tv would need to be reset, Maybe by unpluging over night it might reset, might need longer, might not reset at all, debends on the tv.
    Brigadier General:
  • 6,966 Answers
Without the original remote there is only one action you can try, that is to unplug from the mains for an extended period of time in the hope that the unit will reset and revert to factory defaults.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 12, 2008
    Should this method be not corrective, then at least a replacement remote must be borrowed, accessed or even purchased. Pls click here for a possible replacement.
  • 958 Answers
Is there some buttons on the tv set that you can manually set the wake up button to off?
if not , unplug the unit, open the cover and look if i has some button batteries that holds memory. remove them for 5 minutes and return them. i hope that would erase your wake up cal program.
tnx 4 using fixya,
drcool
    Genius:
  • 3,422 Answers
Please do a hard reset by unpluging all the cords of the Tv for 4 hours even the power cord.Aftrer 4hrs turn on the Tv and let me know the result.
    Master:
  • 763 Answers
Try the settings on the front panel of your tv or change your remote control by purchasing a universal remote control.
thank you for using fixya
CHARCOIS
I have a 58' model LED58G45RQ and at a certian time at nite its coming on how do i fix this problem to stop having to get up and turn it off
Appears to be RCA TV.
The timer turns the TV/VCR on at a desired time. You can set it to
wake you up in the morning or remind you that a favorite program
is about to start.
1. Press MENU on the remote to display the TV/VCR MAIN MENU.
2. Press 2 to display the TIME menu.
3. Press 3 to display the WAKE-UP TIMER menu.
4. Use the number buttons to enter the channel number and time.
• After you enter the time, press 1 for AM or 2 for PM. Example:
For a time of 5:07PM, press 5, then 0, then 7, then 2.
• Press CLEAR to correct an entry or RESET to clear the timer.
6. To cancel the wake-up timer, first display the WAKE-UP TIMER menu by repeating steps 1-3 above. Then, press RESET to cancel the timer, and press MENU to exit. The timer is also canceled if MENU is pressed before step 4 is completed
RCA TV VCR COMBINATION User Manual Sleep Timer Wake up Timer Front Panel...
Mar 11, 2016 | Televison & Video
My rca xl 100 remote will not work. I have changed the batteries multiple times. I was just wonder if i could buy a new rca remote and be able to have it work on my tv?
Yes,, you can easily purchase a new remote and have it work on that TV. In the packaging for the new remote you will find a piece of paper that contains the necessary remote codes for your TV. Follow the instructions provided with the remote and you are all set!
May 19, 2011 | RCA E13309 13-Inch Diagonal XL-100¿...
How to i turn my truflat without the remote? somehow that setting was set to lock and after shut down i won't able to turn it back on,beside that i lost my remote 1year ago
sorry m8 without a remote it is impossible the only way i have been able to do it is by loaning a sky remote from a friend getting the code from the net then puting the code in the remote and it turned on that way but i sat for days before i thought of that once i got it on i turned the lock off use any universal remote you can find or loan but the best i can say is the sky remote by far
Feb 25, 2011 | RCA TruFlat 27F520T 27" TV
How do I program my urc-4021BOO One For All remote to operate my RCA Tv (E13309)?
First turn on the tv manually. Next press the TV button on the remote once. Then hold the set button until the light blinks twice. There are 7 codes for RCA tv's and the model is not specified. After each code entry, the light should blink twice again. The codes are : 0047, 1047, 1147,1247, 1347, 1447, 1547. After you enter a code try the power button on the remote and the set should cut off.You have to start over with the set button with every new code. When you find the right code the tv will turn off. I hope this helps. The link for the owners manual is: http://www.oneforall.com/uploads/support/cc5ef1b7b389da162d2ac97bb9e94210.pdf Thankyou for using fixya. I'm glad to help.
Nov 04, 2009 | RCA Televison & Video
Screen Difficulties
in this issue you have to apply fresh solder in your CRT socket board and and main board its a cold solder problem. this can help you more.
Aug 15, 2009 | RCA E13309 13-Inch Diagonal XL-100 Color...
My citizen tv is locked and i dont have the remote to unlock it is there a way to do it manually
Hold menu button +power+volume up you will go into service mode. Scroll down to see if you can find the reset which will reset the tv to factory setting erasing the password. I never had to do this it might work.
Jun 30, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
Change my rca xl 100 to it video input without a remote
ye a tech can do that.he'll make a extension of the video input at rear.or you can buy a switchbox for that.
May 20, 2009 | RCA E13309 13-Inch Diagonal XL-100 Color...
Change video input witho remote
There might be an input button or menu button on the front of the TV (or behind a door or panel) that will let you set it for video input.
RCA RP3721 Alarm won't shut off
To turn alarm off completely, press WAKE1 and WAKE2 until the bell-shaped indicators go off.
As for resetting the alarm (buzzer), press SET WAKE/CLOCK untill SET and WAKE! light.  Press left- or right+ arrow to set time.  Press WAKE1 until bell-shaped indicator comes on.
Jun 14, 2007 | RCA RP3721 Clock Radio
Wake Up Timer
u have to set real time first then set the desired time when u want to on ur tv and standby the tv via remote,
May 15, 2007 | RCA E13309 13-Inch Diagonal XL-100 Color...
RCA E13309 13-Inch Diagonal XL-100 Color Television Television Logo
52 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
