Question about Logitech Z-560 Computer Speakers
How can i plug in my logi tech speakers on my new dell computer,
The ends on the cable for subwoffer are different it is round with pins it will not connect to dell computer
    President:
  • 2,712 Answers
  1. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the M3D button on the controller unit (if you own a z-560 or z-540) or use the source selector switch (if you own a z-5300 or x-620). If you do not have any of the models above, you can use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
Posted on Nov 12, 2008
Tip
DELL A425 SUBWOFFER PINOUT
CABLE PIN OUT
PIN 1 SPEAKER 1 PIN 5 SPEAKER 2 PIN 3 INPUT 1
PIN 4 INPUT 2 PIN 8 EXTERNAL VOLUME CONTROL PIN 2-5-7-9 GRD
PIN 8 MUST TO GROUNDED FOR MAXIMUM VOLUME OUTPUT
on Jun 25, 2014 | Dell Zylux Powered Subwoofer - P/n A425
How do i connect the boston BA745 comp. speakers to my gateway desktop?
Assuming you have the BA745 2.1 speaker set up, all of the cables connect to the subwoofer and then to the computer or the satellite speakers (these are built into the speakers IIRC). Take the cable with the black box (2 pins) to red and green. The red and green plugs go into the matching color ports on the computer and the pins on the black end fit into the jacks between the those for the two satellites. Plug the single end speaker cable into the subwoofer port all the way to the right on the back of the subwoofer. Plug the wire with the two plugs into the matching color jacks (blue to the left, red to the right). Then plug in the power adapter cable in the farthest left jack and plug in the other end to a surge protected power strip (that is plugged in and turned on).
Oct 24, 2010 | Boston Acoustics BA745 Computer Speakers
I am a regular Dell customer. Received Altec Lansing ADA745 Speakers with my Dell Computer. The cable from "right front" speaker has a broken wire or loose connection in the plug.It isthe "power connection...
Yes thats real easy. You could get a replacement plug, cut the "Old" end off, and reattach the new one, a little bit of soldering will be needed. Usually the Center pin is Plus, Positive, the Outer is Negative. Or take it to a friendly local serviceman and he'll be able to do it for you for a small. free? fee.
Feb 11, 2010 | Audio Players & Recorders
I NEED A USB ADAPTER FOR A PHILIPS MMS 321 Computer Speakers
This post is very old but will answer it anyway. the Round 10 pin plug you were talking about goes to the powersupply that came with the speakers.the one speaker plugs into the other speaker and the double ended cord plugs into your Pc sound out and the other end goes to line in on the powersupply.
Sep 14, 2009 | Philips MMS 321 Computer Speakers
Lost thin cable from compter to subwoffer
u can prolly get one from radio shack or best buy that would b ur best bet
May 29, 2009 | Level 9 Sound Designs Monsoon Planar Media...
I cant figure out how to connect my speakers to the hard drive
The speakers is the round green socket. The yellow 9 pin socket is a MIDI/Game controller socket.
Feb 03, 2009 | Dell Dimension 3000 PC Desktop
Logitech X-540 connecting to dell dimension 3000 ???
Your problem is you have a 3 channel sound card on your dell and you bought 5 channel speaker system. You can plug the green to green and get 2.1 sound but you will have to by a 5.1 pci sound like in the link below to get the full use of your 5.1 system.
http://www.mikescomputershop.com/asus-xonar-d2pm-sound-card-p-2357.html
Sep 08, 2008 | Logitech X-540 Computer Speakers
Dell monitor cable
Can you post the Model Dell and the SKU number of the video card from your invoice?
May 27, 2008 | Dell Computers & Internet
Logitech Z-560 Computer Speakers Logo
233 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
