Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
XBR4cuts off and blinks six times
My xbr4 cuts off and stand by blinks six times
I Have a Sony KDL-46XBR4
  • 320 Answers
A 6 flash failure indicates a backlight problem, either from the backlight inverter board or the backlights in the panel failing. There is a simple problem that sometimes causes this; loose screws holding the boards in place. You can try removing the power, taking the back off the set and tightening down the screws that secure the boards to the frame. the screws are aatually a ground connection and if they are loose it can cause problems. if this doesn't help, you will need a tech to look at it.
Posted on Nov 15, 2008
Sony Bravia KDL-xbr4 Replaced TCON board All worked great for a week Had an issue w/ HDMI cable at the box fixed it and now tv comes and the goes off to 6 blinking red lights
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter
Have this from a youtube link find BUT
Better is to look first also on bad leaking or bulged capacitors thats better to replace in the bad components to get a repair because active components died on bad capacitors but after a while because on the build-in protection circuit by faults like deformed or leaking capacitors and even several fuse resistors then after replace a complete board again after a while you will may be get the same kind of problems again, take If you find some or much bad capacitors replacements 10 volts dc higher . begin with control on the power supply first of all.
Sony Bravia TV kdl red blinking led light error codes solutions Sony KDL 40XBR4 KDL 40XBR5 KDL 46XBR4 KDL 46XBR5 Service Manual
Jan 05, 2017 | Sony Televison & Video
Sony KDL-46XBR4 46 in. LCD flashing light. Light flashes red 8 times pauses
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC. Try this link too.
Dec 20, 2013 | Sony KDL-46XBR4 46 in. LCD Television
My Sony KDL 46XBR4 when first turned on has vertical lines, or sometimes very dark picture for about half an hour, then the picture clears up fine, as long as I keep the tv on. Now, it is dark, almost...
That is correct. Sony has extended their warranty on panels for this model until Oct. 31st 2012. Just give Sony a call or simply take your set to an authorized service center and you will get your set fixed for free.
May 19, 2011 | Sony KDL-46XBR4 46 in. LCD Television
My Sony Bravia, model KDL-46XBR4's standby light is flashing 6 times. We have reset it 3 times but after several days it shuts down and continues to flash the standby...always 6 times. Can anyone tell...
I am experiencing exactly the same problem. TV turns on but within 60 seconds the screen goes black and the red standby light blinks six times. Were you able to resolve this problem on your TV?
Oct 17, 2010 | Sony KDL-46XBR4 46 in. LCD Television
Sony kdl-46xbr4 turn on and shuts off try 10 times
If the problem is with the LCD display unit, Sony is now extending the warranty on the LCD display and will fix the problem for free through September 30, 2012. See: http://esupport.sony.com/US/perl/news-item.pl?news_id=378&mdl=KDL46XBR4 Call their customer service number and they will give you a case number. Then call one of their authorized service centers and they will fix it free, in home.
Dec 30, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
391 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
