Question about KitchenAid KSRS25IL Side by Side Refrigerator
KSRA25IL ice cube tray won't fill
On a KSRA25IL (side by side) the cold water works but the icemaker tray does not fill with water. The icemaker red light keeps flashing. Any suggestions??
  • Anonymous Apr 20, 2009
    I have the same model refrigerator and the identical problem (water works, ice stopped filling). Wondering if this blow-dryer trick worked?
    thanks
    Tom...
The fill tube is probably frozen. Its in the roof of the freezer. turn off the freezer and heat the roof of the freezer with a hair dryer, being careful not to get it too hot,and it should thaw and work again. If you can put the food elsewhere for a day, just turning it off with the door open should work also.
Posted on Dec 05, 2008
GE Fridge icemaker is not working - Help!!
I installed a new icemaker (cost approx $100) and its making ice. Very easy to install yourself (remove 4 screws holding part below icemaker, then unplug icemaker, and unscrew the 2 screws holding it in place.). Good luck-
Jan 28, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Our ice machine does not make full ice cubes. they are small and not complete, they are full of holes.
The icemaker requires a water pressure of 1.5 - 8.5kgf/cm2. It is acceptable if the water supply fills a cup of 180cc with water in 3 seconds. The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Nov 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hello, I have an Samsung rs2533sw. the ice maker stopped working. it is at 8 degree. at this juncture, the manual reset switch does not work. if I let it unthaw then it works. once it gets cold it doesn't...
Hey heads up! The ice-cube maker has two parts... In fancy terms the business motor end, and the back-stop. Your back-stop is all busted. Mostly because it's been used successfully as a backstop for a few thousand times. The piece costs about $20, and you can get it at any Samsung parts distributor. The best way to check this is that your ice-cube tray will look like it's coming un-hinged in the back when it attempts to empty the ice.
When it works properly the ice-cube tray is actually contorted about 45 degrees from the front end to the back. The same way an adult male would crush ice.
Oct 21, 2009 | Samsung RS2534 Side by Side Refrigerator
Ice dispenser does not work unit makes ice and water works fine
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Arctica won't make ice; ice was frozen solid yesterday. After removing, it won't make any more ice cubes.
Sep 12, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Model 22 Icemaker is not making ice
The following assumes that the ice trays are properly filling with water. If not, check the water control valve.
Sep 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice cubes not freezing completely before dumping
check evaporator fan if working or u may have a leak , or check condsr fan motor :)
Aug 28, 2009 | Amana ARS2464B Side by Side Refrigerator
Icemake rarely dumps ice and when it does they are small cubes
There has to be a restriction in the water supply line from your saddle valve, ( shut off valve on the cold water line ) to the water valve. It can be in the category of, the hole in the water supply line is getting calcium build up or to small of piercing, or it can be a kink in the water line, or even the white fill tube at the icemaker is closing up with ice. 99% sure you will find the problem in one of those areas.
Apr 23, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Lg side by side Ice maker not filling all of the tray/dripping
You may have a restriction in the icemaker.  Remove the icemaker and make sure that there is no ice buildup other than in the cube slots.  Also make sure that the fill tube is clear of any ice obstruction.
Mar 21, 2008 | LG LRSC-26922 Side by Side Refrigerator
Water overran ice maker tray
It could be one of two things. The fill cycle could be too long causing the water to overflow or the icemaker may not be ejecting all the cubes out of the tray. A normal fill cycle is very short. Maybe 6 seconds long. So I would check and see how long the fill cycle is and when it stops check and see how much the tray is filled with water. I would also check and make sure that all the ice cubes are ejecting next time you hear it harvest.
Jul 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSRS25IL Side by Side Refrigerator Logo
600 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
