Sharp CF-2216 PM light on
Can not make copies, PM service light (the little man) is on and will not clear.
I tried the sequence (Cancel,interrupt,0,interrupt...1,5,Start) yet the light will come back. Is there another code that I should do? This is a older copier but people are comfortable with it.
  • notbroke Nov 12, 2008
    I agree that there should be another code entered. Problem is I do not have a service manual for this copier and the church does not want to put money into it, only time. So the question is what are the codes? I can not find the manual for free only for pay.
  • 2,794 Answers
You might have to clear the maintenance counters for the drum as well as few others.
You should have a service manual to tell you the codes to reset.  There are several third party companies on the internet that can provide you with a pdf file of the manual.
Posted on Nov 12, 2008
  • Tim Babcock
    Tim Babcock Nov 12, 2008
    A better place to get some copier advice like that is copytechnet.com.  It's a free website and you can find a factory trained technician who can give you the codes needed.  I don't know the codes for that particular model of Sharp copiers unless it's an AR series.
Please help me, how to reset or clear off Sharp Copier/printer AR 5618s Service Maintenance and Developer Indicator.
try pressing *,#,0,#, 24,2,yes or 1 to reset developer light (circle of dots) Then 20, yes or 1 to reset the little man light.
Dec 19, 2014 | Sharp Office Equipment & Supplies
I have a Kyocera Mita KM 1530. User maintenance, the lights are now lit. Now I know I need to replace the drum, but someone can tell me later if you need to reset some or mute only the drum and is already...
press in sequence 10871087...
Go to U251 using cursor keys.
Check and clear PM count(copies since from last PM and PM reset).Press start to display six digit PM cycle. Select "Clear" w/ cursor up/down to clear count back to ..
Go back to U001 and press Start key to exit.
Sep 16, 2013 | Kyocera Mita Km 1530 2030 Copystar Cs 1530...
How to remove service man from copier sharp ar5320
hi the service man means yours copier have complet the pm cycle if u dont want to replace drum and devolper u can clear the pm counter with sim 24-4
thanks
May 12, 2010 | Sharp AR-5316 Advanced Digital Imager...
My copier is indicating CALL SERVICE MAN, i
you did service the machine or e technician which is trained to do the service because if the machine was service by a technician this would haven't happened, but this is not important now, the call service man is still indicating because after the service in the service mode the pm counter have not been reset, so if you have a good copy then there is no problem
Jan 28, 2010 | Sharp AR-5316 Advanced Digital Imager...
Clear seviceman
The service man light is an indication that preventative maintenance is due to be performed on the machine. This is also most likely the cause for the faint copies.
This is true unless there is a code associated with the service man light...check the display for any alpha numeric codes such as H4 or L2 etc.
Oct 19, 2009 | Sharp AR-5320 Black and White Copier
Sharp AL 1644
here is the fix: Press "C", press the exposure button (below the picture of the little man), press "C", press the exposure button. When you do this all the indicator lights will turn off. Now input "24", press the green start button, input 07, and press the start button again. Now turn the copier off and back on with the power switch on the side.
Press: "Clear", "Exposure Select Key", "Clear", "Exposure Select Key", "24", "Start Key", "7", "Start Key"
Sep 09, 2008 | Sharp AR-5316 Advanced Digital Imager...
"little red man"
The "Little Red Man" stands for that the copier has reached it's set "P.M." counter and it is time to have the copier to have a general cleaning done. It is just a counter that comes up 10k, 20k, 60k, 80k or it is set not to count at all. It should not affect the copier it self. It has to be reset and set to "0" for no P.M. count.
Apr 24, 2008 | Sharp AR-160 Copier
Sharp AR-5316
Never heard of an F2 on that machine. But give this a try.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Mar 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Red man flashing on photocopier
Hi Your Copier needs a service, that is what that led is for Hope this helps Regards
Aug 08, 2007 | Sharp AL 1215 Black and White Copier
110 people viewed this question
k24674
jasbo
jasbo
