Question about Dell 1700n Laser Printer
Dell 1700n Ready/Data light blinking (secondary fault)
Got all lights blinking, pressed continue twice and got the ready/data light blinking. Replaced the DC controller card and the same problem exists. Ohmed out the fuser and i'm stuck.
  • 3 Answers
Ok, try this--1.power off printer 2. open front door 3. press and hold continue and cancel buttons 4. power back on 5. wait until light sequence stops om error 6. power off and back on.
this resets factory defaults on the printer..
Posted on Dec 03, 2008
Printing is always blair and i cant view what is printer
Here is a full story
HP LaserJet Professional M1130/M1210 MFP - Interpret control-panel light patterns (M1130 Series only) Interpret control-panel light patterns (M1130 Series only) If the product requires attention, an error code appears on the control-panel display. Status-light legend c01993382.gif Symbol for "light off" c01993383.gif Symbol for "light on" c01993381.gif Symbol for "light blinking" Control-panel light patterns Light status Error code State of the product Action All lights are off.
c01993373.gif The product is turned off. Press the power button to turn on the product. Ready and attention lights blink.
c01993380.gif The status lights cycle during the formatter initialization period or when the product is processing a cleaning page. No action is required. Wait for the initialization period to end. The product should enter the ready state when the initialization period is finished. Ready light is on.
c01993421.gif The product is in the ready state. No action is required. The product is ready to receive a print job. Ready light is blinking.
c01993420.gif The product is receiving or processing data. No action is required. The product is receiving or processing a print job. Ready light is blinking slowly.
c01993420.gif The product is in low power mode. No action is required. Attention light is blinking.
c01993418.gif E0 Paper is jammed in the product. Clear the jam. E1 The input tray is empty. Load the tray. E2 A door is open Verify that the print-cartridge door is fully closed. E4 The product memory is full The job is too complex for the product to print. Simplify the job, or divide it into multiple files. E5 The product did not pick up paper from the tray. You might need to clean or replace the pickup roller. H0 The product is in manual-feed mode. Load the correct paper type and size into the input tray. H1 The product is processing a manual duplex job. Load the pages into the input tray to print the second sides. The attention and toner lights are blinking.
c01993375.gif E3 The print cartridge is missing or is not installed correctly. Install the print cartridge. The toner light is on.
c01993429.gif The print cartridge has reached the end of its estimated useful life. When the supply has reached this condition, the HP Premium Protection warranty for that supply has ended. You do not need to replace the print cartridge at this time unless print quality is no longer acceptable. Attention light is blinking, and ready light is on.
c01993379.gif The product has experienced a continual error from which it will recover on its own. If the recovery is successful, the product continues to the processing data state and completes the job.
If the recovery is unsuccessful, the product continues to the continuable error state. Try removing any media from the media path and turning the product power off, and then on again. The attention and ready lights are on.
c01993388.gif E6
E7
E8
E9 The product has experienced a fatal error from which it cannot recover.
  1. Turn off the product or disconnect the power cord from the product.
  2. Wait 30 seconds, and then turn on the product or reconnect the power cord to the product.
  3. Wait for the product to initialize.
If the error persists, contact HP customer support
Mar 01, 2013 | HP LASERJET PRO M1132 MFP
My Dell 1720 copies tells me it has stopped because the photoconductor kit has stopped working. I just replaced everything and keep getting the same error.
If the drum cartridge has not been replaced, it must be replaced before resetting the counter to avoid damaging the printer.
  1. Power off the printer.
  2. Open the front door.
  3. With the front door open, hold down the Continue button while powering on the printer.
  4. Keep holding continue until all lights start flashing then release the button.
  5. Once only the Error light is on, close the front door.
  6. At this point Continue, Ready/Data, Toner Low, and Load Paper should all be lit.
If the previous set of steps did not go as described then do not continue. Please complete the previous set of steps again.
  1. Wait for the printer to make a sound as though it is about to print something. (This may take a minute.)
  2. Press Cancel 4 times SLOWLY (1 second between presses) to cycle through lights until ONLY the Toner Low light is on. (It may take more than 4 presses.)
  3. Press and hold Continue until all the lights cycle through and go back to Toner Low
  4. Cycle power on the printer.
  5. Press and release the Continue button to print out the settings page. Under Cartridge Information it should read Photoconductor: 0K
Aug 04, 2010 | Dell 1700n Laser Printer
Dell 1700n error light after print job.
double pressing the continue button twice , the printer will give a secondary error code: then check here (link below) : toner is low, with blinking lights = Replacing the Imaging Drum
http://support.dell.com/support/edocs/systems/1700n/en/index.htm
download the manual above and look under Troubleshooting->Maintenance for your printer-> replace imaging drum...
good fortune, please leave rating...
May 11, 2009 | Dell 1700n Laser Printer
DELL Laser printer 1700/1700n
All flashing lights for the Dell 1700 series (1700, 1710, 1720 including those that have n or dn as part of the model) printers is a service related error. When double pressing the continue button twice quickly, the printer will give a secondary error code, narrowing down the printer part being effected. It is possible to even narrow the error code down even futher by double pressing the continue button and taking note of which combination of lights come on, wether they are steady or blinking. Most generally when this series of printers, when you get all flashing lights, something major is going on with the printer. It could be pointing to the fuser, or main board, etc. You can call dell warranty support and they will help narrow down which part is being effected. Most generally, what is being effected is not cost effective to get fixed if you are no longer under warranty.
Sep 18, 2008 | Dell 1700n Laser Printer
Light blinking
The Controller card is faulty
Sep 01, 2008 | Dell 1700n Laser Printer
Problem with printer all buttons flashing
All lights flashing is an error indication. to learn the problem you'll need a service manaual. The procedure is to hit the Continue button twice - see which lights flash (secondary code) and consult the manual. Then repeat that step and look up the final code (tertiary code) in the manual. This should be the problem.
Aug 05, 2008 | Lexmark E321 Laser Printer
T420 error lights
does this occur after while, during or after printing?
from what application are you printing?
sounds like the print you are sending may be too big for the memory of the printer, or it can not recognize the file type.
Oct 16, 2007 | Lexmark T420d Laser Printer
Dell 1700n Laser Printer Logo
405 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
