Question about Giottos MM8970 Monopod
Glue holding head mount to top tube failed
What type of glue can I use to reglue the plastic head mounting plate to the carbon fiber top tube of the monopod?
    Scholar:
  • 33 Answers
I had a similar problem with my Giottos carbon fibor monopod, but it was still under warranty so they just replaced it.  I'd still give contacting the company that handles Giottos in the US a note and ask them to take care of it, or if not, a recommendation.
http://www.hpmarketingcorp.com/warranty.html
There is an email address on this page.  They were quite helpful when I had my problem.  It cost me shipping to send the old one back and I had a new one in under a week from the time I sent if off.
Posted on Jan 29, 2008
How to disassemble
I don't see a diagram, but the parts are listed here: http://www.manfrottotripodparts.com/headMVH500-1.html
They also do repairs if you cannot do this your self.
May 27, 2014 | Manfrotto MVH500A Tripod Head 535 Carbon...
Tip
Replace broken scroll wheel on Rio carbon
Here is a quick guide to taking apart your rio and re-gluing the scroll wheel.
This is the most common part to break on the rio carbon but is reasonably easy to fix.
How to disassemble a Rio Carbon:
  • First take off the front plate (you may want to warm it up, not fry it, with a hairdryer to make the removal easier.
  • Then you will see near the bottom there are two holes which if you get a very small screwdriver then you can unclip 2 of the clips holding the back plate on.
  • Then pry your screwdriver between the back of your rio and the rubber and lever the back off slightly (you may want to get a cocktail stick/match stick etc. to keep this open) then on each side you should see two more metal clips holding the back plate on. Lever each of these clips and the back plate should pop off - don't force it or you might break the plastic.
  • Then you will be able to see at the top left your scroll wheel (or where it should be!)
How to attach the scroll wheel:
  • The scroll wheel was originally attached on by two connections which you should b able to see - these were the weakest joints on your player and kind of lets rio down because the rest of the player is great in my opinion even though it does break a lot.
  • basically all you have to do is glue these back on...
  • Place a little epoxy glue on the points of contact (you can use super glue or a hard plastic adhesive but often they are too brittle so if you drop it again it will almost definitely break)
  • Glue it together...
  • Leave it a couple of hours to harden/dry...
  • Your done...
Now wasn't that easy!
Mowcius
on Jun 01, 2008 | Rio Carbon MP3 Player
Install turn signals
any of the easy fix solutions will probably break again, but try araldite, super glue may be a short term solution. google a carbon fibre part manufacturer in your area and he may be able to help
Mar 17, 2014 | Buell M2 Cyclone Motorcycles
Rear view mirror
1. Slide the metal disc off the base of the rear view mirror assemble. For newer models of cars the metal plate may have to be removed with a properly sized Allen wrench. These are L shaped wrenches that are designed to remove hex head screws and can be purchased at any hardware store. While there you should also pick up a razor blade scraper and some masking tape.
2. Head to your local Schuck's or other automotive store and purchase a rear view mirror adhesive kit for around $3. This super strong adhesive is a two part system that comes with a tube of glue and a vial of accelerant.
3. From the outside of the car, use masking tape to mark the area where the old glue adhesive still remains.
4. From the inside, scrape off whatever is left of the glue residual.
5. Since this glue only works in temperatures of 60 or above, you will have to make special provisions when the weather is cold. The car should be placed in a warmed garage or facing the sunlight. A blow dryer can also be used to heat up the windshield, although don't hold it too close to avoid cracking the glass.
6. Once the glue has been scraped off the windshield, wipe down the area with rubbing alcohol. The metal plate should also be wiped down with alcohol.
7. Apply the accelerant directly to the mounting area on the windshield. Allow to let dry 5 minutes. In the meantime, apply the accelerant to the flat part of the base plate as well and let dry.
8. Slather on the adhesive on the back of base plate and press it onto the glass. Hold in place for about 2 minutes until the glue begins to set up. Let the glue dry overnight before reattaching the rear view mirror.
Jun 11, 2013 | Cars & Trucks
How can I mount rc498c4 on my bogen 3001 tripod legs
Go to http://www.bogentripodparts.com/repairs.htm and the top right video shows how to remove and replace the head.
Mar 28, 2013 | Bogen Manfrotto 498rc4 Midi Ball Head W/rc...
Power button broke gfdn240el1ww
There are two main pieces to the front panel for the GFDN240EL1WW dryer-- the plastic panel and the circuit board. The actual replacement part is: Control Panel WE19M1687. The panel can be purchased for from places like partselect.com or repairclinic.com or Amazon or even EBay, etc. for $100-$200+.
The power button is just a piece of plastic mounted to another piece of plastic; it is not electronic. When pushed, it presses against the circuit board, which then turns the unit on/off. When the power button breaks, it typically means the little plastic button has broken off from the plastic panel. Most likely, the problem is the mount point for the button and the button is actually re-usable.
A cheaper quick-fix is to:
  • Remove top screw from back of the front panel
  • Remove main front knob from the panel
  • Remove screw from behind the front knob
  • Grab both sides of the front panel and push/pull up to remove the panel
  • Disconnect the block connector (power) from the circuit board after removing the panel
  • Locate the power button and mounting position
  • Inspect to see if it looks like you can glue the button back into place
  • Buy a small tube of loctite Stik'n Seal Ultra Universal Adhesive
  • Put some Stik'n Seal on the button mounting point for the power button (be generous)
  • Press the button onto the mounting point and hold for a few minutes
  • Add more Stik'n Seal around the edges of the mounting point and the button mount after you have held the button in place long enough so that it sticks
  • Let the whole thing dry for several hours (instructions on the adhesive say 24hrs
  • If you are worried about the button staying seated while the adhesive sets, you can always try tape it into place
  • When dry, replace the front panel by reversing the steps above used to remove the panel: connect the power block, slide the panel back into place, replace the front screw and knob, replace the top screw in the back of the panel
Jan 23, 2013 | GE DBVH512GFWW Dryer
How to mount plate
You have to loosen the tension knob on the right all the way, and then push in the red (plastic) button on the left as you slide the plate in.
Amanda
Nov 21, 2012 | Manfrotto 501HDV Pro Video Head Tripod
Interior rear view mirror fell off my 98 BMW 540i
There is a small set screw that holds the mirror to the small metal button. Most vehicles use a small Phillips screw but some use a Hex Key Wrench (Allen Wrench) type screw. Slide the mirror off the button. Make sure not to remove the glue before you put the button back on. Trace around the glue with a grease pencil on the outside of the windshield before you remove it. So you know exactly where to replace the button. You can buy a Rear View Mirror Adhesive Kit for around five dollars.
Jan 10, 2012 | 1998 BMW 5 Series
I am looking for advice on how to mount a Ball Head on the plate of a regular tripod, So far I have not found a Ball Head that has the same size thread in the bottom. Is an adapter available as a solution....
The bottom threads on most tripod heafs are 3/8", but some are 1/4"/ The mounting screws on MOST tripods are 3/8", but I have seen `/4" (especially on monopods. IF:
tripod=3/8 head = 1/4 need mounting plate 3/8 female to 1/4 male
tripod = 1/4 head - 1/4 nothing
tripod 3/8 head 3/8 nothing'
tripod 1/4 head = 3/8 there is an adapter/reducer that screws into the 3/8
' female and reduces that to 1/4"
Feb 20, 2011 | Photography
Giottos MM8970 Monopod Logo
95 people viewed this question
Top Giottos Photography Experts
Steve
Alcolu John
Alcolu John
Tony Parsons
Tony Parsons
Are you a Giottos Photography Expert? Answer questions, earn points and help others
