Question about Dell Inspiron 5160 Notebook
Can not connect wirelessly
I had to replace my hard drive, and the only thing that doesn't work now is my wireless card. I can connect hard wire, but when I go to my device manager, it says that "The drivers for this device are not installed. (Code 28)
To reinstall the drivers for this device, click Reinstall Driver."
When I try and reinstall the drivers, it doesn't work.
Any help would be greatly appeciated.
  • howesmusic Nov 12, 2008
    Thanks for that info about Dell. I forgot to write that I have already downloaded all of the drivers from the dell website. I tried calling Dell Support, and after speaking with 5 different people, I was told that I would have to pay $60 (one time fee) for someone to help me. I told them that I would search the internet for a while before paying the $$.
    So if I can't get the fix from Dells support page, is there anyone who has another thought?
    Thanks
    Bob
  • Dell Master
  • 998 Answers
Go to www.support.dell.com and select "I'm looking for drivers and downloads". If you don't have the proper version of Adobe you will be prompted to install it. Once installed return to "drivers and downloads" and enter the "service tag", (serial number) of the laptop. Dell keeps a listing of drivers for every customer's computer they sell. Look under “Network” to download drivers.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 12, 2008
WHY DOESN`T MY HP,LAPTOP.CONNECT TO WIRELES TRANSMITER.
Make sure you didn't disturb the wireless card inside the laptop. Check the connections for the wireless card antennas (usually a gray wire and black wire). Also some laptops have a little on and off switch, to turn on and off the wireless. Please make yours is on. I've had a few clients with the same problem and turned out the switch was accidentally turned off. Good luck
Nov 28, 2015 | HP Computers & Internet
Wireless adaptor broken!?
Alot of times you can go into the properties of your wireless card and clear from the list all the access points you have connected to recently and in the past and it will help.Also check to be sure the wireless card is turned on.I've found that internal wireless cards tend to fail after a while due to heat and use.I would replace the card if clearing it of it's memory doesn't work.Also check to make sure that both antenna's are connected properly to the card in case they came loose.I tend to think the card is bad though.
Aug 28, 2012 | Toshiba Computers & Internet
I just bought and set up a LaCie Wireless Space 1TB as a NAS + router but can't get several computers to connect wirelessly to it. I did get one HP laptop running windows XP to connect just fine. But I...
Is this your first router or you are replacing an existing one with this? If you had a router setup before don't name the wireless network the exact same as your old one unless you go into your wireless properties on all your wireless machines and delete saved profiles.
What kind of security are you using on the wifi? wep, wpa wpa2? If you are using wpa2 and have not updated all your computers to the latest service packs for windows you can have some issues as well. Some routers don't work well with ps3's, try setting the router security to wep and make a ten digit password.
Also the Dell XPS M1530's are known for bad performing wireless cards. You may be able to obtain an updated bios firmware from Dell's website to help fix this though i'm sure it's not the cause of why you can't connect to this router.
See if this helps, if not respond and I will give some more tips.
Chris
Aug 24, 2011 | Computers & Internet
My wireless connection is not working on my inspiron,what should i do?
Cheapest steps first, getting more progressively expensive as the list progresses:
1) Upgrade the BIOS for the system, available at support.dell.com
2) Upgrade the chipset drivers to the latest version, same website.
3) Upgrade the wireless card drivers to the latest version, same website.
4) Re-set the wireless antennas. Usually you can access the WLAN mini-PCI card at the bottom of the systems. It will have two small wires connected to it, one white and one black wire.
5) Re-seat the wireless card. It's like a large RAM SO-DIMM chip, snap-in and out.
6) Perform a system restore (hopefully it doesn't come to that)
7) Re-install windows
More expensive:
8) Replace the WLAN card.
9) Replace the system board.
Apr 19, 2011 | Dell Inspiron Mini Nickelodeon PC Notebook
Sometime ago, i had accidentally dropped my lappy on the ground, causing the hard drive to malfuction. i later replaced the laptop's hard drive but now, its wireless LAN dont work properly. i mean i can...
First check if its a drivers issue.. Unistall the drivers and reinstall the latest drivers from the support website of tashiba... Then try to take the WLAN and reinsert it.. Try to get all the wireless networks again and try to connect.. If the issue is not fixed you may have to replace the WLAN card....
Sep 20, 2010 | Toshiba Satellite A135-S4527 Notebook
Laptop not connecting to wireless network
Don't wait tell you laptop is defective, at least buy a new wireless lan before its too late.
Sep 30, 2009 | Dell Inspiron 5100 Wireless Mini-pci...
Intel Pro wireless modem won't connect to my wireless router
Check whether the drivers for the motherboard is installed for the wireless Adapter card if it is onboard or if it is a PCI wireless card please reinstall the drivers using the software which came with that card. Thanks. It should work.
Jul 29, 2009 | Intel PRO/Wireless 3945ABG Network...
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
Jun 21, 2009 | Linksys Wireless-G Broadband Router
My wireless internet shows connected, but it won't display a page
My Dell Inspiron Mini 10 would not connect to wireless Internet. Tried all the fixes but only restore to previous date worked. Last time I restored I got message: "Windows could not start because the following file is missing or corrupt: <Windows root>\system32\ntoskrnl.exe. Please re-install a copy of the above file." I could not find any way to fix this so I tried to restore to original factory. I followed directions, f12 boot from CD but when I get to "Agree to Licensing Agreement" none of the keys work except ESC. I was able to get on the Dell Tech Chat at http://support.dell.com/support/topics/global.aspx/support/chat/hardware_chat?c=us&cs=19&l=en&s=dhs (you need your Service Tag) tried same steps I did but keys would not work so they sent me a new hard drive that I can install myself.
Evidently there is no way to fix this. Tech says wireless will work with new hard drive. I hope so.
Apr 01, 2009 | Dell Inspiron 5100 Wireless Mini-pci...
Dell Inspiron 5160 Notebook Logo
65 people viewed this question
Alun Cox
