Volume on my lcd tv is stuck on full but there is no sound.
Polaroid 40in lcd tv
Products : TL Series (LCD)
Models : TLA-04011C
Is there a way to solve this problem from my end with out having to take this unit to a tech.
What I have done so far is to unplug the unit from power and everything else. I looked for some sort of reset switch but did not find one.
Thank you, Jason.
  • 1 more comment
  • jaybone_asc0 Nov 11, 2008
    is there anything else it could be.
  • jaybone_asc0 Nov 12, 2008
    Thanx. I will be taking it to a tech.
    forgot to throw this in, once and a while it goes back to normal. the volume level indicator disappears like there is nothing wrong.
    who is the tv tech man and was his info any different than yours
    President:
  • 2,712 Answers
Since you already tried a hard reset (unplugging from power source) and that did not help, the only other thing to do is:
1. Get the remote out of the way (or remove batteries) and try the volume controls on the TV. If it works, then its possible that the Vol Up button on the remote is stuck. If it does not work, insert new batteries in remote and check. if you have the same issue, there could be a problem with the volume circuit.
In this case, i wouldn't recommend opening the set to look for faulty caps / loose connections etc, if you have no prior experience repairing TV's. There are high voltages inside that could kill, even with the TV unplugged. Best get a repairman to diagnose and fix the problem for you.
Posted on Nov 12, 2008
    Scholar:
  • 112 Answers
It can only be either a stuck button or a bad board. Seriously, the speakers are fine if the volume is al the way up. The tv is working fine, so it is a stuck button or a bad board.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Hi was there any spillage? have try reducing ur volume from ur remote control? well,unplug for about 15 minutes, scrol tru menu/ setting & set back to factory reset. if all this did not help ,the suond moudle has to be replace
Posted on Nov 11, 2008
  • olayoju victor Nov 11, 2008
    try change ur channels or press all other buttons on the tv tosee if there functioning at all if not clearly examing ur volume control button for possible stuckbut ,if other buttons work fine .u have to check ur sound moudle for tech troubleshooting
    Genius:
  • 1,847 Answers
I defer to TV Tech Man's answer, after all he fixes these things for a living. But my guess is you are right the buttons may be stuck. But it could also be a bad integrated circuit that is intermittent or bad power supply voltage to that circuit caused by a dried up capacitor or a crack in a circuit board.
  • Legin Varghese
    Legin Varghese Nov 11, 2008
    you can check for the struck button if any, else will require a qualified technician to look into the tv physically.
    Sergeant:
    Novelist:
  • 196 Answers
Make all the settings in the menu ON by selecting.as the volume setting must be made OFF by mistake.
  • 2 more comments
  • mmechanics Nov 11, 2008
    also check if any of the button got stuck in the remote control.and if there make it proper.
    remove the battery of remote and reinsert.also try replacing the battery.
    also try pressing all the buttons on your remote continuosouly for several minutes.then try.
    The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker,
    cloth covered, cover, disconnect cables. TV will work but
    only with remote.
    pushing the Up and Down volume controls on the TV panel.not with the remote control.then shut off the tv and then ON the tv and then try using remote control.
Tv's sound is not coming through but the tv's sound test is working
Go into the sound menu and make sure the speakers are set to the TV , or the audio system you are using.
If they are turned on , then reset the systems sound settings to clear any previous settings .
The preset volume may be set too low and you are using your surround systems volume controle?
try turning up the volume on the set manualy... ?
Sep 29, 2011 | Samsung 40IN LCD 1920X1080 30001 400UX2...
Tip
Polaroid FLX-374 Service Manual Download
Download Polaroid FLX-374 LCD HDTV Service Manual
Models: FLM-2632 / FLM-2632M / FLM-2634B / FLM-3232 / FLM-3232M
Models: FLM-323B / FLM-3234B / FLM-3732 / FLM-3732M / FLM-373B
Models: FLM-3734B / FLX-374
Have you misplaced your Polaroid FLX-374 LCD HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLX-374LCD HDTV Service Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Polaroid FLX-374 Manual Download
on May 01, 2010 | Polaroid FLX-374 37 in. LCD TV
Tip
Download Polaroid FLX-374 LCD HDTV Manual
Have you misplaced your Polaroid FLX-374 LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLX-374 LCD HDTV Users Guide?
Follow this link
I hope that helps.
_____________________________________________
I have a polaroid 15.4" LCD TV. The blue light
i think this can repaired, change the lcd tv screen it will work, your lcd was broken at all
Jan 22, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
At my Polaroid LCD TV the sound disappears for a
Go to menu reset the sound back to factory setting,should solved this problems.Not then ur Main Tuner signal board have problems.
Mar 10, 2010 | Polaroid FLM-3201 Television
I want to buy a 40in 1080p LCD HDTV. I went to
not even close! this is just another routine to get more money out of you. when you recieve your LCD tv there is a menu that you an access that will allow you to perform this yourself.
Oct 28, 2009 | Sony 40 in. LCD HDTV
No sound on my polaroid tv tlu-o1541 cu
Hi, Try to reset the tuner settings to cable or what ever your are using for a signal. and run the auto search again. Thanks.
Sep 22, 2009 | Polaroid TLA-01511C 15 in. LCD Television
POLAROID 37" TV - VOLUME STUCK ON LOUD - CAN'T TURN UP OR DOWN
sound like the volume is locked out you can access this in the main menu to unlock it
May 29, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
No sound when Wii is switched on
DID YOU TRY PLUGGING YOUR COMPONENT CABLE INTO A SCART ADAPTOR FOR YOUR TV...THIS SHOULD FIX IT FOR YOU.... I TAKE IT YOUR TV IS A 5 SERIES OR A 6 SERIES SAMSUNG.. GREAT TVS HAVE ONE MYSELF, BETTER WHEN MORE CHANNELS ARE BROADCAST ON FULL HD BUT...
Jan 11, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
