Question about Balance CM2019 19" LCD Monitor
Creeping black pixel line.
I have an IC Power CM2019 monitor. Just the other day I noticed what looked like scatches on my monitor screen. Closer look it's in the pixels. Problem is that it's growing around the right side of the monitor. Don't know what it is or why. My system works fine, thought it was a diaplay adapter, but completely unhooked the monitor from the system still exsits. Any suggestions? Also can't seem to find a website for the manufacturer. Help!!!!!
  • mrtaz187 Nov 12, 2008
    I'm not so sure though. I mean it has gotten worse within the past 48hrs. Could it be anything else?
    Scholar:
  • 44 Answers
Hi mrtaz187,
Well it sounds like the monitor pixels are starting to fail. Once you notice the pixels starting to fail, you will probably notice that over time it get worse. I had the same problem on one of my monitors too. I think it's time to replace that monitor. On the good side, new monitors are relatively inexpensive. You might think about getting a name brand for your new monitor too as it will usually have a warranty for problems like this in the future.
Hope that helps,
Take care,
Michael
Posted on Nov 11, 2008
What does it mean by dead cells?
I assume this is related to your LCD monitor.
I think you mean dead pixels. The LCD monitor has tiny pixel elements, one for each red, blue, green color and each one of these colored pixels are turnes on by a transistor. When a transistor fails then the colored pixel it controls does not light up. This is a dead pixel and it shows up as a tiny black dot.
If the screen displays a blue screen, a dead blue pixel will appear as a tiny black dot in the blue screen.
You normally would not notice a few dead pixels unless they are grouped together.
Sep 20, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
Re: Creeping black line
Hi mrtaz187 -
Well, the pixels can go bad on the LCD monitors and from what you are explaining, it certainly sounds like this is the case on your monitor. I wish that I had better news for you but the monitor will have to be replaced. Sorry. I know that Walmart has had these monitors on sale in the past and they have offered a 13 month warranty. If you could return it from where you bought it (under warranty), that would be the best solution... otherwise it will need to be replaced because usually the bad pixel problem grows worse over time.
Hope that helps,
Take care,
Michael
Nov 12, 2008 | Computers & Internet
HD70 additional information on vertical problem
well the vertical ic on the main board need to be replaced....
the will need de-soldering the chip and replaced by a new one
Jun 02, 2008 | Optoma HD70 DLP Projector
CM2019 LCD MONITOR NO PICTURE
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 17, 2008 | Balance CM2019 19" LCD Monitor
Line
Good Luck!
Dec 27, 2007 | Balance CM2019 19" LCD Monitor
Having a problem with my monitor
9 times out of 10, the vertical output IC I501 ( TDA1675 )and resistor R574 (1 ohm, 1 watt) are bad...The resistor opens up because Vert. IC has gone bad. IC doesn't get 30 volts from the power supply, hence , no vertical sweep....
Don Kirsch Questar III BOCES
Mar 18, 2007 | Princeton Digital Arcadia AR2.7AV 29...
Balance CM2019 19" LCD Monitor Logo
117 people viewed this question
Top Balance Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
