Question about Samsung SyncMaster 510N 15" LCD Monitor
Monitor black outs,displays set optimum resolution
Monitor blacks out about 20-30 minutes after turning on.inspite of setting resolution and frequency the problem persists.
    President:
  • 2,961 Answers
Sounds like a setting problem in the power options, go to Start>Control Panel>power Options, then ensure your monitor stand by time is set to never.
Posted on Nov 09, 2006
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
When i turn it on it says out of range and i have a black screen
Hi, The reason behind the out of range (frequency of monitor) because the video display adapter is trying to set resolution more than what the monitor (screen) is capable of. In this case, try to boot your computer in Safe Mode using F8 function key while starting your computer. Once you are in safe mode, try to decrease the resolution of monitor to the lowest resolution level and apply the settings. Now try to boot computer in normal mode once again, you will get the settings which you have applied in safe mode. Adjust the screen resolution accordingly till the settings work with the monitor (screen).
Cheers!
Mar 01, 2010 | Microsoft Windows XP Home Edition
Frequency out of range 11khz/ 119khz message
The PC is sending out the resolution that is too high for the monitor to handle, you need to set the resolution of the PC to be the native resolution of the monitor and set the refesh rate to be at 60Hz.
Jan 12, 2010 | Envision H191W Monitor
My iLo moniter keeps telling me that my signal is out of range, i don't know what this means or how to fix it?
It means that the screen resolution and/or refresh frequency that have been set in your computer's display properies are beyond this monitor's capabilities.
You don't specify your system type or exact monitor model, but you have to:
1) Find out the optimum (native) resolution of your monitor
2) Go to Display Properties and set that resolution. Obviously you will have to make the monitor show something in order to do it - if we're talking Windows, you'll have to boot to Safe Mode.
Dec 12, 2009 | Computers & Internet
Out of range message
This is caused by a resolution and/or refresh frequency setting in your computer's display properties that exceeds the values supported by the monitor.
Find out the optimum (native) resolution of your monitor (in case of AMV 17V5 it will be 1280x1024 pixels), and supported refresh frequency (usually 60Hz for LCD monitors), and set your display properties to these values.
Nov 23, 2009 | Amptron AMV 17V5 17" LCD Flat Panel...
''not optimum mode'' icon continues to show
this is not the problem with your monitor. Pl boot your computer with enable vga mode. in vga mode set your resolution into 1680 x 1050 with which color mode you need set ok
it will be ok. After restart, your computer will ok. even the problem retains, pl reinstall the video driver and try again. give me ur feedback
Aug 25, 2009 | Samsung SyncMaster T200 LCD Monitor
Monitor displays Msg. frequency out of range, screen is black
Start your computer and press the F8 when the manufacturer's logo screen is showing. This will bring you to the Windows startup menu. Pick "start in VGA mode" and windows will start up with video settings you monitor can handle. Then you can change your video settings so Windows will start normally with your monitor.
Mar 31, 2009 | Compaq Computers & Internet
Display Problem
video card may not be capable of that resolution and color depth, check your video cards max resolution and color depth.
I have several lcd monitors that are 1280x 1024 and they do not need drivers to work. the video card must be capable of generating that resolution.
Jun 06, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Not optimum mode
change windows resolution and refresh rate to 1024 X768 and 60 Hz.
start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
Screen blacks out
OK you need to try this monitor on another pc so as to write off a faulty graphics card. If your settings on monitor match the pc and youve tried the auto settings button, there is a faulty lcd for replacement.
Nov 10, 2006 | Samsung SyncMaster 510N 15" LCD Monitor
Samsung SyncMaster 510N 15" LCD Monitor Logo
101 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
