Question about Daewoo DTQ-20U9SC TV
I have a blue screen on my Daewoo tv
Direct TV tech says stuck on input channel
2 Suggested Answers
  • 88 Answers
SOURCE: Problem getting cable to tune in to Daewoo TV
you need to get back origenial daewoo remote control to do the setup input & output. good luck!
Posted on Jun 12, 2008
How do you change contrast on Daewoo DVQ 19H1FC TV?
Use the remote to go to the tv setup menu and change the contrast there.
Dec 21, 2013 | Daewoo DTQ-19V1FC 19" TV
TCL Blue Screen "No Media"
I HAVE FOUND THE ANSWER!!!! I just bought an TCL TV last night and was given the wrong remote. Screen was stuck on "no media" screen BUT I noticed that when I turn the tv on and keep pressing the menu button, the menu screen would pop up for a half second before the no media screen popped up again. So I knew it was able to access it. SO, it took a few try's and with no exact method I turned the tv on, waited til I saw the TCL logo and then simultaneously pressed the menu and channel up button repeatedly. It will open the menu for you and allow you to move between the input channels!!!! It WILL take a few tries to catch it but it worked!!! Your welcome!!!!
Dec 29, 2012 | Televison & Video
Ds25284 sayno tv
If you have its remote control, it will input option buttons like AV/TV etc. Press it to select correct input. If you do not have its remote control, Check whether there is a 'Menu' button on the front panel of the TV. If yes, get into its Menu; surf through; come to input selection window, and select the input to TV there.
Jun 14, 2012 | Sanyo Televison & Video
Tv is stuck on blue screen
i would suggest cycling thru the inputs- av1 av2 rgb hdmi. blue screen is indicator of no input.
Apr 07, 2009 | Televison & Video
I need to find out what channel my tv needs to be on
Try the input button on the TV remote it should only allow you to change to the inputs available.
Jan 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
No picture, blue screen
Use the TV input selector to select the right channel, that should fix it.
Jan 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Daewoo DVN-14F6N
Same problem...Went to Goodwill Store, they usually have a large basket of remotes. I found a Daewoo remote for a TV only, HOWEVER on the bottom it has a AIR/CABLE button. The remote doesn't say Daewoo on it only..."Remote Controller R-25B03". The rest of the button of course work with the TV portion of the DVN-14F6N.
Sep 17, 2008 | Daewoo DVN-14F6N 13" TV
Can not get the image back on my astar hdtv when I choose the option
First check Tv menu comes on screen?
Connect DVD Player at any a-v input and confirm picture on tv. This will confirm that tv has no problem except in tuning circuit.
Now check Antenna / cable hooked up in RF input of tv properly.
Perform Auto-Search / Auto-Tuning / Auto-channel on TV menu and tune all available channels.
Still blue screen? means TV Tuner looks bad.
Sep 16, 2008 | Astar Televison & Video
Power went out while tv & Direct TV was on
The garbage on your unused channels are not important, just artifacts from signals not strong enough to produce a picture.
The 'blue screen' on #3 is what many sets use when they sense they are connected (terminated) to 'something' but not receiving any signal.
If sounds a lot like DTV's receiver took a hit.
If you have a second set you can borrow or drag to the receiver, try it first but I don't think it is your problem unless the cable input on it was zapped.
Jul 12, 2008 | Televison & Video
Mar 02, 2008 | Daewoo DTQ-20U4SC 20" TV
Daewoo DTQ-20U9SC TV Logo
357 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
