Question about Sceptre NagaIII X30SV 30 in. HD-Ready LCD Television
Sceptre NagaIII X30SV 30 in. HDTV-Ready LCD Television powers off
This set turns off sound and picture after about 10 minutes.  I can unplug it from the wall and it will work for another 10 minutes. if it is the power supply and it needs to be replaced do you know where I could get one and what I should look for?  Are there any tests to see if the power supply is the problem. The company support is less than helpful. to send them the set would cost more than the set is worth. But that is their only solution.
Look at the top right venting louvers above the power cord receptacle. A green LED glows when the power supply is providing voltage to the TV. If the LED is off, you'll have to check the wall receptacle for 110 Volts, check the power cord and check to see if the power supply is getting 110 Volts. If you have voltage in and nothing out of the power supply then buy a new one off E-Bay. Quite often electronic devices will "turn off" when warmed up because of expansion of a faulty connection and "turn back on" after it has cooled. Also, their could be a safty thermo switch within the power supply that is sutting things down because of over heating. So, it's a **** shoot. I fixed mine with an E-bay AC adapter.
Posted on Mar 01, 2009
It turns on but dosent stay on it turns its self off
it ie a ground proglem. confirm all connections to be true, ie/ kinda tightenthem. Then unplug the thing and plug it back in and presto!
Aug 29, 2010 | Sceptre NagaIII X30SV 30 in. HD-Ready LCD...
My Sceptre X30SV had no power. I unscrewed the panel where the power supply is (in the back of the tv) and unplugged the power brick. Shortly after I plugged it back in and it has worked for the past 24...
Replaced all the capacitors in the power supply is the best bet to solved the power shut down.Becauce capacitors is unprodictable very small amount virable dip in Micro farets the whole power board will shutdown.Capacitors testing with the voltage meter is very hard to determine the micro farets in and out went power in use or power it off.
Feb 10, 2010 | Sceptre NagaIII X30SV 30 in. HD-Ready LCD...
My sceptre won't show my pc screen, it keeps going to black screen...when I push source button my pc flashes on screen but then goes black...
I believe you are trying to display too high of resolution to this screen.
Try using a lower resolution. If you had 1024x768 then try 800 x 600.
Nov 19, 2009 | Sceptre NagaIII X30SV 30 in. HD-Ready LCD...
Screen goes black after powering up sound is just fine.
The backlight video board inverter it dead,need a new one.
Oct 03, 2009 | Sceptre NagaIII X30SV 30 in. HD-Ready LCD...
TV will not power up
My Sceptre X30SV had no power. I unscrewed the panel where the power supply is (in the back of the tv) and unplugged the power brick. Shortly after I plugged it back in and it has worked for the past 24 hours. I'm thinking my power supply is on its way out. I have purchased a voltage meter, how do I go about testing the power brick?
Thanks for your help in advance!
May 28, 2009 | Sceptre NagaIII X30SV 30 in. HD-Ready LCD...
Where can I get inverter for X30SV-Naga III
when you turn it on there is a saying in the right hand corner saying tv off
Aug 29, 2008 | Sceptre NagaIII X30SV 30 in. HD-Ready LCD...
Hello...
Unfortunately, this is still a project.
Let me get back to you about this.
Back to you soon. I will get back on this tonight.
Basil
Mar 28, 2008 | Sceptre NagaIII X30SV 30 in. HD-Ready LCD...
X30SV-NAGA III
So here is the scoop, sceptre told me to fill out an RMA request, fax it in with CC# and it would cost 250.00 as long as it was not the display. Upon approval of the RMA they asked for an additional 80.00 return shipping fee to be added on to the 250.00. Plus it would cost me 35.00 to ship it from Missouri to City of Industry, CA. So as you can tell it would cost me 365.00 just to send it.
Oct 16, 2007 | Sceptre NagaIII X30SV 30 in. HD-Ready LCD...
Sceptre NagaIII X30SV 30 in. HD-Ready LCD Television Logo
272 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
