Question about Poulan Pro 22" Self Propelled High Wheel Mower
Hydristatic slips my 20hp poulan riding lawnmower slips after 30 minutes of use. is there a fluid to put in it it looks like there is a spot for it. if so what goes in it
    Problem Solver:
  • 8 Answers
Try running it to warm up the fluid, drain the old stuff out and replace with a quality hydrostat fluid recomended by the mfg. Also change the filter if so equiped. you should be able to get ahold of the mfg. online or start here http://www.poulan.com/poulanpro/indexAction.do?id=default
Posted on Nov 15, 2008
I have a poulan riding lawnmower dont know exactly what one it is at a camp but the question i have is why does the tractor jum when you leave the clutch out especially in 3rd or4th gear.h
If the tractor lurches or jumps when you let the pedal out it could be one of a few problems. The most likely is a chunk missing out of the belt. Lower the deck all the way down and look under the chassis for the ground drive belt and inspect it. Next it could be loose or bad pulleys. If the transmission input pulley has worked loose or one of the plastic flat idler pulleys has froze up and burned a hole through it then it could be making things skip. Again with the deck all the way down lock the brake. this will slacken the belt. Reach up and grab the 2 flat idler pulleys and check that they turn free and feel for grooves worn into the flat. Grab the transmission pulley and wiggle it. Is it loose? Turn it. Does it feel chunky or smooth? Lastly, it could be a worn input shaft bushing causing the worm and pinion to slip. Especially if in your last test the trans pulley felt chunky. While the brake is locked slide the belt off the two idler pulleys so the belt stays slacked with the clutch out. Put the transmission in gear and turn the transmission pulley by hand. The tractor should start moving. Keep turning by hand and see if there is a spot that it slips. If so you will have to remove the tranny, dissect it, and replace bad parts. Input shaft bushing kit is about 50 bucks.
Hopefully its a worn belt... one last thing just came to me... check the drive pulley on the crankshaft. If the pulley is bent in a spot. Say; from trying to force a new belt on past the belt guides. Then the pinched spot will grab the belt every time it comes around cause a lurching.
Aug 06, 2014 | Poulan 17.5HP Lawn Tractor 960120110
WHAT SIZE DRIVE BELT I NEED FO 30" RIDING LAW MOWER ? MODEL NO P01230lt SERAL NO.011310A001123 model no PO12530lt 12.5 HP
We do not have any info on this site
Just a chat room
Take you info to a small equipment
dealer/repair shop & they can look it up
for you
Jul 06, 2014 | Poulan Pro Lawn Tractor 2006 and Newer...
We are needing a diagram on how to put a deck belt on a 42 inch yard machine
Needing a diagram on how to put drive belt on 42" 20hp poulan pro lawn mower
Jul 23, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Riding lawnmower 42 in husqvarna i changed spark plug and gave it gas and charged the battery it acts if it wants to start but it just doesnt turn over
Have you checked the air filter? Look at the filter and hold up to sunlight if you can't see the light thru the filter then replace.
Sep 07, 2010 | Husqvarna 20HP Hydrostatic 42" Cut Riding...
Put Lawnmower on its side and changed blade. Put
Most likely you have flooded the cylinder with oil. You can try this and see if it helps you out.
Remove the spark plug, clean and dry it with carb cleaner, let dry, spray carb cleaner in the spark plug hole and thoroughly flush it out. Let is sit this way for about 20 minutes. Reinstall your spark plug and see if it will start up for you. If it does you are done if not go to an auto parts store and buy some starter fluid. Spray the fluid with just short burst into the air cleaner. Try to start it. Repeat and it should stay running in a couple of tries.
Jun 15, 2010 | Poulan "Poulan" Push Mower
LOOKING FORWARD TO PURCHASING A POULAN RIDING LAWNMOWER. AS A FEMAALE I AM A BIT APPREHENSIVE ABOUT A RIDING LAWN MOWER. I HAVE USED A SELF-PROPELLED FOR ABOUT 30 YEARS. AM I MAKING A GOOD CHOICE?
If you like driving cars, riding 4 wheelers, or just plain love the outdoors, the a rider is definately the way to go! Everyone loves the joy of a riding mower no matter what age. You will definately will fall in love with cutting your lawn. Use the rider for the big stuff and push mow the little hard to get places.
Jul 22, 2009 | Garden
My poulan riding lawnmower will not roll. The
Hi..my name is Keith..and it sounds like the neutral rod on the back of the mower needs to come out further to fully disengage the transmission so you can roll it..it should have an adjusting nut on the rod..and i would turn the nut in a couple of turns until the lawn mower will roll..i hope this will help..if not please write me back
Jul 12, 2009 | Garden
Poulan Pro 22" Self Propelled High Wheel Mower Logo
152 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
