Dell (C35096003) 350-Watt Power Supply Logo
Anonymous Posted on Nov 11, 2008
My laptop is not recognizing the power supply, power almost out!
Upon returning from Asia (220v) my laptop will not recognize 2 different power cords. what is not resetting now that i am back in USA?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
359
Points
2nd charger bought overseas was causing a short
Printer not being recognized by computer
Sir/Madam
1. Is the printer turned on?
Make sure the printer is turned on.
Make sure the power cord is securely plugged into the electrical outlet.
Test the power by plugging in the power cord of another electrical appliance to an electrical outlet and turn it on. If the power to the other electrical appliance comes on, the printer may be considered to be faulty.
If this product is recognized:
Close this page to return to the installation window.
If this product is not recognized:
Proceed to the next step.
2. Are your computer and the printer correctly connected?
Make sure the USB cable is securely connected to the printer and to your computer and check that the USB cable is not damaged nor badly crimped.
The printer will not be recognized during the driver installation if connected to a printer switch or the printer buffer. If this is the case, try to directly connect the printer to your computer using the USB cable.
If you are connecting the printer to your computer via a USB hub, connect the printer to the first-tier hub from your computer. If the printer driver is still not recognized on your computer, try to directly connect the printer to your computer without the USB hub.
If you are connecting the printer to your computer via a USB hub, make sure the USB hub device is recognized by your computer.
3. Does your computer provide USB or IEEE 1394 support?
If Still Your Problem Is not solved Then Click On Below URL
http://files.support.epson.com/htmldocs/r1800_/r1800_rf/dset_1.htm
Or
Still You have problem Then please Follow Us On HP Printer Support
2answers
Laptop wont recognize charger
Maybe you did damage a component due to overheating? What caused the Laptop to overheat? Does the battery work on another laptop?
2answers
I will be in Asia where the power is 220. Will I need a transformer/converter to use my laptop? My digital camera says it will work on 110 or 220 and a tranformer will damage the camera. Is this the...
The power cord for your laptop is a transformer. However, is is in all likelihood, meant for use in the U.S. only and does not have a selector for 220v. You will need an power cord that is meant to work with 220v. I'm sure there is one available for your laptop. Just make sure that when you purchase it, that the output is rated the same as the one you use now and you will have no problems.
1helpful
My Dell Inspiron 1525 battery won't charge. The plug powers the PC but is not recognized by the computer and will not charge the battery. I have tried replacing the battery and cord, but no difference.
hi , it sounds like internal hardware problem , if you replaced battery and power supply then next the mother baord power relay for charging battery is out . you have take too a tech. . it will be high in price . thanks hope i been some help
Laptop does want to turn on any more
Try a different AC adapter. If your computer doesn't recognize that one either, then you may need a replacement DC-in Board.
Dell Inspiron Laptop Not Recognizing Universal Power Cord
some universal adapters work.but a dell power supply would be better for you.at least you know its the proper one. ebay search there.
Drive not recognized by desktop.
Try checking your power cord adapter.
I found the same problem was with the cord.
Luckily, I had another Acomdata HD cord to check the problem.
7helpful
2answers
Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Power supply on Gateway Laptop is not recognized, will only run on Battery
YES, take it back.
It should still be on Warranty. Anything that you try to do will void the Warranty.
Note: Power supplies for a laptop are notoriously expensive.
3answers
Acomdata no longer recognized
Check your USB Cable connected possible lost contact problem or the power supply of your optical drive.
Hope this will be helpful to you.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
