Question about Hughes HDVR2 with 105 Hrs DirecTV DTV Receiver
The Screen shows "welcome. Powering up....." and is stuck
The welcome screen has been stuck like this for 6 days. I have tried unplugging it and unhooking all the cables, but nothing works. I can't get past this frozen screen. Help!!
  • 1 more comment
  • big eee Dec 24, 2007
    Yes I have the same problem with my unit.
    I unplug it for a few days it fail to rest itself.
    www.bigeeeinpa@aol.com
  • Anonymous Jan 10, 2008
    I had powered down all the equipment for a vacation. When we started
    the system back up the TV is stuck on the Welcome. "Powering up..."
    screen
    I have an older unit. Maybe it is time to upgrade...
    Scholar:
  • 27 Answers
Direct TV has been working on numerous software issues. Some patches have been downloaded for TiVo that in some cases have caused problems. In your case, it is more possibly an indication that the hard drive is not running and you have a possible hardware failure. When you rebooted and became stuck on the "welcome, powering up screen", it could be an indication of a software glitch or a hard drive failure. I would go with a hard drive failure. Since this is a Hughes Receiver like mine and you own it, you could try a drive swap with another TiVo drive out of a like receiver. If one is not available, you may have to purchase one. Pre-configured and initialized drives are available from www.weaknees.com. I have no interest in them, but that is where I buy Tivo pre-configured Hard Drives from. You can get replacement or upgrade Maxtor Drives preconfigured from them for this specific brand and model of TiVo DVR. A drive swap would be cheaper troubleshooting. There is also a possibility of a problem with the built-in IDE controller or the power supply on your receiver which can't be determined until you do swap out with a Known Good Drive to eliminate a hard drive problem. If you are able to swap it out and If the good drive works, then your old one has corrupted data and would need to be re-initialiaed and reloaded. If it is an older smaller (35 hour) drive, you would be better off with a new replacment since the loading is a somewhat lengthy process and must be done on a computer running the Linux Operating System.
Posted on Mar 02, 2007
SOURCE:
My lg blue ray player is powering up and all that isoniazid the screen is powering off
if you have basic knowledge in electronic repair then you can do a check in your player. first you will need to unplug the unit for safety. then unscrew to remove the cover now look for the power supply board which supply the main board and mechanism. try to find any unusual in the board like bulged component parts or any burnt parts, as will as in the main board. if none everything looks fine, at this time you will need a trouble shooting which need to used device like digital tester. you must check weather the supply dc voltages coming from the power supply board are stable if not it will not turn on properly.
Mar 02, 2014 | LG BD390 Blu-Ray Player
Video 1 stuck on "Welcome. Powering up..." screen
well thats some kind of tricky :(
and how much time do it get? when say powering up? did you check that?
Feb 03, 2008 | Fujitsu P55XHA40US 55 in. Plasma...
After powering on the TV, a "Dell" message pops up
The set is stuck in "Power On Self Test", aka POST.
Try unplugging the set from the wall for 15 minutes (to allow any stored internal power to bleed down), plug it in and try it again.
Feb 03, 2011 | Dell W3201C 32 in. LCD Television
My dvd player rdr-hxd860 seems to be frozen on 'welcome'
I've had the same problem. I've actually unplugged the unit and it's been unplugged for probably about two weeks. When I reconnected the power this morning the problem persisted where the DVD Recorder was stuck on the Welcome Screen. As a last ditch effort I pressed and held the power button for 10 to 15 seconds until the word "Welcome" dissapeard of the screen and back on. This seems to have reset the unit. I know I should have tried this a long time ago. So much for reading the instruction manual! I'm just glad it's working again!
Nov 17, 2009 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
My dvr is stuck int the welcom pwering up screen
May be a little too late, but usually the problem is the Hard Drive with that. There are several places online to buy a new hard drive with the proper software already installed or you can buy InstantCake and a blank hard drive and make your own
Oct 28, 2009 | RCA DVR40 DIRECTV DVR with TiVo
TIVO is stuck on start up on a sony svr-3000
It sounds like you need a new hard drive. I'd recommend you visit this TiVo repair website.
Sep 04, 2009 | Sony SVR-3000 TiVo
Powering up
Leave the box unplugged from the wall for an hour then try to power up again.
If it doesn't please post back.
Good luck
Jun 01, 2009 | Toshiba SD-H400
Uniden TRU8885-2 Restarts every time an incoming phone call, start showing the Welcome message ....
YOUR batteries are bad and not giving full current to phone.Clean charging contact and see battery gets full charge. IFthe battery indicator will show full charge due to voltage but once if you remove battery and put it again indicator will be minimum. then replace batttery.
Oct 07, 2008 | Uniden TRU8885-2 Cordless Phone
"Welcome. Powering-up " on screen and cannot turn it off manually or remotely
If you have a TiVo that is stuck on powering up, you likely have a bad hard drive. See this page for more information about a TiVo that is stuck on powering up.
Oct 05, 2008 | Sony SVR-3000 TiVo
Directv HR10-250 Reboots by itself, then get stuck rebooting
I found unplugging it helped.  Problem with that is that sometimes it deletes newly recorded shows.
Apr 11, 2007 | Directv HR10-250 DTV Receiver
Open Questions:
Hughes HDVR2 with 105 Hrs DirecTV DTV Receiver Logo
1,882 people viewed this question
Top Hughes Televison & Video Experts
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you a Hughes Televison and Video Expert? Answer questions, earn points and help others
