Question about Canon i950 InkJet Photo Printer
Colors are not printing properly
The black ink seems to be leaking into the yellow. Anything we print with yellow comes out muddy at best but generally closer to black. the yellow ink cartridge has black in it after just a couple of uses (after replacing the yellow).
Looks like your printer head is in need of replacement
Posted on Dec 16, 2008
Canon pro 9000 printing not printing vibrant colors
I've had 5 Pro9000 & Pro9000 II's so far. Mechanically sound and fairly heavy duty. Mostly by default they print muddy or muted, with unsatisfactory reds and yellows. The default settings usually suck. I have had to develop my own driver settings and save them to printer profiles for individual situations. There is a lot of control in the driver settings and I recommend making your own color charts for reference, displaying the settings on each page. I also recommend regular nozzle checks and calibration. Avoid cleaning via the driver utility as this wastes a lot of ink, which is all deposited on the bottom of your printer and eventually has to be dealt with. Instead, remove and soak the head. Completely dry before reinstalling.
Jun 26, 2014 | Canon PIXMA Pro9000 Printer
Wrong Color Printing
Type "print nozzle test" in the search box and click Search. Perform a nozzle test, and if the colors match what are on the instructions, your print head and inks are OK.
(1) If the print head and inks check out OK, type "wrong colors on print" in the search box, and you will see several troubleshooting steps you can try.
(2) If the nozzle test colors are off, confirm that you are using BCI-6 inks for all three colors and the small black tank. You should only have a BCI-3 tank in the large black position. If you have all the correct inks, your machine probably needs to be serviced/ repaired.
Thank
Jan 09, 2014 | Dell 1320c Laser Printer
HP ink jet 1200..prints only test page after replacing the yellow cartridge.test page only shows black and blue inks are good.need help.
Important thing: HP inkjet printers having self align technology & its aligns automatically after replacing the ink cartridge/s.In the process of align it will prints align page &it will read it on the model.
Suppose if you replaced yellow cartridge, as usually it will print align page, but if one or more cartridges not printing properly align will not completes. Results every time it will prints the align page when its switching on. Align will completes only when all cartridges/print heads are in healthy condition.. Check the alignpage find out which colors are not printing properly, replace it to over come from this issue. Now you decide what to do?..
Dec 11, 2012 | HP Inkjet 1200dn Printer
Replaced black ink cartridge, ink wont come out
If any of the ink cartridges need to be replaced the printer will not work. Also, if you are printing only black you will need to go into print properties and select black.
Nov 07, 2017 | Brother MFC-465CN InkJet Printer
Muddy prints
I have the R2400 and the photo prints look muddy. I have tried the same picture on another printer and the colors are vibrant. Why the muddy pictures on such a nice printer?
Mar 23, 2010 | Epson Stylus Photo R2400 InkJet Printer
I changed all Print cartridges-Black, Yellow,Cyan,Blue
On this machine you have to install inks with power on and use the ink button and choose replace ink. If you just plug them in it won't register and reset the counts. You may need to run clean cycles at least twice to get proper colors.
Jan 29, 2010 | Brother MFC-5840CN All-In-One InkJet...
Look at your yellow ink cart. if it looks dark or almost black then the membrane in the printhead is bad allowing contamination of the yellow ink. Otherwise the nozzle check print will tell you if colors are missing, clogged or burned out nozzles means you need a new printhead also...
Oct 22, 2009 | Canon i950 InkJet Photo Printer
Black and Yellow do not print even with new ink cartridges
no,, it can be like,, you have used those colors prior usages..
Sep 27, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Yellow Prints in the other colors
Problem seems to be with your Ink Tank(s) or Printing Head. Replace both of them one by one and retry.
Jun 06, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Colour prints coming out with a lilac hue
check whether the printer is in proper mode or not
Feb 29, 2008 | Epson Stylus Photo 950 InkJet Printer
Canon i950 InkJet Photo Printer Logo
137 people viewed this question
old marine
old marine
