Question about Saws
Blade Change for Bosch 1581
I inherited a Bosch 1581 vs, I don't have the manual. The blade is broken in the tool and I can't figure out how to get it out. There is a hole at the top of the handle, does this use a hex, phillips head or flat head. Also do you know if the manual is downloadable. I went to the bosch website and it is not available online. Thanks
    Scholar:
  • 132 Answers
The screw is a flat head but you need a long series screwdriver you have to loosen the screw first then turn the blade sideways remove then place new blade in sideways turn to straight then tighten screw again its not too hard at all best of luck glenn.......
Posted on Nov 12, 2008
Bosch b4300 jigsaw blade replacement
To change the Bosch B4300 blade - If the grey knob does not turn to release the broken blade, you need to use a LONG THIN flathead screwdriver down the center hole at the top. Unscrew until the broken blade is loose. Pull out. Replace the new blade and then screw the it tight through the same hole at the top. DONE.
Jan 25, 2012 | Bosch 1581AVSK Top Handle Jig Saw Kit
I have a Bosch 1587 avs. I am trying to change the blade. I have followed the instructions as per Manual. In the last part I am supposed to hear a click to lock the blade in to position while rotating the...
First unplug tool and lift up on the knob and loosen the spindle lock, insert blade and push up slightly while doing so and twist to align blade with the roller, while lifting up tighten the knob until you hear it click and the blade should be tight and stay in place. Let me know if you need more assistance.
Apr 04, 2011 | Bosch Saws
I have a bosch 1587 vs jig saw i got used. I don't know how to install a blade. I have never had one like this. I turned the top handle the way the diagram showed but I don't think something is working.
In most models at the blade shuck holder is a screw that thigh the blade,unscrew it and change your new balde .
Also Go to this LINK and find the part/diagram that can help you.
Please thumbs back if help is fine,thanks!.
Nov 02, 2010 | Bosch 1587avsp Vs Orbital Jigsaw
Bosch 1581 old style, blade is tightened with a screw driver. The screw to tighten the blade is lost. How to get part for an old style saw or have it repaired?
go to Boschtools.com and you can order online or find a Bosch center near you the part number is 2 603 400000 and it lists for 1.20, let me know if you need more assistance.
Dec 30, 2009 | Bosch Saws
I bought used Bosch-1581-vs, unfortunately parts are missing required to secure the blade. Would you be able to tell me part numbers I need to buy? Thank you in advance.
The only clamp part you need is 2603400000 . It may be down in the shaft already. You need a thin flathead screwdriver to stick in the hole at the front of the handle. This is the bosch part number for their screwdriver for this jigsaw JA1001 .
Sep 15, 2009 | Bosch Saws
Do not know how to replace blade in a Bosch 1581 VS Jig Saw
You need a long shafted flat head screwdriver that fits into the hole in the handle above the blade. Then simply loosen or tighten the screw inside there, and the blade twists 90 degrees and will pull completely out. Reverse to install. Also see pg 7 of instruction manual (click here.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks
Jul 27, 2009 | Saws
Milwaukee jigsaw with blade change problem
a new tool will cost you about 170. You could look for a used on on craigslist.
Apr 21, 2009 | Milwaukee Tool Milwaukee Orbital Jig Saw...
BLADE CHANGING
What's the model number of that saw?
If it's one of the old ones, a 1581 VS or some such, you need a long thin flat-head screw driver that fits through the hole in the top of the handle and reaches down far enough to unscrew (loosen it) the set screw that holds the blade locked in place. Then you twist the blade 90 degrees (perpendicular to the direction of cut), and pull it out. Reverse process for installation, making sure before you tighten the blade it rides in the groove on the guide bearing below.
If that doesn't seem like it's the correct sequence for your saw I apologize.
The Bosch website won't accept any 10 digit tool product numbers due to some glitch in the system, and they made so many variations on that saw it'd make your head spin.
That's the other way some of them loosen up, actually, is by pulliing up the plastic head at the top of the handle and unscrewing it a few turns to loosen the blade.,, Vice versa for install..
Hope this helps a bit!
Mar 14, 2009 | Saws
Blade wont stay in Bosch 1882VS jig saw
ARE YOU USING BOSCH BLADES IF NOT GET SOME THEY ARE MADE A LITTLE DIFFERENT THAN SOME OF THE OTHER BRANDS AND FIT A LITTLE BETTER , IF YOU ARE THEN DO NOT KNOW
Feb 22, 2009 | Bosch 1587AVSK 5.0 - AMP Top Handle Jig...
BOSCH: 1581 VS... BROKEN BLASDE HOW TO REPLACE WITH NEW BLADE
hi there is a hole on the top of the handle at the front when holding it it is just in front of your hand you need a long series flat head screwdriver to loosen turn the blade sideways and out she comes
hope this helps glenn...........
Nov 09, 2008 | Saws
Saws Logo
1,334 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
