Question about Hotpoint RGB790SEHSA Gas Kitchen Range
Dangerous, slippery stove grates
I love my new stove EXCEPT for the very slippery stove grates. Do they make them in non-slip???
  • Anonymous Jan 24, 2009
    We just bought a new Kenmore gas cooktop from Sears and we have the same problem. It would be dangerous if you accidently caught the handle of a pan with your sleeve, for example.
Tappan self cleaning oven
You plobably have the incorrect drip pans that do not have the proper holes for the grates to fit in, I would chech with an appliance repairman, he should have a source for the correct drip pans.
Aug 14, 2013 | Ovens
Im thinking of buying a shower perch but Im afraid my parrot will slip
Don's worry, most shower perches are made out ofnon-slippery materials like rubber so even when its wet, the bird won't slip.
May 14, 2012 | Birds
Hi I love my stove but the cooking grates are difficult to clean. We bought the stove may of 2001. Do they have different ones that are easy to clean. Thanks for your help. Gregg Reutter
Hi, Gregg
Honestly, the grates that came with your GE are the only ones available. The only other solution would be to buy another set.
Please rate me a "4 thumbs" if the information was useful.
Best of luck!
Dec 15, 2010 | GE Profile Spectra JBP95 Electric Kitchen...
Can mulberry boiler/stove version be used without being plumbed in , or will heat damage dry boiler
fill the boiler with dry fine sand.that way it can be hoovered out if you need to connect it later. dont run it dry
Feb 21, 2010 | Kitchen Ranges
How to remove scratches from stove top
use on stainless steel- 3M 7447 pads get at auto parts store or more aggressive 180 grit sandpaper going with the grain of course. For daily cleaning use DeBruce Polish, it is non-toxic and odorless. DeBruce polish is also non-abrasive, also use DeBruce Polish on glass/ceramic cook tops. We get DeBruce Polish at debrucepolish.com
Jun 23, 2009 | Frigidaire FEF366 Electric Kitchen Range
Maytag gemini gas stove. Ignitor problems
My experience with this is that it occurs when moisture gets into the ignitor area and shorts out the open and causes the spark. It stops after it drys out.
This is very non-techinical and I will defer if there is a deeper solution.
May 14, 2009 | Maytag MGR6772 Gemini Gas Kitchen Range
St croix pellet stove
Had the same problem which I discovered this weekend..........
I have an eleven year old Afton Bay....the versa grate was not moving. I look into the inner workings of the stove and saw a bracket which had broken off....
The bracket was attached to the versa grate rod and made contact with the cam system in the stove...this is what moves the versa grate...........
I called my dealer, the part costs about $12.00 and looks like it can be replaced with out having a service guy come out..........
Hope this helps
Oct 21, 2008 | Kitchen Ranges
Slippery burner grates
hi thanks for the question i would contact the store you bought the new stove from and ask if they have a none slip grate thanks the appliance doc
Aug 25, 2008 | Tappan TGF320 Gas Kitchen Range
Cleaning grates of GE profile gas stove
Sounds crazy, but this works. Soak the grates in warm to hot water with 2 dryer sheets (Bounce), let them soak for an hour or two. Unbeliveable how they came clean. I did have to use a Scotch Brite pad on the two that I use most, but it sure beats replacing them.
Jul 02, 2008 | GE Profile JGP636 Gas Cooktop
JGBP89SEMSS BURNER HEIGHT
Sounds right long as you did the conversion okay did you change the spring in the reg ? lp gas does burn lower than nat gas smaller blue flame . you could see if the aeration can be adjusted to the burners You could also check the pressure at the burners lp working pressure is 14in wg .
You could check the reg outside . That's all I got .
Mar 17, 2017 | GE JGBP88SEKSS Gas Kitchen Range
Hotpoint RGB790SEHSA Gas Kitchen Range Logo
365 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
